VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Dec 8, 2019 at 1:37 PM
    #2251
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It's okay to flash the .p5f file that you have now. The TCU file will be sent to you when the one for your specific ECU has been completed.
    mzim[QUOTED] likes this.
  2. Dec 8, 2019 at 1:40 PM
    #2252
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    2015 Tundra DC Silver Sky
    275/65/20 Goodyear Wrangler Duratracs (May2024) Full ARH long tube system Bilstein 6112 Front +2.7" Bilstein 5160 Rear & Icon 1.5 AAL & +2.0 Shackles Fender Flares 1D6 White Knuckle sliders TRD Grille Morimoto LED Headlights with LED DRL/sequential amber switchback turns Rigid Fogs with Square TRD Bezel 4x LED bed lamps wired in OV Tune base load with iterations coming Tech12Volt remote with 2 way fobs and range extender antenna 4.88s with Auburn TRD skid plate Koyo radiator - FAILED REINSTALLED OEM Tyger tri-fold bed cover Bed mat from Boss 4x4 Front bumper spacers 0.5 inch by Boss 4x4 Pop n Lock tailgate wired in Black badging all around Classico Faux Leather Seat Covers Rough Country Floormats Halo 9 HU Underseat kicker sub JRT upgraded speakers
    Would be easier and less questionable if this procedure were documented somewhere. At least i can get questions answered here. Thank you Wynnded and Trucky Truck
    TruckyTruck likes this.
  3. Dec 8, 2019 at 1:41 PM
    #2253
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    We're on the bleeding edge here, it's crazy!:thumbsup:
  4. Dec 8, 2019 at 1:47 PM
    #2254
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Yep, you need to flash that first tune, use the logger to capture how your truck runs with it and send the results back to Mat. Afterwards, he will make adjustments to your specific truck and send you another updated file.
    mzim[QUOTED] and Wynnded like this.
  5. Dec 8, 2019 at 1:58 PM
    #2255
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    TCU file is for the Tacomas.
    If you get a TCU file from us it will be specified as a TCU file. Otherwise skip that part of the instructions.
    theraven, TruckyTruck and mzim like this.
  6. Dec 8, 2019 at 2:08 PM
    #2256
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    Ok... thank you Mat. I THINK IM READY!
  7. Dec 8, 2019 at 2:44 PM
    #2257
    TruckyTruck
    Gary
    Hey Mat, what's your timeline for the tundra tune? Are you planning on getting everything finished before the end of the year? Specifically, early shifting in first gear and transmission features for all ECU's.
    Towing with the new transmission update was excellent, by the way.
  8. Dec 8, 2019 at 4:06 PM
    #2258
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    I can't promise every ECU ID will be done in time, as some are harder than others.
    But I'm working on getting as many as I can done
  9. Dec 8, 2019 at 4:30 PM
    #2259
    TruckyTruck
    Gary
    No, that's good! Not looking for promises, just curious about your estimated timeline. Keep up the good work :thumbsup:
    Wynnded likes this.
  10. Dec 9, 2019 at 4:09 PM
    #2260
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    one more easy question. When i turn the key to on, not start, im getting 12.2 or so volts reading. i have radio off, etc. Will this reading be ok for the duration of the flash?
  11. Dec 9, 2019 at 4:15 PM
    #2261
    TruckyTruck
    Gary
    You better put a charger on the battery... You don't want to brick the ECU. Either that or start the motor for a few minutes and get the voltage up higher.
    14burrito and mzim[QUOTED] like this.
  12. Dec 9, 2019 at 4:25 PM
    #2262
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    i have a charger to use during the procedure.
    Ive started the truck and the voltage jumps to 13.8 or 9. Normal. As soon as I shut it off it drops to 12.3 or so. With charger on, I can get it up to 12.8 and steady with the key turned to on
  13. Dec 9, 2019 at 4:28 PM
    #2263
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Is this a harder ecu to work on? (crosses fingers, toes & eyes hoping not)
  14. Dec 9, 2019 at 5:11 PM
    #2264
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    So would 12.8 V be sufficient for the duration of the flash. What would the lower threshold be? just curious
  15. Dec 9, 2019 at 5:16 PM
    #2265
    TruckyTruck
    Gary
    It shouldn't drop below 12v. I think a pop-up tells you the minimum. But if you have a charger hooked up, you will be good. 12.8 will work.
  16. Dec 9, 2019 at 5:37 PM
    #2266
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    Thank you sir. You've been a great help here
    MrMax and TruckyTruck like this.
  17. Dec 9, 2019 at 6:18 PM
    #2267
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Why risk bricking an ECU for the few minutes it takes to put on a charger.
    What if something goes wrong?
    What if you get pulled aside mid flash process?
    These trucks seems to have a nice draw with key on.
    IMHO, take the few minutes to hook up a charger regardless of battery voltage.
  18. Dec 9, 2019 at 7:30 PM
    #2268
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    I plan to. Was looking for minimum voltage throughout the flash. Was trying to get a feel for a voltage range with the key on only.
  19. Dec 9, 2019 at 9:55 PM
    #2269
    ZPMAN
    Minnesota
    I was biting nails during my Bully Dog install, aftercooler pump and Phoenix Tesla head unit running with charger attached my volts were dropping. Had to unplug cooler and turn HU screen off to keep a steady 12.8
    mzim likes this.
  20. Dec 10, 2019 at 12:34 AM
    #2270
    ZPMAN
    Minnesota
    I was biting nails during my first Bully Dog flash, aftercooler pump and Phoenix Tesla head unit running with charger was draing volts with key on. Had to unplug cooler pump and turn HU screen off to get a steady 12.8
    Anyone flashing with a Supercharger should have at least a 10 amp charger and or unplug the cooler pump.
    MrMax and TruckyTruck[QUOTED] like this.
  21. Dec 10, 2019 at 4:21 AM
    #2271
    MrMax
    MrMax Introvertigo Eximious Geargasm
    Rob
    Eastern Iowa, USA
    2011 Crewmax S/C TRD Rock Warrior
    Driving the truck for awhile before flashing helps the battery be in a more charged state. Having a charger on while flashing is probably the best insurance against a low voltage drop as well. For the SC guys its not only important to turn off all accessories like radio, climate control, etc...But also pull the fuse for your heat exchanger circ pump...big draw there when the key is on.
  22. Dec 10, 2019 at 5:13 AM
    #2272
    TruckyTruck
    Gary
    Mine isn't SC, but I don't have any problem running the motor a couple of minutes, then turning off the radio and ac before flashing. I don't use a charger. But I do make sure the battery voltage is where it needs to be. If I was in extreme cold or hadn't run my truck in a while, I would use my charger. It's probably a better idea to use a battery charger, but I haven't had a problem. The OV tune flashes quickly and my voltage doesn't drop below 12.3v, by the end of a flash.
    Edit: when I owned a BD tuner, I did use a battery charger. It took longer to flash.
    mzim and MrMax like this.
  23. Dec 10, 2019 at 5:27 AM
    #2273
    MrMax
    Rob
    Eastern Iowa, USA
    I remember my BD flash too...Charger on, everything that could be turned off...off, Holding my breath, crossing my fingers and praying to the tuner gods not to "brick" my ECU while watching that voltage. And like TruckyTruck said..longer...much longer...seemed to take forever at the time.
    Edit...Sorry Trucky, misspelled your name :( Fixed it!
    I dont know what it was...but I never felt right about that BD tune...Then, or the next couple of years running it...funky shifting and never trusting the fuel ratio's in the upper RPM range, etc....That canned tune from Mag/BD had a not so good reputation...some had good luck with it and others seemed to have issues. It was a glorious day back in May of this year when I uninstalled it and flashed my base OVTune. And after many logging sessions and revision's the tune and the truck continue to improve and build my confidence.
    ZPMAN[QUOTED] and TruckyTruck like this.
  24. Dec 10, 2019 at 6:11 AM
    #2274
    ZPMAN
    Minnesota
    I'm hoping for a Cinderella story also!
  25. Dec 10, 2019 at 4:26 PM
    #2275
    Unwildered
    Unwildered New Member
    2018 Magnetic Gray CrewMax
    Stubby Antenna :)
  26. Dec 10, 2019 at 5:19 PM
    #2276
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  27. Dec 10, 2019 at 6:52 PM
    #2277
    mikmikcm15
    mikmikcm15 New Member
    will this tune void warranty? not sure if it was mention before... and can it be tune back to stock if it does void warranty?
  28. Dec 10, 2019 at 7:15 PM
    #2278
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    A stock tune can be reflashed if there's a concern/worry.
  29. Dec 10, 2019 at 7:22 PM
    #2279
    Unwildered
    Stubby Antenna :)
    Thank you!
  30. Dec 11, 2019 at 12:34 PM
    #2280
    TruckyTruck
    Gary
    Unwildered[QUOTED] and Wynnded like this.
Thread Status:
