VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Dec 2, 2019 at 9:49 AM
    #2161
    MrMax
    MrMax Introvertigo Eximious Geargasm
    Rob
    Eastern Iowa, USA
    2011 Crewmax S/C TRD Rock Warrior
    ^^^This^^^
    I SC'd mine along with some other mods simply to make a better towing platform. The reality is my slowest mustang...1999 SVT Cobra N/A full bolt on's making a little over 300whp out accelerates my 450ish whp SC'd truck simply because it weighs 1800+ pounds less. If all out performance is your primary goal there are much better platforms than these three ton trucks.
  2. Dec 2, 2019 at 10:07 AM
    #2162
    Speedkills119
    Speedkills119 Shenanigator
    Ryan
    2017 Silver Tundra 1794
    Mostly Stock Procomp 4" lift Prospeed cold air intake Bakflip bed cover HID head and fog lights 2000W JL Audio build Magnuson supercharger w/ Sniv Pulley AR Headers/full exhaust Auburn Limited Slip Prospeed fuel system w/ 1000cc injectors Dual 450 in tank fuel pump 2nd pump on a Hobbs boost reference switch Lexus RCF throttle body Prospeed catch can system TRD sway bar Prospeed Flex Fuel Tune Dirt Logic coil-over and shocks VR forged wheels CalTracs Nitto 420V 305/50R18
    Tuner is being delivered tomorrow :thumbsup::bananadance::burnrubber:
    shellshock likes this.
  3. Dec 2, 2019 at 10:53 AM
    #2163
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    My MPG remains the same, about 10-11 mpg on the hwy. I went from 87 with oem tune to 91 OVTune.
    Keep in mind The Truck weighs 8000lbs and I have 37s and 4:88 gears
    The base tune you sent me 2 weeks ago does not have gear lock in S mode. I have to press the tow/haul button to get gear lock to work. Is S mode gear lock something that you will be sending me in the future??
    Im sorry, Im a little confused. What is the difference between GearLocking and DirectShift???
    Yes, the throttle limits in 1st/2nd while in 4wd work great! and the shift patterns when hitting it hard off road work well too.
    Removing the throttle limits while in 4wd in reverse would be helpful also
    theraven likes this.
  4. Dec 2, 2019 at 11:23 AM
    #2164
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Okay to cover all the topics:
    S mode gear lock is still in progress for some ECUs
    s mode gear lock means, you move the lever to S mode, you can lock a gear out from downshifting.
    DirectShift is all new, nobody has it except me and one other person who got it today (probly a member here).
    DirectShift works by giving you unlimited gear control.
    I just finished the code for it last weekend, and it wasn't even going to be a feature but it's so nice on this truck it's absolutely one now.
    If you know how stock S mode works, you know that when you shift up or down, it won't always do it when you click it. It does it when it wants to.
    With DirectShift it does it right away, no limitations at all.
    It also shifts much faster than normal. You can full throttle row through the gears very, very quickly and without hesitation. When you shift, it shifts, every time.
    That being said, when you try to shift stupidly, like going into 6th at 20mph, it wont allow it.
    DirectShift does come with some cautions:
    1. Shifting crazy (up down up down up down just to see if it can) may harm the transmission
    2. If you hold the shift up, it will shift each gear at the lowest rpm it can, all the way to 6th
    3. If you hold the lever down it's going to throw you into the lowest gear for that speed, and it's abrupt.
  5. Dec 2, 2019 at 12:27 PM
    #2165
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    I will have a feature video that will go over everything.
    The DirectShift down control is probably the most awesome.
    Say you're in S6,
    Hold the lever down,
    Truck will put you into S3, or even S2,
    Continue to hold the lever and accelerate as hard as you want
    Let off the lever
    Truck will put you into one gear lower than your start (S5 in this case).
    Click the lever down equals go down one gear
    Hold the lever down, you can launch/ accel, then go back to the one gear down after.
  6. Dec 2, 2019 at 12:38 PM
    #2166
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    Don’t tell the taco guys. They’ll go crazy wanting this :)
    Dakar650 and TruckyTruck like this.
  7. Dec 2, 2019 at 12:59 PM
    #2167
    art64
    art64 New Member
    I requested to have Direct Shift added to my tune this past weekend thru zendesk.
    So for example, I'm drivng on the freeway on 6th gear. Then, I proceeded to exit. Do I downshift to the appropriate gear as the truck is slowing down to stop on the STOP sign or will it downshift itself all the way to 1st gear?
    Just wondering if this works like having a manual transmission.
  8. Dec 2, 2019 at 1:17 PM
    #2168
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    If you just decelerate from 6th and you don't do anything else, the truck will still downshift on it's own. it won't stall or be stuck in 6th. but it will do it's downshifts at very low rpm, around 1100-1200 rpm.
    Ericsopa and TruckyTruck like this.
  9. Dec 2, 2019 at 1:29 PM
    #2169
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    I can't imagine a reason not to have it. The last email I send detailed out my request pretty well and I dont want to bog you down with emails. Can you just add that to mine, or do I need to request it formally? Thanks!
    Wynnded, shellshock and suby2low like this.
  10. Dec 2, 2019 at 1:32 PM
    #2170
    suby2low
    suby2low New Member
    2016 TRD Tundra DC SC'd
    3" lift w/ 33x12.50s, Grampa cap, TRD supercharged, URD pulley, 340LPH FP, OV tuned
    @OVTune I sent in data logs for a tune revision a little over a week ago. The direct shift option has come out since then. I would really like to have this feature as well added to my tune revisions. order #5100.
  11. Dec 3, 2019 at 5:09 AM
    #2171
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Ok, thanks for the explanation. Sounds like "s mode gear lock" and "direct shift" are pretty similar? Both will hold whatever gear you choose, correct? Sounds like direct shift just shifts faster. Or am I missing something?
    Will you be sending me another base tune with "s mode gear lock", or do I have to request it or something?
  12. Dec 3, 2019 at 6:08 AM
    #2172
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    I don't know why people are so bent on numbers, There is a lot more to driveability than power.
    Neutron, Ericsopa, theraven and 3 others like this.
  13. Dec 3, 2019 at 6:16 AM
    #2173
    TruckyTruck
    Gary
    Good gravy... So more hp. More tq. Faster shifting. Have you looked at the Dyno sheet?
    One could only think if a of those have increased, a vehicle would move from 0 to 60 faster than before.
    Neutron, Wynnded and MrMax like this.
  14. Dec 3, 2019 at 6:24 AM
    #2174
    MrMax
    Rob
    Eastern Iowa, USA
    Everything you asked about is improved as I and most everyone else implied. From a stop...More power and faster. From a roll...more power and faster. I haven't actually done a 1/4 mile run, but from 20mph to 100mph full throttle pull...guess what...More power and faster :) Did I do any of these with a stop watch...Nope...But I have enough time/miles on my rig to see and feel the difference. And make no mistake it is a noticeable difference. Driveability improvements alone would make this tune worth it to some I imagine.
    As far as risk vs reward goes everyone's opinion will be different. Ive been stock, TRD and BD tuned before going with OVTune and it is by far the best tune yet. Again my opinion, and you always have the ability to flash back to stock(included).
    Thanks for stopping by the thread, and I hope you find what you are looking for...
  15. Dec 3, 2019 at 6:25 AM
    #2175
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    a lot of added risk for very little benefit. Alright.
    We have our dyno results, on page 1. Same thing that any other tuning shop offers (dyno results).
    We have our additional custom features, that nobody else on the planet can provide, without them writing the code them self.
    Free updates, etc
    We've even shown our tune beats competitors tunes out there (page 1 again).
    and our option is cheaper than most others.
    The only thing that is real con in our option is adding new ECUs and writing the code for it can be slow. Also part of that is since we developed the features, we went from tuning about 10 trucks to over 100 in just a few weeks...
    Our features, support, and continued development speaks for itself.
    Im not claiming acceleration improvement only because I dont test it. Im sure its there if tested.,
    Ericsopa, theraven, snivilous and 7 others like this.
  16. Dec 3, 2019 at 7:40 AM
    #2176
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    if you have the flash it, just send us an email support@ovtune.zendesk.com and we can get you switched
    rocky.mtn[QUOTED] likes this.
  17. Dec 3, 2019 at 7:43 AM
    #2177
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    I was wondering this as well. I was just on their website and under the FAQ's page it says each vehicle has to pay license fee.
    @OVTune How much is the fee? Do you guys have any plans to support or start work on 4Runners? Our Tundra and 4Runner are both 19's. Would be cool to get both tuned by you guys. Of course that is if its beneficial to have the 4Runner tuned. Haven't even started looking into that cause its the wife's ride.
    Stroke250 likes this.
  18. Dec 3, 2019 at 3:06 PM
    #2178
    theraven
    theraven New Member
    Central AZ
    16 DC / KI7LWX
    Icon 2.5 cdc front and rear. MCM UCA's, RXT rear leafs , wheelers bump stops, Icon hydrolic Bump stops, Icon six speed 17x8.5 w/35x12.5R17 Nitto Ridge grapplers, A.R.E. CX,, Smittybilt Gen2 12k synthetic on SSBuilt Front bumper, factor 55 fair lead, factor 55 flat link-E, SSBuilt high clearance rear with S2Pro, BD squadron pro fogs and side lights, BD 40" Onx6 behind the grill on SDHQ mount, BD XL80's on SDHQ a pillar/ hood mounts. Switch pros 9100, SDHQ panel mount and SDHQ under hood mount. Pro Grill, SDHQ ABS guards, P&P Sliders, Full RCI skids. Kenwood TM-V71a, Dual GPS antenna, Rago dash mount, WE Boost inreach
    Tune received today, flashed to truck with no problems. data logs sent.
    TruckyTruck, Ericsopa and 14burrito like this.
  19. Dec 3, 2019 at 4:17 PM
    #2179
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Compared to...
  20. Dec 3, 2019 at 6:15 PM
    #2180
    TruckyTruck
    Gary
    Sex with a cactus?
    Wynnded[QUOTED] and Midway like this.
  21. Dec 3, 2019 at 6:23 PM
    #2181
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Peter Piper pricked a peck of prickly pears?
    TruckyTruck[QUOTED] likes this.
  22. Dec 3, 2019 at 6:25 PM
    #2182
    TruckyTruck
    Gary
    Definitely high risk, low reward!
    Wynnded likes this.
  23. Dec 4, 2019 at 3:19 AM
    #2183
    coTony
    Tony
    Montrose, CO
    Got my updated tune flashed last night and the shifting is MUCH improved! Now to find the name of the Flash Manager program so I can remove it from Add/Remove Programs, could not find it. Anyone know the name of it? I could be blind in one eye and can't see sh*t out of the other o_O
  24. Dec 4, 2019 at 4:20 AM
    #2184
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    :monocle:
  25. Dec 4, 2019 at 4:43 AM
    #2185
    osidepunker
    Alex
    2013 Tundra DC 4x4
    You guys crack me up :rofl:
    I went from 87 oem tune to 91 OVTune and I didnt feel any gains in acceleration or HP and MPG remains the same.
    HOWEVER, The Truck drives WAY better. The shifting is vastly improved. Off road it chooses gears very well and the throttle limits greatly improved the performance in deep sand. On the hwy it doesnt hunt for gears anymore and cruising feels like a stock truck again.
    The tune is worth the price. Its not a quick process, but worth it in the end. I'm very happy.
    Now. If I can get the damn logger working so I can send Mat some logs we'll see if I can get some improvements to the power band.
    FYI, Im running stock intake and exhaust and The Truck weighs 8000 lbs and has 37" tires and 4:88 gears
    theraven, airosey and Wynnded like this.
  26. Dec 4, 2019 at 5:18 AM
    #2186
    14burrito
    2014 SR5 CM 4x4 5.7
    How do I crack you up Sir?
    My comment was,
    "I don't know why people are so bent on numbers, There is a lot more to driveability than power."
    I think your experience hit pretty home with my comment.
  27. Dec 4, 2019 at 5:22 AM
    #2187
    MrMax
    Rob
    Eastern Iowa, USA
    I hear you and understand what you are saying. I was not saying it was as noticeable as when I added the SC, but after a couple of tune revisions the throttle response was improved and the truck felt quicker and more responsive. At close to 5800# my SC CrewMax is over a ton lighter than yours :) Just sayin...
    Agreed that the overall drivability...shifting, power and the extra features alone make the tune worth the investment
  28. Dec 4, 2019 at 5:33 AM
    #2188
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Sry didnt mean to lump you in with the others. I agree with you, everyone is fixated on numbers. Like anyone can feel +5hp :rolleyes:
    "more hp. More tq." "More power and faster"
    Thats the shit that cracks me up :rofl:
    theraven and 14burrito[QUOTED] like this.
  29. Dec 4, 2019 at 5:36 AM
    #2189
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I can see how someone with a SC might gain enough HP to feel it.
    And Im sure that there are dyno charts to show HP improvements.
    But I am simply trying to be the voice of reason here. For a normally aspirated truck, I didnt feel any power gains. but then again, I didnt expect to. I didnt buy this tune for HP. I bought it so it would drive better. And it does :thumbsup:
    theraven, snivilous, Wynnded and 2 others like this.
  30. Dec 4, 2019 at 5:37 AM
    #2190
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    Yeah Alex this is my experience so far also. My trucks just feels better and is more fun to drive. MPG’s haven’t changed.
    theraven and osidepunker[QUOTED] like this.
Thread Status:
