VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Jun 3, 2019 at 1:59 PM
    #181
    tbrown
    tbrown 2017 CM FFV
    Nashville, TN
    2017 TRD Blazing Blue
    Magnuson Supercharger Kooks long tube headers King 3.0 remote reservoir w/ clockers front King 3.0 triple bypass remote reservoir rear Deaver Custom leaf Method 312 Corsa Exhaust w/ custom stainless bro’s resonator tip Custom HP tune Viair 400c Dual Onboard Headlight Revolution Stealth Bar Baja design XL 80 ditch lights on SDHQ Ditch brackets Victory 4x4 sliders and bed Molle RCI Skids C4 fabrication overland front bumper Smittybilt x2o 12k winch Toyo Open Country RT 37’s Icon Billet Delta UCA’s Nitro 5.29’s ARB Air locker front and rear Switch Pros Leitner Designs Bed Rack ICS Fab Dash Mount Expedition One Dual Swing Rear Bumper Viper remote start Rosen in headrest DVD players
    why everyone gotta hate on the mac crowd?!...running bd today but you may be persuaded me to move over...
  2. Jun 4, 2019 at 12:38 PM
    #182
    Duneflyer
    Duneflyer MGM is the light at the end of the tunnel
    Darren
    Yuma AZ
    2017 1794 edition Crewmax 4x4
    Nitro 4:88 gear package with locker in rearend, Procomp 6" lift, mid travel arms, with devers on back, Fox 2.5 coilovers
    @OVTune
    I have a 17 FFV 5.7, Magnusson SC'd with 4.88 gears with LSD, catback BAM single exhaust, K&N airbox and filter(supplied by Magnusson) and 35" tires. It really isnt happy with the bullydog tune. Its not set up for the gearing or tire change. When I go to pass at high rpm, it wants to jump back and forth between gears etc. In your build, can you correct the shift points with the gear/tire change? Want smooth shifting, whether in in tow/haul or not. Thats my biggest pet peeve. I have a trip across the country (AZ to Sturgis, SD) towing a trailer, in August and really want to have this problem corrected. Magnusson/Bullydog arent much help.
    UPDATE:: I decided to order the kit.. Order 4624. HURRY UP! :)
    Stroke250, Watt maker and tbrown like this.
  3. Jun 4, 2019 at 1:58 PM
    #183
    Duneflyer
    Darren
    Yuma AZ
    Thats my biggest problem..shifting problem to limp mode.. gotta stop and remove a battery cable to get back to normal.
  4. Jun 4, 2019 at 2:11 PM
    #184
    MrMax
    MrMax Introvertigo Eximious Geargasm
    Rob
    Eastern Iowa, USA
    2011 Crewmax S/C TRD Rock Warrior
    Totaly understand and similar to when I had Lund Racing do the tune for my GT500. Sent you an email but will share the tip here as well...
    For the Supercharged guys...When you are getting ready to flash the truck pull the fuse for the HX pump as it comes on with the key and does draw significant power. I was only seeing 12.42 with the pump running. 12.51 with the pump running and a charger on the truck. pulling the fuse brought me up to 12.7-12.8 and allowed me to write the new OVTuned Flash :)
    Watt maker and Duneflyer like this.
  5. Jun 4, 2019 at 2:16 PM
    #185
    Duneflyer
    Darren
    Yuma AZ
    @OVTune
    just ordered (#4624) this kit... hopefully running the Genesis dual oddessey battery kit will solve that problem..
    MrMax[QUOTED] likes this.
  6. Jun 4, 2019 at 6:41 PM
    #186
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Hello everyone. We will get back with everyone as fast as we can, this week we are getting all testing setup, so quite busy over here! Sorry for any unanswered questions.
    MrMax, TexasTundra27 and TruckyTruck like this.
  7. Jun 4, 2019 at 7:31 PM
    #187
    MrMax
    Rob
    Eastern Iowa, USA
    I would imagine it is the dyno testing to complete the initial Tundra tunes release, but that is purely speculation on my part based upon the equipment they recently received and the commitment to release performance numbers and complete the initial tune offerings next week or so...
    Wynnded and Duneflyer like this.
  8. Jun 5, 2019 at 9:59 AM
    #188
    taco supreme
    taco supreme New Member
    16 white CM 1794
    im in for the group buy if there is one.
  9. Jun 5, 2019 at 3:26 PM
    #189
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    We can fully tune and correct shift points for any gear, up and down. Along with the torque converter. Our tune eliminates the flex fuel issue on trucks where they get the check engine light and limp mode from fuel pressure / fuel pump high demand switch over.
    currently we can only do 2019s by removing the ECU, not something we are offering at this time or testing further yet.
    Watt maker and Wynnded like this.
  10. Jun 5, 2019 at 3:42 PM
    #190
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Correct, currently we are not offering anything for the 2019. We have not advertised anything for any version of the 2019 Tundra yet.
    Wynnded likes this.
  11. Jun 6, 2019 at 8:19 PM
    #191
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    Ok. If there is a group buy, even though I have a '19 , could I still get in on it and just wait for it's release?
  12. Jun 7, 2019 at 11:38 AM
    #192
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    unfortunately right now we do not want to take any orders for 19' trucks.
    group buy for Tundras.com members will be up Mon / Tuesday. Will results and more info.
  13. Jun 7, 2019 at 11:42 AM
    #193
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Ok. How about I buy for '18 and just don't use it till y'all have '19'' figured out? Or are you thinking the '19 will require different hardware? I thought it'd be similar to the '18 BUT, I am no programmer so just my thoughts.
  14. Jun 7, 2019 at 12:05 PM
    #194
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Guess it's not the same.... Patience... I've been waiting for something like this since 2013! :goingcrazy:
  15. Jun 7, 2019 at 12:34 PM
    #195
    Hobbesdsm
    Hobbesdsm New Member
    Eddie
    2016 crewmax limited
    TRD exhaust and rear sway bar, 2018 led headlights
    Haha! Patient, so true! I was about to pull the trigger on one of the other tune but, glad I waited!
    Vr0ck and TruckyTruck[QUOTED] like this.
  16. Jun 7, 2019 at 7:02 PM
    #196
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    Changing damn near everything for 2018, I can't see how the 2019s would be that different...2020 yes. But I guess you have the best working on it so it is what it is
  17. Jun 8, 2019 at 6:34 PM
    #197
    TruckyTruck
    Gary
    @OVTune
    What sort of power difference do you think naturally aspirated ffv trucks will see using flex fuel/ethanol vs 93 octane? Do you plan on doing this on the Dyno at some point?
  18. Jun 9, 2019 at 8:17 AM
    #198
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Anticipating the release of dyno results and the potential release like a new phone release....:drool:
    shellshock likes this.
  19. Jun 9, 2019 at 11:44 AM
    #199
    TruckyTruck
    Gary
    Man, no kidding. But twice as bad!
    Mountun Goat likes this.
  20. Jun 9, 2019 at 1:44 PM
    #200
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    We will post once everything is ready.
    Mountun Goat and Watt maker like this.
  21. Jun 9, 2019 at 1:56 PM
    #201
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    We know, just had to express our excitement.
    TruckyTruck likes this.
  22. Jun 9, 2019 at 6:35 PM
    #202
    Duneflyer
    Darren
    Yuma AZ
    I decided to order my kit early so I can start on getting my truck tuned before the rest of you guys order you kits. . I'm afraid of a huge delay/line to get the tunes dialed in for everyone.
    darkknight2014 and TruckyTruck like this.
  23. Jun 9, 2019 at 6:49 PM
    #203
    TruckyTruck
    Gary
    Lol... Jeeze! :laugh:
  24. Jun 13, 2019 at 4:00 AM
    #204
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Any updates on results or GB?
    Duneflyer and darkknight2014 like this.
  25. Jun 13, 2019 at 1:34 PM
    #205
    Duneflyer
    Darren
    Yuma AZ
    Still waiting on my kit. Dang thing was UPS'd on Monday, and said delivery was yesterday.. then today.. now tomorrow. BLAH! @OVTune (I know, not your fault)
  26. Jun 13, 2019 at 5:52 PM
    #206
    TruckyTruck
    Gary
    I read over on Tacoma world, there was some kind of problem with the tacoma having 6 lugs and the Dyno set up not being able to accommodate it. This was for the Tacoma. So maybe the tundra didn't get a Dyno either. Just speculation though.
    Anyway, its a pretty good thread if you want to see how it's going for the Tacoma. Everyone seems to be very happy with their trucks and the ov programming. Apparently, there was a lot of room for improvement in the whole performance of these tacomas. It's really got me wondering just how much the tundra will be improved over stock. Im pretty excited to find out first hand.
    https://www.tacomaworld.com/threads/2016-toyota-tacoma-ovtune-1-05-tune-development-thread.495735/
    Wynnded likes this.
  27. Jun 13, 2019 at 7:39 PM
    #207
    MrMax
    Rob
    Eastern Iowa, USA
    Patience...It will arrive and you can start the process. Sounds like they are busy getting things dyno'd and working on the base tunes right now.
    Still waiting for the first revision post log's myself, and it need's revised for sure :). I pulled my 16' Jon boat 30 miles the other day and the truck felt power wise like it thought it was pulling my 20' deck boat. Hopefully they get caught back up this month. Ive a 2K mile trip planned pulling the toyhauler the week of July 4th at some higher elevations and I may have to reflash the stock tune and and the crappy shifting BD tune just for that trip. Otherwise....other than that potential hickup...I am really looking forward to seeing these OV Tundra tunes develop and bear fruit :)
    Watt maker likes this.
  28. Jun 14, 2019 at 8:31 AM
    #208
    Duneflyer
    Darren
    Yuma AZ
    That is exactly the reason I want to get started, and tuned as well. I have some shift issues, and am taking a 3000 mile trip August 1st, (AZ to Sturgis, SD and back) pulling an enclosed trailer and my harleys. I have been SC'd for 9 months and have always had these shift issues. The thought of finally having them resolved has made me impatient. I'm not upset or anxious about it, just excited.
    EDIT:: YAY!! Kit arrived today.. now I wait.
    @MrMax Your trip is coming up fast.. hopefully they can get you figured out quick. I still have a month and a half. I love the power the bulldog gives me, but with having the 4.88 gears the shifting is not good.
  29. Jun 14, 2019 at 2:01 PM
    #209
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Yes we have had a few hub issues that we are getting sorted. So the Tundra is a little bit behind. Not much longer though
    Should have your reg key to you asap as well.
  30. Jun 14, 2019 at 4:44 PM
    #210
    Duneflyer
    Darren
    Yuma AZ
    Perfect. Thanks again Matthew. @OVTune
Thread Status:
