VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Nov 22, 2019 at 8:54 AM
    #2041
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Same here.
    suby2low[QUOTED] likes this.
  2. Nov 22, 2019 at 8:56 AM
    #2042
    suby2low
    suby2low New Member
    2016 TRD Tundra DC SC'd
    3" lift w/ 33x12.50s, Grampa cap, TRD supercharged, URD pulley, 340LPH FP, OV tuned
    It is possible to trick the system into thinking there is more or less ethanol than actually true because of the lack of a specific ethanol content sensor. Additives, water, etc... will change how rich and/lean the truck runs and therefore will change the ECMs estimation of ethanol content.
    Seuqoia11[QUOTED] likes this.
  3. Nov 22, 2019 at 9:16 AM
    #2043
    Seuqoia11
    Seuqoia11 New Member
    Wow good to know! will go easy on the snake oils in the fuel!!...
  4. Nov 22, 2019 at 9:36 AM
    #2044
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    12 mpg??
    is your truck holding locked 6th on the highway? it should be
  5. Nov 22, 2019 at 10:01 AM
    #2045
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    @OVTune
    Seemed to be driving normally. Rpm wasn't high like it was unlocked or in 5th. I didn't notice anything abnormal til I flipped to the average mpg screen and saw 14 instead of the usual 18ish for the trip. When I reset it it came back as like 12.5mpg. I had to get off the highway a couple minutes later so I didn't have a chance to mess with it much more.
  6. Nov 22, 2019 at 10:12 AM
    #2046
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    The problem is that there isn't a sensor... It's an algorithm. :rolleyes:
  7. Nov 22, 2019 at 11:02 AM
    #2047
    Duneflyer
    Duneflyer MGM is the light at the end of the tunnel
    Darren
    Yuma AZ
    2017 1794 edition Crewmax 4x4
    Nitro 4:88 gear package with locker in rearend, Procomp 6" lift, mid travel arms, with devers on back, Fox 2.5 coilovers
    My foot is the biggest influencer to my MPG. SC'd 35" tires I get 14-15 at 80 plus on 400 mile rolling hill trip. Same trip at 75mph or less, pulling a tow dolly (unloaded) I was getting 17-18 mpg. I i were to do 65ish I know I could pull 20mpg. But I didnt put a SC on my truck to so 65ish
    Midway and Vr0ck like this.
  8. Nov 22, 2019 at 12:25 PM
    #2048
    Seuqoia11
    Is there a difference between NA and Supercharged MPG with the exact same driving habits? does it even matter to know if somebody is N/A or Supercharged when reporting milage? I just assumed S/C was less mpg in general. Are the EPAs numbers anything to compare to?
    Then again last I checked on some older years on there site like my 2011 sequoia EPA says it gets better milage 19 highway vs 17 for the tundra with same engine/4x4 package. That doesn't make sense. I bet the sequoia is nearly 1000# heavier than a standard tundra. Unless its from aerodynamics but 2 mpg difference. Maybe EPA is smoking something...
    PeakIT and Vr0ck like this.
  9. Nov 22, 2019 at 12:50 PM
    #2049
    coTony
    Tony
    Montrose, CO
    Damn... wish I was getting 18 mpg
  10. Nov 22, 2019 at 12:59 PM
    #2050
    Seuqoia11
    I only see 18 plus with 100% highway literally hot car fill up at gas station next to on ramp and drive on flat section of I-80 till bone dry at 75 mpg. Anything else even if 90% highway 10% city on a tank and I am lucky to get 14 tops... my average is 12-13 in real life. all stock truck with Michelin highway tires.
    Vr0ck likes this.
  11. Nov 22, 2019 at 1:04 PM
    #2051
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I would be surprised to discover that the EPA tested a S/C 'd Tundra/Sequoia. My opinion would be that they (N/A vs S/C'd) would test very similar in similar circumstances. My S/C'd Long Travel Tacoma did, versus when it was stock.
    This is mere speculation, but the Sequoia may be more aerodynamic in that it may allow the air to close more smoothly behind it with less turbulence. ¯\(°_o)/¯
    Vr0ck likes this.
  12. Nov 22, 2019 at 1:08 PM
    #2052
    suby2low
    suby2low New Member
    I see 12-13 on average with my SCd double cab. My commute to work is 13 miles. Half 40mph roads and half interstate @ 75mph. Thats just normal driving, normal acceleration. If I get aggressive with the throttle for a tank of gas, I see it drop down to 10-11. If I am super nice and gentle on the pedal for a tank of gas, I get 15. So I settle for the average with spirited driving here and there. Sure is fun to romp on it from time to time and have a 6000lb truck set you back in the seat.
    Duneflyer, Seuqoia11 and Vr0ck like this.
  13. Nov 22, 2019 at 3:38 PM
    #2053
    Seuqoia11
    So there MAY be one reason a sequoia is better than a tundra? :eek2:
    Wynnded[QUOTED] likes this.
  14. Nov 22, 2019 at 5:28 PM
    #2054
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I wouldn't mind having a Sequoia in the least, but then I'd feel obligated to offer to haul people around. But with a Standard cab, bucket seat Tundra, I don't always have to be a Designated Driver.:burp:
    Vr0ck and shellshock like this.
  15. Nov 22, 2019 at 5:32 PM
    #2055
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Soon!
    Vr0ck, Wynnded and Midway like this.
  16. Nov 22, 2019 at 7:37 PM
    #2056
    ZPMAN
    Minnesota
    How long did it take to receive from order date?
  17. Nov 23, 2019 at 6:16 AM
    #2057
    e30cabrio
    About a week.
    ECU info sent! Need to take Bully Dog off.
  18. Nov 23, 2019 at 7:34 AM
    #2058
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    When was this going to be available for 2019's?
    Dakar650 and FitsofRage88 like this.
  19. Nov 23, 2019 at 7:48 AM
    #2059
    MrMax
    MrMax Introvertigo Eximious Geargasm
    Rob
    Eastern Iowa, USA
    2011 Crewmax S/C TRD Rock Warrior
    Not That I have noticed if...you can keep your foot out of the fun peddle avoiding boost and driving easy it may actually be slightly...albeit...slightly better. Just my observations over the last few years since I SC'd mine. Towing is however a marked improvement...and requires less throttle having more power overall...Pulling the same 9K load through some hills where I would get 6-7mpg, I now get 7-8mpg.
  20. Nov 23, 2019 at 8:39 AM
    #2060
    coTony
    Tony
    Montrose, CO
    I am in the middle of the tune holding until the gear issue is resolved and I am getting 13-14 MPG when I just drive it
  21. Nov 23, 2019 at 9:06 AM
    #2061
    Duneflyer
    Darren
    Yuma AZ
    Same as me max... On the freeway there is noticable mpg improvement being SC'd. Around town about the same and when towing there it's better. But remember.. any gain in mpg you loose by having to purchase 91 octane. But it doesn't mean you still can't use the mpg gains for justification for getting the SC. I know I did.
    MrMax likes this.
  22. Nov 23, 2019 at 9:30 AM
    #2062
    Jbtaco2002
    Jbtaco2002 Almost a Tundra
    San Diego
    nothing cool
    @OVTune
    are the ECU files *.bin?
    i found a russian website that may or may not have the 89663-YWL32 bin file... just not willing to risk it ;-) haha
  23. Nov 23, 2019 at 9:33 AM
    #2063
    Ericsopa
    Ericsopa Old man and the sea
    Flash kit on the way!! :yes::dancingbacon::yay:
    Midway likes this.
  24. Nov 23, 2019 at 1:17 PM
    #2064
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    What gear issue?
    yes. There are some russian sites that have them buy you have to pay, give your credit card info, and hope you dont get a million other charges on top from fraud
    Seuqoia11 likes this.
  25. Nov 23, 2019 at 4:42 PM
    #2065
    suby2low
    suby2low New Member
    Logs done and sent! Really looking forward to the new TCU logic and hopefully squeeze a few more HP out of her as long as she is running safely.
  26. Nov 23, 2019 at 5:26 PM
    #2066
    Seuqoia11
    Try it with a prepaid card if it’s cheap enough.
  27. Nov 23, 2019 at 5:29 PM
    #2067
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    Patience is a virtue.
  28. Nov 23, 2019 at 7:35 PM
    #2068
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    yes
    Dakar650 and rockmup like this.
  29. Nov 23, 2019 at 11:32 PM
    #2069
    ZPMAN
    Minnesota
    How about trying to use an android HU or at least mirroring to it?
    Vr0ck likes this.
  30. Nov 24, 2019 at 4:39 AM
    #2070
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Damn, thats a pretty setup you have there.:thumbsup:
    ZPMAN[QUOTED] likes this.
Thread Status:
