VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Nov 18, 2019 at 8:52 AM
    #1891
    art64
    art64 New Member
    YES!! Very happy with it. I used D mode on the way to work yesterday. Feels solid, a bit firm but not annoying. Tow/Haul shifting hang up is gone!! Shift points are higher than D drive, then it upshifts. No hang ups, no delays. I will load the truck heavy again today for more testing. My truck is retaining the gear lock feature. I'll give it few more days and will data log.
  2. Nov 18, 2019 at 9:18 AM
    #1892
    Duneflyer
    Duneflyer MGM is the light at the end of the tunnel
    Darren
    Yuma AZ
    2017 1794 edition Crewmax 4x4
    Nitro 4:88 gear package with locker in rearend, Procomp 6" lift, mid travel arms, with devers on back, Fox 2.5 coilovers
    I got the latest update to new logger and tune. gear lock in S mode worked as far as Im aware of as I did my data logging. I didnt really do much other testing for the gear lock. My question, which I asked in my follow up email to matt @OVTune was... what is my tow/haul mode now? Did it revert back to what it was before, is it the same tune as without tow/haul on...what is its purpose now?
    Vr0ck and TruckyTruck like this.
  3. Nov 18, 2019 at 9:38 AM
    #1893
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think that it's back to T/H behavior, but may also have GL functionality when you knock it over to S-Mode. You'll probably have to spend more time with it to be sure...or wait on Mat's reply.
    Vr0ck and Duneflyer[QUOTED] like this.
  4. Nov 18, 2019 at 9:53 AM
    #1894
    2Tall
    2Tall New Member
    Chance
    South MS
    2020 Super White CM SR5 4x4
    Can someone clear up the logging process for me, so I know I’m doing it correctly. Do I connect, start recording, stop recording, then save? I don’t want to waste my time and send Mat a bunch of blank files
  5. Nov 18, 2019 at 10:04 AM
    #1895
    Duneflyer
    Darren
    Yuma AZ
    this is what i do.. others can chime in as well.
    I do a few different logs on specific driving things I do. I first do a hot idle for 5 minutes. After uploading the tune, and idling the truck for 5 minutes, I restart the truck and start recording on the logger and then wait 5 minutes. I press stop and it auto saves the data. I add the file name hot idle, at the end.
    then I do a 15 minute noral drive session. Start recording on the logger and then drive around for 15 minutes in normal traffic, doing normal driving things. push stop on the logger and again, add normal 15 minute drive to the end of the file name.
    then again, press record and put truck into gear lock mode, second gear, and idle upto to 2k rpm.. mash the throttle to 3k then idle to 3k mash to 4k rpm. again, stop recording, add name change and then I do a couple speed passes.. 0 mph to 100 mph with the throttle mashed. Being S/C'd the start is a little rough with the spinning of tires, but you get the point. Then stop the log and change the name.
    then I attach all the logs in the email and send.
    This is what I send to Matt, and he hasnt asked for anything else. I suppose he can get a good read on what the truck is doing, both shifting and lean/rich issues across the board. I would be curious of others logging routine.
    2Tall[QUOTED] and Vr0ck like this.
  6. Nov 18, 2019 at 3:45 PM
    #1896
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    @OVTune I received the base tunes for 87 and 91 thank you. However, your email states that I would also have a stock ecu tune but that was not included. Can you please send that in case I need to flash back? Thanks
    Order #5285
  7. Nov 18, 2019 at 3:58 PM
    #1897
    osidepunker
    Alex
    2013 Tundra DC 4x4
    @OVTune I got it thanks for the quick response!
  8. Nov 18, 2019 at 4:36 PM
    #1898
    Seuqoia11
    Seuqoia11 New Member
    cant wait to get your feedback on the tune with the type of use/fun you get out of your ride. Some highway folks like me may never appreciate this tunes abilities offroad! Dont forget pics and Video demonstrating the tunes jump capabilities!!!
    osidepunker[QUOTED] likes this.
  9. Nov 18, 2019 at 5:20 PM
    #1899
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Woot! registered my software, ETA for the kit Friday!
    Thank you!
  10. Nov 19, 2019 at 5:09 AM
    #1900
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I'll definitely report back! I leave for a 4 day off road trip on Thu. I just filled up with 91, I'll run a little gas through the engine then install the base 91 tune this afternoon.
    Biggest thing for me is removing the throttle restriction in 4wd. Thats gonna be huge.
    @OVTune I have a few questions for you:
    How do you want us to log? I didnt see instructions anywhere. How should I be driving the truck when I log? How many logs? How long? Do I log the 91 tune and also the 87 tune??
    In my email I asked about retaining the oem red line limits but I didnt get an answer. Can you tell me what the red line limits are in the base tunes I received?
    Thanks Mat!
  11. Nov 19, 2019 at 6:55 AM
    #1901
    Cuban11182
    Cuban11182 New Member
    Hope Mills, NC
    2018 Tundra Limited
    Kings w/ adjusters, Icon Rebound with Discover AT3 LT 285/75/R17, Airlift bags, ARB dual compressor, OV Tuning,
    For those with the new version of the tune, should gear lock be engaged in "D" while the tow/haul button is on or should it only work in "S"?
  12. Nov 19, 2019 at 6:59 AM
    #1902
    osidepunker
    Alex
    2013 Tundra DC 4x4
    @OVTune Can you answer this question please? I am curious as well
  13. Nov 19, 2019 at 7:08 AM
    #1903
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    Mine is doing it, I just want to make sure this is the way it is supposed to be.
  14. Nov 19, 2019 at 7:09 AM
    #1904
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I havent installed mine yet so I was hoping Mat would explain what it will do lol
  15. Nov 19, 2019 at 8:03 AM
    #1905
    osidepunker
    Alex
    2013 Tundra DC 4x4
    So I cant install the new flashmanager 1.3.0. "VCRUNTIME140.dll not available. Reinstalling may fix this problem"
    But it wont reinstall, tells me the directory already exists. If I uninstall and reinstall I get the same VC Runtime error.
    I'm gonna reload windows and try again. But that means I have to reinstall all kinds of stuff fml
  16. Nov 19, 2019 at 8:08 AM
    #1906
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Some ECU's are not finished, including mine. So it could be that your gear lock works simply by shifting into sequential mode. Or you may still have to press the tow button.
  17. Nov 19, 2019 at 8:10 AM
    #1907
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Well it would be nice if Mat told us which way its going to work
  18. Nov 19, 2019 at 8:11 AM
    #1908
    TruckyTruck
    Gary
    If you have to press the tow button to activate the gearlock, it will gearlock in D also. At least that's the way mine works currently. Mat said some ECU's are finished, to where you don't need to press the tow button. Soon they will all work that way.
  19. Nov 19, 2019 at 8:13 AM
    #1909
    TruckyTruck
    Gary
    I think he includes in his emails if it works in a mode. If not, you will know pretty easily. Since this is your first tune, you probably will need to press the tow button for now. I could be wrong.
  20. Nov 19, 2019 at 8:15 AM
    #1910
    osidepunker
    Alex
    2013 Tundra DC 4x4
    No. He does not mention this stuff in his email. He doesnt say anything:
    "Hello Alex
    attached is a copy of our latest flasher which you will need to use for flashing the tune
    A copy of the stock tune is attached labeled XXX
    attached is two base tunes for two different fuels (87, and 91) which are appropriately labeled.
    NOTE, it is critically important that you do NOT attempt to flash with low battery voltage (below 12.2), the software will tell you before flashing begins.
    IF you get any errors(very rare) DO NOT shut the truck off, the software will prompt you there was an error and ask you to try again, click ok and try again. Keep trying until it does flash successfully.
    (errors are extremely rare, we just tell this to everyone).
    OVTune - Lead Developer/ECU Assembly Development/Toyota Calibration Lead
    www.ovtuned.com
    CUSTOMER SUPPORT / BUSINESS HOURS
    9:00 AM - 4:00 PM EST ( MON - FRI )
    Office closed on weekend/holidays
    Please allow 1-3 business days for response to all inquiries."
    TruckyTruck[QUOTED] likes this.
  21. Nov 19, 2019 at 8:21 AM
    #1911
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    My truck is working like this: in D with tow/haul off, it drives normally. When I put it in S with tow/haul off, I get gear lock. In D with tow/haul on, I have gear lock. When I put it in S with tow/haul on, I have gear lock.
    I'm just making sure this is the way my current ECU is. If it isn't, I've already emailed him saying that this is what is happening on mine, so he is made aware of it.
  22. Nov 19, 2019 at 8:22 AM
    #1912
    TruckyTruck
    Gary
    You have the base tunes. I'm not sure how your gear lock works... But most likely you will have to press the tow button. When you get your logger to work, pull some readings, normal around town driving, wot in D and a wot with the gears locked. When you send those back, if you don't already have gl tied to s mode, I'd just ask him when your ECU should have it that way. I imagine it won't be long.
    You are coming in at the tail end of development for the tundra tune, so it shouldn't be long before it's complete.
  23. Nov 19, 2019 at 8:25 AM
    #1913
    TruckyTruck
    Gary
    Oh ok, so you are positive gl is working just by moving into s mode. Art64 thought the same thing for a while before it was even released... If it does, I'd just make sure to ask for something assigned to the tow button. Another octane or different settings for your current octane.
    Edited... Sorry I've been up since 330
  24. Nov 19, 2019 at 8:27 AM
    #1914
    osidepunker
    Alex
    2013 Tundra DC 4x4
    thank you for trying to help. I appreciate it.
    But I paid Mat a lot of money for this product and I would like him to answer these questions so that I and everyone else knows exactly what we have in our tunes, how to data log properly, and how to install the new flash manager and logger.
  25. Nov 19, 2019 at 8:29 AM
    #1915
    TruckyTruck
    Gary
    Understood
  26. Nov 19, 2019 at 8:29 AM
    #1916
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    I haven't asked for anything as far as different maps with the tow haul button, only that I have gear lock. I'm positive that gear lock works in "S" mode with tow/haul turned off. Either that, or it's not shifting right is my guess. I slap it in S, it goes into 4th and wont down shift when I floor it...it just goes up in RPM.
  27. Nov 19, 2019 at 8:30 AM
    #1917
    TruckyTruck
    Gary
    Awesome! So when you send logs, request something for the tow button. I plan on having it set to 87, just in case I get somewhere that doesn't offer 93 octane.
  28. Nov 19, 2019 at 8:32 AM
    #1918
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    I personally don't use anything other than the lowest octane that is available. If I was really after more power, I'd get a supercharger (which I might eventually). I guess with the tune the tow/haul-ass button has become useless, lol.
  29. Nov 19, 2019 at 8:33 AM
    #1919
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    For certain ECU IDs, this feature is still being worked on, as I said in a previous post I will be listing the finished, in progress, needed, IDs.
    Please review our flash manager instructions / flash manager page / instructions page. The fix for this is on that page. https://www.ovtuned.com/pages/flash-manager
    I believe I have also posted here a few times, but will post again.
    all we need is :
    1x warm idle for a few minutes
    1x casual driving around (normal driving)
    2x full throttle pulls to the limiter or close to
    With the exception being supercharged trucks that are in the process of tuning, you get specific logging instructions from me on what RPM to do your WOT pulls to.
    As previously said, a bunch of times for people who do follow this forum. Some features are not automatically included in your tunes.
    So that there is no future confusion, I'll add all optional features on that list.
    When someone has a question regarding troubleshooting an issue, the first place to go is to our zendesk. not the forum. We will just end up in the same predicament as the tacoma guys. Refusing to contact us through the proper channels, and expecting all of your support on this board. I will not be doing that.
    Duneflyer, theraven, YotaMan and 7 others like this.
  30. Nov 19, 2019 at 8:35 AM
    #1920
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    Answers received. Thank you.
    Seuqoia11 and TruckyTruck like this.
Thread Status:
