VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Oct 25, 2019 at 10:40 AM
    #1621
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    When you removed your original pulley, did you do it with the engine having not been run that day? I've read that this is about the only successful time that owners have been able to remove it while the blower is in the vehicle due to the shaft expanding and essentially locking the pulley on. Before installing my blower, I did remove the stock pulley in anticipation of removing it again after install. Seems that it really wasn't necessary to go that route, but that's the one taken. I reinstalled it with anti-seize to lean things toward my favor. I'm just trying to determine if I need to actually leave it overnight, or if I can drive it the mile into work to do it inside, or if I'd be wasting my time. I may drive it in to work this afternoon where it will sit outside in 40*F weather for three hours, but then I'd still need to fire it up long enough to pull it indoors. I'm also trying to not leave it inside at the workplace overnight, as that's kinda frowned upon and I'd rather avoid that conversation.
    TruckyTruck likes this.
  2. Oct 25, 2019 at 2:30 PM
    #1622
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I had it sit overnight, but I was also replacing my coupler while I was at it so had to pull the nose cone. If your blower sounds weird and grindy at idle I would do that. Made pulling the stock pulley easy, and made pressing the new pulley on a breeze since I just threw the nose cone on the press.
    But back to your original question, I wouldn't worry about it. I would let it sit outside (if you have an electric fan, I put one of those in the engine bay if I'm trying to work on quicker after it ran and keep the hood all the way open). I think doing that for a few hours would be fine. I also think you'll be fine since your original pulley sounds like it came off easily and you prepped it to pull again, my stock pulley I could not get off to the point that my big 3 jaw puller was ripping valleys through the whole pulley since it was seized on so much. I had to make a 1/4" steel backing plate that distributed the force from the 3 jaw to even get the dumb thing off. Considering yours wasn't that hard, I think you'd be fine if it's cool enough to keep your hand on. I'd be more worried about how to get the new pulley on since that sounds like a bitch with that jank ass tool from URD if you're not using a press.
    Wynnded[QUOTED] likes this.
  3. Oct 25, 2019 at 8:23 PM
    #1623
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I drove the truck the five minutes to work and the water manifold was only 60-some degrees, not even as warm as we keep the bays. Then after a few hours outside I moved it inside and began. I pulled the fan and shroud to make room for the puller and got to work. Got the new pulley nice and toasty with a heat gun and put it on with that "jank ass tool from URD". ;) I found it worked rather well, but then I didn't have another plan for the install. The only part that I don't know how I would've handled, was keeping the pulley/shaft from rotating had I not had a friend there to hold the belt type filter wrench to prevent that from happening. I got all the bits back in place and went for a brief whip. Time for a nap and try to figure out a little drive tomorrow, in the daylight this time.:cool:
  4. Oct 27, 2019 at 4:28 PM
    #1624
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think we're good.
    Toyotoholic, ndm417 and TruckyTruck like this.
  5. Oct 28, 2019 at 4:03 AM
    #1625
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Following... wanting to replace my DAP tune.
  6. Oct 28, 2019 at 6:04 AM
    #1626
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    Hey Mat, @OVTune following up about the logs I sent in on 10/7. Order #4776.
    Any timeline for getting my updated tune sent out?
    Thank you
  7. Oct 28, 2019 at 6:07 AM
    #1627
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    I am will be working on several more today.
    For people who have sent logs and are waiting on a new file, you will be receiving one more file update, and then after that the next update is once our latest development is complete.
    Vr0ck and jc153[QUOTED] like this.
  8. Oct 28, 2019 at 6:10 AM
    #1628
    Seuqoia11
    Seuqoia11 New Member
    @OVTune How about those waiting on base tune? Order #5221
  9. Oct 28, 2019 at 6:12 AM
    #1629
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Believe me I am well aware that you are waiting and as soon as I have it setup you will receive everything
    Seuqoia11[QUOTED] likes this.
  10. Oct 28, 2019 at 6:12 AM
    #1630
    Seuqoia11
    thanks... !! Cant wait!!
  11. Oct 28, 2019 at 6:20 AM
    #1631
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Make sure you post in here when your new updates are added to the base tune. I am waiting to send you my ECU ID because I dont want to load the base tune until you update it. Thanks Mat!
  12. Oct 28, 2019 at 7:57 AM
    #1632
    suby2low
    suby2low New Member
    2016 TRD Tundra DC SC'd
    3" lift w/ 33x12.50s, Grampa cap, TRD supercharged, URD pulley, 340LPH FP, OV tuned
    I'd say quit waiting and send him your ID and get a tune sooner than later. You will want to log anyways and get tune updates then. It takes 5 minutes to load the tune and our ECUs can handle being re-mapped an infinite # of times. You are missing out.
    shellshock and Vr0ck like this.
  13. Oct 28, 2019 at 8:32 AM
    #1633
    osidepunker
    Alex
    2013 Tundra DC 4x4
    What am I missing out on? Weird shifting?
  14. Oct 28, 2019 at 8:56 AM
    #1634
    snivilous
    SW UT
    My tune feels totally fine with shifting and power delivery and everything and I've never sent in logs. It feels way nicer than the stock or TRD tune did. Lots of bitching in this thread, so to counter that I think the OVT is awesome and I would be 100% happy if what I have now is the final tune.
    ZPMAN likes this.
  15. Oct 28, 2019 at 9:33 AM
    #1635
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I'm not bitching. I have several friends with legitimate complaints about the shifting in the base tune.
    I paid for this product so obviously I believe in it.
    I am simply asking Mat to remember to let us know when he incorporates the new changes to the shifting that he mentioned. I don't want to run a base tune that shifts funny.
  16. Oct 28, 2019 at 10:44 AM
    #1636
    suby2low
    suby2low New Member
    I had 1 or 2 quirky shifts in the first few days of running my base tune. Its been good since then. And I also am still running on base tune. Havent made time to get some logging done. I also agree that Matts base tune is much better than TRD tune and BD tune. The only thing I wish I could have changed is being able to use my Tow/haul mode without having to use sport shift. But that is minor.
    ZPMAN likes this.
  17. Oct 28, 2019 at 12:34 PM
    #1637
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Lol!!!! Oh I needed that today.
  18. Oct 28, 2019 at 12:35 PM
    #1638
    TruckyTruck
    Gary
    Yes. Yes you do.
    Rex Kramer[QUOTED] likes this.
  19. Oct 28, 2019 at 12:37 PM
    #1639
    TruckyTruck
    Gary
    You are missing out on a noticable amount of added power and better hwy mpgs for sure. Yes, the shifting isnt correct yet. But it's not terrible. I still couldn't make myself go back to stock. It's just that much better.
    suby2low likes this.
  20. Oct 28, 2019 at 1:36 PM
    #1640
    osidepunker
    Alex
    2013 Tundra DC 4x4
    What's so funny?
    I already paid for it. What's wrong with waiting for the updates?? Stock tune doesn't bother me. I'm only interested in removing the throttle limits in 4wd
  21. Oct 28, 2019 at 2:19 PM
    #1641
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    The latest shift updates have been incorporated into new base files as we make them. Probably the older base files that haven't been are what you are hearing about.
    Definitely would be a good idea to send me the ID, just make sure to note "please send me with latest shift development"
    Stroke250, Vr0ck, Wynnded and 2 others like this.
  22. Oct 28, 2019 at 2:22 PM
    #1642
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Ok thx! I'll send it over shortly
    Wynnded and papasmurf like this.
  23. Oct 28, 2019 at 2:25 PM
    #1643
    TruckyTruck
    Gary
    Nothing is wrong with waiting. You just asked what you were missing, so I answered your question.
    I just enjoyed your response! Weird shifting! That's what's funny. :cheers:
    Wynnded and shellshock like this.
  24. Oct 28, 2019 at 2:28 PM
    #1644
    TruckyTruck
    Gary
    This next file we receive will be your expanded shift tables?
    And the one after, will be the updated flex fuel?
    Vr0ck and Wynnded like this.
  25. Oct 29, 2019 at 9:24 AM
    #1645
    Jbtaco2002
    Jbtaco2002 Almost a Tundra
    San Diego
    nothing cool
    @OVTune as if the Sequoia's weren't hard enough just to get base tunes for, mine is a special case with the IPT trans shift kit. Hopefully we can get it dialed in with logging!
    As a note, really just the 1-2 shift is hard and quick shift, the rest feel better than stock but not too noticable.
    I have the BD tuner currently set for performance shift and throttle sensitivity, and the pedal feel is more important to me.
    Excited to start running the tune! Hopefully soon
  26. Oct 29, 2019 at 9:34 AM
    #1646
    Rex Kramer
    Georgia
    Mat responded to my email:
  27. Oct 29, 2019 at 10:00 AM
    #1647
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ya, everything has been dialed back a bit until they can get set up in their new digs. It's only fair.
  28. Oct 29, 2019 at 12:17 PM
    #1648
    Ericsopa
    Ericsopa Old man and the sea
    Me, too......
  29. Oct 30, 2019 at 7:50 AM
    #1649
    Seuqoia11
    @OVTune is there a reason you cant give any sort of time estimate for base tune or the hole OV tune process? After weeks of "I will get all pending tickets caught up and get your stuff done" or "I haven't forgotten about your tune" isn't helping me and I assume others to be patient.
    If you gave a sort of realistic time line with some info I think it would help me and future customer expectations. If 6 weeks or 10 weeks or 3 months is the time it takes to get an OV base tune and revisions of that another 3-6 months till done, AND thats communicated up front than thats fine!
    From reading the fine print upon ordering I had no clue it would take 6 weeks or more to get a base tune, never mind revisions. Nor have you given any time expectation when I have asked in emails and on this forum.
    Maybe you are just as frustrated with ME asking for my tune all the time on this forum! LOL :annoyed:when you think I should know it takes 10 weeks from order to get a base tune. And thats normal. If thats my fault for not knowing I apologize....!!! :(
    I do believe your tune work is the best there is out there! Just let me know some expectations and info and I will wait till then! Thanks Mat!:thumbsup:
  30. Oct 30, 2019 at 7:56 AM
    #1650
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    As soon as I can find the relevant TSB PDF on toyotas server and decompile the CUW file from S-Record format to binary. it's a process, but not impossible. My goal right now is to have everyone, including you, ready to go before Nov 15th.
    Also I really don't think the forum is the most appropriate place for individual answers like this. It is hard to give any *exact* date due to the process involved with adding new ECUs that are not previously done or obtainable by the standard methods (database, etc).
    It is not normally the case to wait this long but toyota ECUs are additionally difficult to the lack of a read function. So far the fastest way by far for this type of scenario is sending us the ECU. Without that, it becomes a easter egg hunt to track down the data from toyota or online.
    Stroke250, shellshock, Vr0ck and 6 others like this.
Thread Status:
