VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Oct 19, 2019 at 8:49 AM
    #1531
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I've seen this too.
    Everyone, just check your To: field in your email. Nothing worse than discovering you've been talking to yourself the entire time. :crazy:
    shellshock and Midway like this.
  2. Oct 19, 2019 at 10:22 AM
    #1532
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Anytime I press the tow button, it engages gear lock. I've only tried it while driving down the hwy, but it will lock into 6th gear. It won't lock the torque converter completely. If I step hard on the throttle, I feel the TC unlock. But it will stay in 6th. Not sure if this was intended, but it is what happens with my truck.
    Now when it's in s mode and I press the tow button, my TC will stay locked.
    I just drove an hour testing it in both D and S mode.
    Wynnded[QUOTED] likes this.
  3. Oct 19, 2019 at 10:24 AM
    #1533
    Jbtaco2002
    Jbtaco2002 Almost a Tundra
    San Diego
    nothing cool
    @OVTune Were you able to get your hands on the Sequoia ecu file? If so I'll feel assured know the tune is coming soon.
    If not, should I just cancel the order and refund until my ecu is supported?
    Thanks in advance
    roy2015 likes this.
  4. Oct 19, 2019 at 11:24 AM
    #1534
    MrMax
    MrMax Introvertigo Eximious Geargasm
    Rob
    Eastern Iowa, USA
    2011 Crewmax S/C TRD Rock Warrior
    That was my understanding as well and all worked properly it seemed for the first 3 tunes/revision's. However after the last revision(8/23/2019) tow/haul does not shift right. it shifts up nicely, but does not want to shift down which sucks in the hilly river valley I live in :) causes me to have to mash the throttle listening to the boost start to come on as the motor lugs and the trans refuses to shift down. Hence the reason I either tow now in regular drive mode or tow/haul+S pretending to drive a manual. I'm sure it will get sorted, and as you mentioned this stuff is all still in development.
    Warreng and Wynnded[QUOTED] like this.
  5. Oct 19, 2019 at 3:27 PM
    #1535
    Seuqoia11
    Seuqoia11 New Member
    @OVTune can you check order 5221 I keep posting that I am waiting but maybe your waiting on something from me. I emailed you my ecu id info last month and no base tune yet. I replied back to your email no mods so i assumed all this time I was waiting for you.
    roy2015 likes this.
  6. Oct 20, 2019 at 3:37 AM
    #1536
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Is it possible to put a bluetooth adapter on our obd2 plug so I can run an app showing live tempatures off my phone? I know they sell bluetooth obd2 plugs, I'd rather just buy a adapter that makes this one wireless since I know it's a good product.
  7. Oct 20, 2019 at 7:16 AM
    #1537
    ZPMAN
    Minnesota
    Nick, I believe you should have no problem with an bluetooth obd adapter but it might depend on what temps your looking for.
  8. Oct 20, 2019 at 7:20 AM
    #1538
    Transmission temp would be at the top of my list. I have the tactix obd2. I was wondering if there was a way to put a bluetooth adapter on the existing taxtix just as a send and reciever.
  9. Oct 20, 2019 at 8:07 AM
    #1539
    ZPMAN
    Minnesota
    At the time of my supercharger install I had my first gen Phoenix android head unit installed, it needed to be connected to my obd2 dock and after installation of supercharger I ended up installing a 3 to1 adapter for the obd2. I have since installed the 2nd gen Phoenix and connection to the obd2 is not needed. When I get time I might install a Torque Pro adapter because the Bully Dog is very hard to read underway. https://www.tundras.com/threads/diy-supercharger-install-2016-5-7-ffv.26402/page-3#post-649897
  10. Oct 20, 2019 at 8:07 AM
    #1540
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    unlikely. You can buy a Bluetooth odb2 for $20-30.
  11. Oct 20, 2019 at 8:33 AM
    #1541
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    - Several more tickets updated as of this morning. We are going through everything as quickly as possible!
    3 ECUs left to update and send out. Thank you for being patient with us, we work every day, so even if you haven't heard from us yet, you will.
    Stroke250, LifeCycle, Midway and 3 others like this.
  12. Oct 20, 2019 at 8:38 AM
    #1542
    Will this include 2019 ECUs?
  13. Oct 20, 2019 at 8:39 AM
    #1543
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    no
  14. Oct 20, 2019 at 9:03 AM
    #1544
    Jbtaco2002
    San Diego
    nothing cool
    Will this include Sequoia ECUs?
  15. Oct 20, 2019 at 12:15 PM
    #1545
    TruckyTruck
    Gary
    Saving the best for last huh...? :D
  16. Oct 20, 2019 at 12:45 PM
    #1546
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    @OVTune Would it be a big deal to put 87 in a truck with the 91 octane tune? Say you need gas and for whatever reason all that's available is 87.
  17. Oct 20, 2019 at 12:55 PM
    #1547
    If you like engine knock, then it wouldn't be a big deal.
    shellshock likes this.
  18. Oct 20, 2019 at 1:33 PM
    #1548
    helidave
    flagstaff
    2015 DC 4x4
    Thanks, but unless you were involved with writing the code and you actually know how well the programming can compensate for the lower octane, that's not really helpful.
    tttrdpro and snivilous like this.
  19. Oct 20, 2019 at 1:38 PM
    #1549
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Go slow and not romp the throttle and you'd be safe until the proper fuel octane is acquired...just be smart if you have to use 87...this is in reference to S/C'd 5.7s tho...so sorry, no help
    snivilous likes this.
  20. Oct 20, 2019 at 2:01 PM
    #1550
    You are right.
  21. Oct 20, 2019 at 2:06 PM
    #1551
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
  22. Oct 20, 2019 at 3:33 PM
    #1552
    TruckyTruck
    Gary
    Did you Sequoia guys get a tune?
  23. Oct 20, 2019 at 4:40 PM
    #1553
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    I have the file for one of the 3, will have second file hopefully tomorrow.
    Surprisingly sequoia files are much harder to obtain that tundra. Not impossible just way more time consuming. I might have to just order a bunch of different year sequoia ecus
    TruckyTruck[QUOTED] likes this.
  24. Oct 20, 2019 at 4:54 PM
    #1554
    TruckyTruck
    Gary
    Probably not a whole lot of tuning going on in the Sequoia market.
    Mat, my truck is one of your last ECU's. Is the transmission portion giving you trouble? When you send this coming update, I'm going to thoroughly test it and try and give better details in how it's acting, before I send any files or description back to you. It seems like it takes a week or two before I notice exactly what it's doing.
    Vr0ck likes this.
  25. Oct 20, 2019 at 6:12 PM
    #1555
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Just a perspective, but I would think that logs are going to be the most valuable feedback, even if you can't describe what you "feel". It's just too subjective, logs are data, not a sensation. Even if you can't include dialog. I've sent in logs that I've described as just random driving around with little to no description. If they aren't relevant, Mat can delete them. The effort for me to collect them is moot.
    Vr0ck likes this.
  26. Oct 20, 2019 at 6:21 PM
    #1556
    TruckyTruck
    Gary
    Yes, but the reason I'm going to wait before sending logs is not for the logs themselves, but a complete description of transmission activity. A few drives around the block isn't enough time to catch little transmission behaviors.
    As far as the logs themselves, I still send in a driving around town log, wot in D, wot with gear lock and this last time I sent one driving in rush hour. He tweaks things every time, so I assume what I'm sending is valuable.
    Vr0ck and Wynnded[QUOTED] like this.
  27. Oct 21, 2019 at 5:09 AM
    #1557
    Seuqoia11
    Mat thanks for emailing me this weekend I just resent you the ECU info with the new Pflash version you sent over and its the exact same info as the old one had. Hopefully that doesn't hinder my tunes progress?
    suby2low likes this.
  28. Oct 21, 2019 at 5:37 AM
    #1558
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Order #5285
    Mat can you please send me my reg key. It's been almost 2 weeks since I send you my system ID. Thank you.
  29. Oct 21, 2019 at 8:08 AM
    #1559
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Wil do
    Also for everyone, when you send us something, if you continually reply to your ticket before we respond, your previous messages get buried.
    Like yours, we never saw the system ID because the after replies buried it.
    For everyone, it goes much smoother if you guys only send something once. Just because we haven't replied doesn't mean we didn't see it.
  30. Oct 21, 2019 at 8:50 AM
    #1560
    Jbtaco2002
    San Diego
    nothing cool
    What's funny and perhaps an indication of my desperation, I was going to offer to remove and send you my ECU!
Thread Status:
