VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Oct 18, 2019 at 6:35 AM
    #1501
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Several files updated yesterday and more today. Thanks everyone. We should have everyone wrapped up by this evening
  2. Oct 18, 2019 at 9:31 AM
    #1502
    Seuqoia11
    Seuqoia11 New Member
    Still pushing refresh. My enter key is about warn out....
  3. Oct 18, 2019 at 10:01 AM
    #1503
    2Tall
    2Tall New Member
    Chance
    South MS
    2020 Super White CM SR5 4x4
    Got my base tunes yesterday evening! Now the long 2 week wait of being stuck at work until I can try it out:(
  4. Oct 18, 2019 at 10:25 AM
    #1504
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Now that's a real bummer!
  5. Oct 18, 2019 at 10:31 AM
    #1505
    toyobama
    toyobama New Member
    I have a 2018 Tundra and I just received stock and base 87 and 91 gearlock. Any guidance on which one has worked best for y’all? Can more than one be installed?
  6. Oct 18, 2019 at 10:33 AM
    #1506
    TruckyTruck
    Gary
    Do these updates include your upgrade to gl being tied to S mode?
  7. Oct 18, 2019 at 10:51 AM
    #1507
    suby2low
    suby2low New Member
    2016 TRD Tundra DC SC'd
    3" lift w/ 33x12.50s, Grampa cap, TRD supercharged, URD pulley, 340LPH FP, OV tuned
    Go fill up on 93 or better and put the 91 tune in. You wont be disappointed.
  8. Oct 18, 2019 at 11:15 AM
    #1508
    toyobama
    toyobama New Member
    How does gearlock work?
  9. Oct 18, 2019 at 11:25 AM
    #1509
    suby2low
    suby2low New Member
    Put the shifter into S mode and turn on tow/haul. Works about the same as before, but it really tries to hold the gear you are commanding. It will only downshift if necessary to keep the engine from stalling or if there is too much knock from what I understand. Pretty sure it will also let you bang it off the rev limiter if you dont command an upshift. It is worth noting that you MUST use Sport shift mode with tow/haul. Tow/haul mode wont shift correctly on its own.
  10. Oct 18, 2019 at 11:26 AM
    #1510
    2Tall
    2Tall New Member
    Chance
    South MS
    I received 87 and 93 tunes, and Mat recommended logs. Will I need to do logs for both? I'll mainly be running 87, but may use the 93 on occasion.
  11. Oct 18, 2019 at 12:00 PM
    #1511
    Seuqoia11
    So jealous on all the new tunes keep mine coming Matt
    roy2015 likes this.
  12. Oct 18, 2019 at 12:08 PM
    #1512
    TruckyTruck
    Gary
    You just got put at the back of the line for adding an additional T to his name... :laugh:
    Wynnded likes this.
  13. Oct 18, 2019 at 12:35 PM
    #1513
    TruckyTruck
    Gary
    Though crowd.... :anonymous:
  14. Oct 18, 2019 at 1:03 PM
    #1514
    Seuqoia11
    Oooooppps...
    TruckyTruck likes this.
  15. Oct 18, 2019 at 3:42 PM
    #1515
    toyobama
    toyobama New Member
    Has anyone downloaded the p5flash 1.2.2? The download is redirecting to a different site. It’s throwing all kinds of virus alerts. The other files from the site don't throw virus alerts.
  16. Oct 18, 2019 at 3:47 PM
    #1516
    TruckyTruck
    Gary
    Is that something new?
  17. Oct 18, 2019 at 3:52 PM
    #1517
    toyobama
    toyobama New Member
    Not sure if it’s new or not. I just know that my virus program does not like page the download is on. The flash files are on a similar page, but the p5flash.exe download is red flagging @OVTune
  18. Oct 18, 2019 at 4:20 PM
    #1518
    TruckyTruck
    Gary
    Yeesh... I turned my antivirus off when I downloaded the programs. Not sure if it mattered or not. But I only use my laptop for this program and techstream.
  19. Oct 18, 2019 at 5:07 PM
    #1519
    LifeCycle
    LifeCycle Build..build..build..
    Hugh
    Barcelona Red SR5 XP CM 2017
    TRD Dual exhaust TRD headlights bedmat Elka with adjustment knobs, ARB leafs-ring Fuel Crush +1 offset 20 inch 5 in backspacing TOYO open country 275/65 R20
    i opened the P5Flash thru the Toyota Flash manager, under the tab: Tuning
  20. Oct 18, 2019 at 6:11 PM
    #1520
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Random thoughts:
    When development reaches the stage where we will be able to have several maps loaded on the ECUs and available on the fly, I was pondering about how to keep track of which one is enabled. The numerical LCD that comes on when in S-Mode. One idea might be that a daily-driver map could be indicated as '0', the next map that you might have elected to be in the queue would naturally be '1' and so on. I find it difficult to imagine, at this stage, that there could/would be greater than 10 maps that a user would find useful or necessary to have loaded up. What order your maps are in may be something that the user could manipulate, might be a custom feature compiled by OVTune, or set up as having a default order of some determination. When the map is changed (rumored to be via the Cruise Control switch) that respective map's "number" might flash in the display at a rate of 2-3 times per second for 5-6 seconds, then go blank or back to whatever function it was serving prior to the user making changes.
    :thumbsup:
    TruckyTruck and LifeCycle like this.
  21. Oct 18, 2019 at 6:41 PM
    #1521
    LifeCycle
    Hugh
    Man, it just boggles my mind on how much potential this tune has on specific user settings it does get complex for an average mind like mine
    shellshock likes this.
  22. Oct 18, 2019 at 7:00 PM
    #1522
    TruckyTruck
    Gary
    Vr0ck, Midway and Wynnded[QUOTED] like this.
  23. Oct 18, 2019 at 7:05 PM
    #1523
    TruckyTruck
    Gary
    LifeCycle[QUOTED] likes this.
  24. Oct 18, 2019 at 7:08 PM
    #1524
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    @OVTune how about a registration code, so i can start requesting a base tune???
    order 5255 thanks, ive sent a zendesk email as well last week
  25. Oct 19, 2019 at 7:13 AM
    #1525
    MrMax
    MrMax Introvertigo Eximious Geargasm
    Rob
    Eastern Iowa, USA
    2011 Crewmax S/C TRD Rock Warrior
    Annoying as hell for me as 80-90% of the time my truck gets started it is towing and/or hauling something. Forces me to either tow stuff in regular drive mode or pretend like Im driving a stick all day :( Waiting for a revision and fix from Matt still. Dont get me wrong, I like the gear lock feature when I want to use it. However 99% of the time I just want to hook up my load select tow/haul and go. Hopefully he gets it sorted for me soon, otherwise I will be dropping the gear lock feature.
  26. Oct 19, 2019 at 7:20 AM
    #1526
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Something about this doesn't sound right. T/H should work as from the factory when used alone. If GL is desired, T/H and S-Mode must be used at the same time with a GL enabled tune. Of course, this is planned to change when the tunes are "officially" released. Things are technically still in the development stage at present.
  27. Oct 19, 2019 at 7:34 AM
    #1527
    TruckyTruck
    Gary
    The tow button will lock gears in D and S right now. The only "towing mode" right now is S mode. Mat did say he was planning to make the tow button function like it was intended, eventually.
    MrMax likes this.
  28. Oct 19, 2019 at 7:41 AM
    #1528
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    How does it lock into a gear in D, what's it's behavior? This is not how I understood it was working. (Disclosure: I don't currently have a GL tune.)
  29. Oct 19, 2019 at 7:42 AM
    #1529
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    What is your email or ticket number? We sent out all pending keys yesterday so maybe I am not receiving it? pm me
  30. Oct 19, 2019 at 8:45 AM
    #1530
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Okay found it, looks like you were replying to yourself somehow so we did not see your ticket update. We have had a few issues with zendesk doing this, but I found it
    ryanwgregg and Wynnded like this.
Thread Status:
