VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Sep 14, 2019 at 10:19 AM
    #1021
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Thank you OV!
    TruckyTruck likes this.
  2. Sep 14, 2019 at 10:38 AM
    #1022
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    more files to send out.
    I can't wait to show you guys the latest stuff we have worked on.. but got to catch everyone up first.
    - Line pressure control for the transmission
    - disabling torque reduction when shifting
    lots of goodies.
    A question asked that would be good to share here. There is no restriction on using map switching, how or when you can implement it. You don't have to stop the truck, or anything. Simply pressing the button does it right on the fly.
    The way we have implemented this is that by pressing the button to switch to map 2 the ECU will perform the necessary branching statements in code on the fly that will update to the new tables.
    These new tables' data will be read, calculated and put into RAM, replacing the old values in less than 10 milliseconds... the clock speed to cycles persecond is ...extremely fast so it will switch seamlessly.
  3. Sep 14, 2019 at 10:46 AM
    #1023
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    :woot: can't wait either!
  4. Sep 14, 2019 at 10:51 AM
    #1024
    Jbtaco2002
    Jbtaco2002 Almost a Tundra
    San Diego
    nothing cool
    :bananadead: refreshed my inbox about 40000 times this morning... Bahaha
    Wynnded and TruckyTruck like this.
  5. Sep 14, 2019 at 10:57 AM
    #1025
    TruckyTruck
    Gary
    Keep refreshing!
    Jbtaco2002[QUOTED] likes this.
  6. Sep 14, 2019 at 10:57 AM
    #1026
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    I still have some files left to send. PM me your ID I'll let you know where you are in the line
    ryanwgregg, Vr0ck and TruckyTruck like this.
  7. Sep 14, 2019 at 11:05 AM
    #1027
    Jbtaco2002
    San Diego
    nothing cool
  8. Sep 14, 2019 at 11:17 AM
    #1028
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Mat is going hard this morning, thank you! Just received the tune for my supercharged Tundra in time to head to the lake this afternoon and then really see how it does picking up a rock crawler to tow across Utah tomorrow. Stoked to have everything before my trip! Thank you again sir!
  9. Sep 14, 2019 at 11:25 AM
    #1029
    4firemandan
    4firemandan Superduper Member
    SWFL
    2016 Crewmax 4x4, 5.7
    TRD Supercharger, Ported SC inlet, RCF TB, 4.5” intake, WMI, 2.38 pulley, custom tune, DW660 inj, aeromotive fpr, msd boost-a-pump
    2 quick questions:
    1. Is that sport shift great lock going to be the standard of you pick "gear locking" instead of tow button? (I like this option MUCH better)
    2. Curious what you're looking to do with 4low throttle, can you explain what/why?
  10. Sep 14, 2019 at 12:00 PM
    #1030
    art64
    art64 New Member
  11. Sep 14, 2019 at 12:14 PM
    #1031
    art64
    art64 New Member
    Wow. This keeps gets getting better and better!! Hopefully the transmission tuning will eliminate the excessive "hang time" on Tow Haul Mode (91 Octane Tune). Sometimes it takes 2 seconds for the transmission to upshift from 3-4, 4-5. It just hangs on top of the rpm i.e. 2500 and the the truck is not accelerating anymore at this point. This is more noticeable on no-load or lightly loaded truck. Sometimes I would kinda let go of the pedal to make the tranny upshift quicker but it is a hit and miss. It's kinda like driving a stick for the first time.
    Thanks for continuing to develop the tune for our Tundras. I started with 2007 RCSB in Feb 07 and now with 2010 Crewmax 4x4, 12 years later we are finally getting the tune that we just dreamed of back in the day.
  12. Sep 14, 2019 at 12:36 PM
    #1032
    snivilous
    SW UT
    Got the tune loaded and drove around the block and some pulls down the street. 93 octane tune for TRD Supercharger with upgraded pulley and gear lock enabled. First thing I noticed is the shifting is WAY smoother. Super quick and crisp, barely noticed it shifted versus the usual jolt and weird shit where it seems to hang at rpm for a second before engaging the next gear. The gear lock seems to work great. The throttle seems much more tame off of idle, as in it's not jumpy (the TRD tune/supercharger had actually cured some of this from the engine/ecu being 100% stock, but the OV tune noticeably improved on it). My AFRs under boost are still in the 9s, but I assume Mat will work with me to dial that in (the TRD tune did the same thing, so not like this is worse). Interestingly I also hit 6.7psi of boost, the highest I've ever hit before at this elevation was 5.8psi. My boost gauge is a little weird at measuring max boost, but one way or another it measured considerably higher first run with the OV tune than it ever measured with the TRD tune. The truck will go right up to the rev limiter if you manually gear lock it, so the gear lock is the real deal (found this out on accident...). Overall I am very very pleased that literally right out the door the truck is performing better and has an actual noticeable difference. The real test will be towing for 300 miles tomorrow, but the gear lock alone will make that a much nicer experience.
    This is the first tune that I've ever gotten (besides the TRD, but that went hand in hand with the blower), and I've always been skeptical about any tunes that don't include physical changes to back them up. Five minutes in and I'm a believer. Back to back from what I had to this is very noticeable improvements. I would be 100% happy with this and no changes in the future, and the fact Mat will help dial in things like shift points and afr makes me that much more excited.
    EDIT: 50 miles on the interstate and good so far. Manually shifted into 6th is way nice, helps fix the cruise control that will shift 3 gears at the glance of a hill. Especially with the blower it'll just add boost to keep speed and stay lugging at 2500rpm or less.
  13. Sep 14, 2019 at 1:51 PM
    #1033
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    If you can get me some logs tonight, or send me a message on the AFR you are seeing at various rpm full throttle I'll update a file before you leave in the morning,
  14. Sep 14, 2019 at 1:53 PM
    #1034
    snivilous
    SW UT
    Awesome, I brought my laptop here so I'll try to grab some data on the way home. Thanks!
    ryanwgregg likes this.
  15. Sep 14, 2019 at 2:07 PM
    #1035
    Cuban11182
    Cuban11182 New Member
    Hope Mills, NC
    2018 Tundra Limited
    Kings w/ adjusters, Icon Rebound with Discover AT3 LT 285/75/R17, Airlift bags, ARB dual compressor, OV Tuning,
    I LOVE the idea of line pressure adjustment. That's how we keep our transmissions alive for longer by allowing less slip in the clutch plates.
  16. Sep 14, 2019 at 2:08 PM
    #1036
    roy2015
    roy2015 Waterproof
    Houston
    Super White = Super Fast
    @OVTune hey Mat you still working on that inbox? Sent you a reply and still waiting on my tune. I feel like it’s Christmas :santa:
    Order 5042
  17. Sep 14, 2019 at 2:34 PM
    #1037
    snivilous
    SW UT
    Maybe this is a dumb question, can someone tell me where to download the data logger? I can't find it in the instructions or on the website.
    HulkSmurf14 likes this.
  18. Sep 14, 2019 at 3:42 PM
    #1038
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Open the Flash Manager, then Tuning (drop down opens) and Data logger is listed. Is that not working for you?
  19. Sep 14, 2019 at 3:57 PM
    #1039
    snivilous
    SW UT
    I'll try it, I just plain didn't know where it was haha.
    EDIT: I seem to have the same issue of most of it crashing when I try to connect. Oh well, hand written data logging it is.
    Wynnded[QUOTED] likes this.
  20. Sep 14, 2019 at 3:59 PM
    #1040
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Got the tune flashed on my TRD SC'd truck...far superior transmission shifting, smooth, I hear the SC work more then it used to just downshift...it feels like it's meant to run...will get some DL'n tomorrow and see what everything looks like...OVT, thank you!
    andy9743 likes this.
  21. Sep 14, 2019 at 4:02 PM
    #1041
    TruckyTruck
    Gary
    @OVTune I was looking at what was listed in your data logger and noticed it doesn't have a reading for ethanol %. Not sure how useful it is for you, but I wondered bid you could add it.
    The reason I ask is for the longest time I had to check my ethanol levels because of Toyotas crazy fuel/ethanol algorithms. Min would climb until I had to get it reset.
    Anyway it would be nice to just see it on your program instead of having to hook up my other obd and use the app I have.
    Any chance of that? Honestly I don't want to take away from your programming time. But if it's a simple flip of the switch, it might be nice.
    Got my first driving around town log done. So far so good! Smooth and transmission shifts very nice!
    The more I drove around I realized it was holding gears a bit longer.
  22. Sep 14, 2019 at 4:05 PM
    #1042
    Jbtaco2002
    San Diego
    nothing cool
    Is this with p5flash.exe you run to identify and flash the tune with?
  23. Sep 14, 2019 at 4:36 PM
    #1043
    snivilous
    SW UT
    No it was under the Toyota flash manager.
    I took a video of my afrs with rpm call outs and sent it to Mat. If that's enough info to do anything with awesome, if it's not or he's too busy awesome too. I'm just happy I have gear lock now, Ive had afr in the 9s since installing the blower so this is nothing new. Better too rich than too lean.
  24. Sep 14, 2019 at 4:58 PM
    #1044
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ya, I was having the same issue earlier in the day as my laptop had an update last night. I rolled it back and just returned from collecting and sending some data to Mat. Now for a sammich!
  25. Sep 14, 2019 at 5:03 PM
    #1045
    Jbtaco2002
    San Diego
    nothing cool
    I am still waiting for my tune, but I downloaded flash manager and the logger works "for now" . Be glad to get data back to OV for fine tuning.
  26. Sep 14, 2019 at 6:53 PM
    #1046
    4firemandan
    SWFL
    Excellent to hear! What tune were you running before OV?
  27. Sep 14, 2019 at 7:39 PM
    #1047
    HulkSmurf14
    2014 Tundra Limited
    TRD...
    4firemandan[QUOTED] likes this.
  28. Sep 14, 2019 at 8:15 PM
    #1048
    TruckyTruck
    Gary
    @OVTune
    In the email I sent to you, I mentioned that it felt like my truck wouldn't shift out of gear around 30 mph.
    I just wanted to add to that after speaking with another member. I couldn't quite put what I felt into words (well that was a weird statement), but here is a good way to describe what is happening:
    The transmission seems to be tuned to have a bit of the Tow/Haul behavior where it holds the gear a little longer before the truck up shifts. The throttle is kind of jerky trying to maintain 25-30 MPH. It seems like the transmission holds 3rd gear.
    I didn't notice this every time. But I didn't have long to test it out.
    Vr0ck and Wynnded like this.
  29. Sep 15, 2019 at 4:02 AM
    #1049
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    I think in the email with the update it said if you want the short points adjusted or don't like it just let me know, you can email me that not post it here as not everyone is running the same shift tables, it's mod dependent.
  30. Sep 15, 2019 at 5:17 AM
    #1050
    TruckyTruck
    Gary
    My bad
Thread Status:
