VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Sep 5, 2019 at 7:40 AM
    #871
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Ethanol content and tune control via ethanol content is calculated using fuel trim feedback. AKA engine runs leaner, ECU sees this, calculates trim, calculates what the ethanol content "would be" from this. No actual real value of true ethanol.
    As far as controlling tunes via cruise control buttons, possible. We are already doing this on the Tacoma.
    Toyotas ethanol content blender code is too complex to modify safely right now. So instead we are creating a table that takes calculated ethanol content (from the ECU) and throw this into a table that will increase ignition as a result.
    So imagine :
    X = ethanol %
    Y = RPM
    Z= Load
    Table data = Ignition increase
    (4D table)
    This is already being worked on (not even "alpha" so no eta whatsoever). but coding this is slow.
  2. Sep 5, 2019 at 8:20 AM
    #872
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    Thanks for the update - safe E% tuning takes a really long time. Especially if you don't have an actual E% reader - Thanks Toyota. :bananadead:
    OBXTundra, Watt maker and ryanwgregg like this.
  3. Sep 5, 2019 at 9:02 AM
    #873
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I thought that the nannies were disabled in 4lo (assuming you were running that obstacle in low range) ...or might that vary from 2nd to 3rd Gen ( I also thought that I read some time ago there was a subtle change to how they were disabled)?
    TruckyTruck likes this.
  4. Sep 5, 2019 at 9:35 AM
    #874
    KevinK
    Tundras to Sedona
    He tried it in all the possible nanny settings - appears to be independent of nanny settings and is always "on" in 4x4 in 1st and 2nd gear.
    TruckyTruck and Wynnded[QUOTED] like this.
  5. Sep 5, 2019 at 9:37 AM
    #875
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    I had all nannies off. In 4lo, there are only two modes. I even tried it in 4lo D, 4lo 1st, and rear locked/unlocked (arb locker) Acted the same no matter what
  6. Sep 5, 2019 at 9:40 AM
    #876
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Huh, must there to keep the knuckle-heads from (hypothetically) destroying CVs and front diffs with too much skinny pedal.
    TruckyTruck and KevinK[QUOTED] like this.
  7. Sep 5, 2019 at 9:47 AM
    #877
    osidepunker
    Alex
    2013 Tundra DC 4x4
    yeah I can see that. If you dont know what you're doing with the gas you can tear up a lot of shit or even overheat the trans. Toyota probably think its a "safety" feature, but I hate nannies
  8. Sep 5, 2019 at 9:51 AM
    #878
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    They can be a hazard at times....
  9. Sep 5, 2019 at 10:32 AM
    #879
    FredB32
    FredB32 New Member
    2011 TRD RW
    Subbing and following here as I've been reading this thread for a couple of weeks now and just recently (finally!) purchased another Tundra. I may be one of the odd ones out here, and while I can appreciate the power gains (which are impressive, particularly the smooth delivery) - what are the expectations for MPG improvements? Full disclosure: my truck is basically a commuter. No off-roading, no mudding, 99.9% paved roads and highway (the 0.1% is the short entry to our cottage). I don't tow...well, anything really. The gains in the Tacoma were/are impressive...curious if anyone running a stock truck w/87 has any results yet? The only mods on the truck (done by the previous owner) are a K&N CAI (nice and growly...though I'm pretty sure it does nothing) and a remote start (probably dings me slightly in MPG!). Thus far, in <2 weeks of ownership, I've been getting 19-20mpg on road trips (pretty happy with that) and 16-18 day to day commuting through town to work (not a lot of stop and go, ~45ish most of the way). Looking forward to results either way, this is definitely on my list of things to consider!
    ETA: I had my previous '07 w/4.7L back just before gas prices spiked to ~$5/gallon and at the time was getting 12-14mpg on average. I've owned several hybrids in the meantime, and bought the truck knowing full well what I was getting into...so I don't expect 30mpg, but even incremental improvements would be nice! Also...new truck is an '11 Rock Warrior with the 5.7L.
  10. Sep 5, 2019 at 10:35 AM
    #880
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'm getting about the same, but I'm only a couple of hundred miles in. I don't drive my truck as a commuter, it's personal use only and doesn't see a ton of miles.
  11. Sep 5, 2019 at 11:37 AM
    #881
    Jbtaco2002
    Jbtaco2002 Almost a Tundra
    San Diego
    nothing cool
    That N/A torque curve looks amazingly similar to S/C... Can't wait to see an OV Tuned supercharger Dyno!
  12. Sep 5, 2019 at 2:58 PM
    #882
    coTony
    Tony
    Montrose, CO
    Well updating the Windows 10 OS and tried the data logger and it crashed again. It was already not working and crashing the data logger so figured it was worth a try to see if updating would fix it since I heard another in here had that work for them.
    Back to waiting for the new logger. This sucks, freaking Bill Gates
    TruckyTruck and 4Runner like this.
  13. Sep 5, 2019 at 3:11 PM
    #883
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Impressive S/C numbers...looking forward to seeing what more comes of these!
  14. Sep 5, 2019 at 3:13 PM
    #884
    Jbtaco2002
    San Diego
    nothing cool
    Those are my S/C numbers with BD, 95 octane tune and urd underdrive pulley. I was running a bit lean.
    I guess I'll Dyno after ovtune for my comparison
    4firemandan, AZTundra and TruckyTruck like this.
  15. Sep 5, 2019 at 3:19 PM
    #885
    HulkSmurf14
    2014 Tundra Limited
    Awesome!!^^Keep us posted!
  16. Sep 5, 2019 at 3:19 PM
    #886
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    That was me. Sorry for the false alarm for you. It did work for me. Maybe uninstall reinstall, run in compatibility mode?
  17. Sep 5, 2019 at 5:19 PM
    #887
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Had the same issue after running updates on win10 laptop. Have you tried a run-as admin on the logger app?
  18. Sep 5, 2019 at 10:25 PM
    #888
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    My truck has pretty low compression ratio (8.5:1), so 14 PSI on it feels like 10 PSI would on the stock 10.2:1, but it is still good for a low 12 second 1/4 mile :)
  19. Sep 6, 2019 at 3:48 AM
    #889
    coTony
    Tony
    Montrose, CO
    I have uninstalled, reinstalled, disabled Windows Security and run as Administrator --- No luck and stuck
  20. Sep 6, 2019 at 7:16 PM
    #890
    4firemandan
    4firemandan Superduper Member
    SWFL
    2016 Crewmax 4x4, 5.7
    TRD Supercharger, Ported SC inlet, RCF TB, 4.5” intake, WMI, 2.38 pulley, custom tune, DW660 inj, aeromotive fpr, msd boost-a-pump
    How far out are you from OV flash?
    I'm on the fence for my SC myself.. Waiting on some numbers!
  21. Sep 6, 2019 at 7:26 PM
    #891
    Jbtaco2002
    San Diego
    nothing cool
    No idea, just waiting for the registry key email, then I dump my ecu, send to them and get another email with their flash, not sure how long that will take.
    I PMd with another member who has the SC and had BD tune but went OV a few months ago and raved it. And based on the time OV tune is investing into this product, it will only get better with each iteration.
  22. Sep 6, 2019 at 7:48 PM
    #892
    4firemandan
    SWFL
    Thank you for the quick feedback.
    I'm on the BD SC tune currently and have been been and forth between waiting for OV Dyno and AFR sheets and a BD... Although I'm not traveling across the country and honestly OV is sounding super legit.. Just need actual data!
    I love that these guys are putting the time in and here on the forums listening to the community. (Thanks Matt)
    That's how you succeed no doubt!
  23. Sep 7, 2019 at 4:59 PM
    #893
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    @OVTune hey Mat, what's this lean burn strategy business?? I saw your post on a full closed loop. Can you explain that?
    Edit:
    Stroke250 and Wynnded like this.
  24. Sep 7, 2019 at 5:39 PM
    #894
    TruckyTruck
    Gary
    Sounds like someone needs to get off the fence, buy the tune and get on the Dyno... :burnrubber:
    roy2015 likes this.
  25. Sep 8, 2019 at 6:12 AM
    #895
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Huh, interesting to read more when additional information becomes available.
    TruckyTruck[QUOTED] likes this.
  26. Sep 9, 2019 at 6:49 AM
    #896
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Will discuss burn strategy later.
    new logger is actively in development, and going well. Much much better than our older logger. Will be published as a downloadable and by flash manager.
    Likely we will have all of our updates ready to send out when the new logger app is ready to go
  27. Sep 9, 2019 at 7:10 AM
    #897
    4firemandan
    SWFL
    I'm happy to do that with a R and D "use our stuff/test out stuff/report back"... But I'm not ...eh... "Financially equipped" to be paying for someone's R&D on my daily driver.
    I've actually got a lot of questions for Matt about the tune and methanol injection, IATs programming, etc... But it seems like OV is a little too busy right now.
    I'm in no rush.
    Gonna get my wideband on and do some testing with my current BD tune and Methanol.
    If they come back with nice Dyno and AFR numbers I'll be here waiting.
    Wynnded likes this.
  28. Sep 9, 2019 at 9:39 AM
    #898
    Thadragon
    Thadragon New Member
    M.Y
    gray tundra trd 4x4
    Custom exhaust S&B cold air intake
    Did Ov stop taking orders for the 18’s?
  29. Sep 9, 2019 at 10:13 AM
    #899
    TruckyTruck
    Gary
    I don't think so. There was a small window where he stopped taking orders until his tune for the tundra was released, but it was only a week or so. I just checked his website and it looks like you can order for 2018s.
    Wynnded likes this.
  30. Sep 9, 2019 at 10:24 AM
    #900
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Yea we stopped taking orders because we are out of stock, and wanted to publish a big update... I believe I posted about it in this very thread. Dustin obviously has not a clue on how we operate because we do this on every platform. Whenever we have a big update about to post we temporarily go out of stock so that we may first create and publish this update. This isn't specific to the Tundra at all.
    We have been able to flash 2018s since the day we started this platform, in person, remotely, via our flash kit. Unlike the other who is waiting on a 3rd party company (probably dimsport..) to make it available for them.
    Anyways.. back to bringing awesome stuff for this platform.
    Once I finish up these betas for the Tacoma I should be able to show you guys the battery gauge patch that makes it a AFR gauge :)
    I'd wager we'll be first into the 2019s before long, while other companies wait on other companies...
    by the way, we want everyone to know we are expanding to a larger shop before the year ends so winter might be a bit busy during the transition.
Thread Status:
