VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Aug 27, 2019 at 6:21 PM
    #691
    tbrown
    tbrown 2017 CM FFV
    Nashville, TN
    2017 TRD Blazing Blue
    Magnuson Supercharger Kooks long tube headers King 3.0 remote reservoir w/ clockers front King 3.0 triple bypass remote reservoir rear Deaver Custom leaf Method 312 Corsa Exhaust w/ custom stainless bro’s resonator tip Custom HP tune Viair 400c Dual Onboard Headlight Revolution Stealth Bar Baja design XL 80 ditch lights on SDHQ Ditch brackets Victory 4x4 sliders and bed Molle RCI Skids C4 fabrication overland front bumper Smittybilt x2o 12k winch Toyo Open Country RT 37’s Icon Billet Delta UCA’s Nitro 5.29’s ARB Air locker front and rear Switch Pros Leitner Designs Bed Rack ICS Fab Dash Mount Expedition One Dual Swing Rear Bumper Viper remote start Rosen in headrest DVD players
    I bought a new laptop just for this (mac otherwise) and have never been able to pull a log
  2. Aug 27, 2019 at 6:25 PM
    #692
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Man... Well I guess I'll have to try with mine after I get my tune. Can I do this without a tune, just with my dap tune? Maybe I'll try
    Wynnded likes this.
  3. Aug 27, 2019 at 6:32 PM
    #693
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'd guess that it's worth a try if you have nothing else going on.
    TruckyTruck[QUOTED] likes this.
  4. Aug 27, 2019 at 6:35 PM
    #694
    TruckyTruck
    Gary
    I had a lot better things to do until this thread was created!
    Watt maker and Wynnded[QUOTED] like this.
  5. Aug 27, 2019 at 6:41 PM
    #695
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I should have....;) Dang Internet.
    Bear and TruckyTruck[QUOTED] like this.
  6. Aug 28, 2019 at 2:32 AM
    #696
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    Windows 10 is a pile of garbage. I use windows 7 on a daily basis and don’t foresee that changing anytime soon. If you are only using it for programming, there’s zero reason to update unless you enjoy stuff randomly stopping working.
  7. Aug 28, 2019 at 2:38 AM
    #697
    shellshock
    Iowa
    2019 TRD PRO
    There’s a cracked version of TS you can run. A bunch of us on tacomaworld have it running to apply a TSB for the third gen Tacoma and do the vehicle customizations. Works with the tactrix adapter used for the tune.
    This is the one I’ve got installed
    http://blog.obdii365.com/2017/09/18/install-toyota-techstream-12-02-024-on-windows-7/
    The newer version of TS is available too, I just haven’t gotten around to installing it.
    You can also do most common customizations with Carista and some other apps but you need a Bluetooth odb2 adapter for that.
  8. Aug 28, 2019 at 6:12 AM
    #698
    art64
    art64 New Member
    Day 5 driving with this tune 91 octane Shell. Low to mid rpm power and torque are excellent. Transmission feels solid and engaged all the time. Smooth and no erratic shifting. I don’t use Tow/Haul anymore. Not needed. D mode is sufficient enough to move this heavy truck with ease. Have not done WOT yet nor data logging. I have that cash issue too with Win10. Really happy with this tune. Made the truck fun to drive even though it is loaded heavy. I will remove some of the weights this weekend and see how it feels. I’ll leave 300lbs for traction.
    Wynnded and TruckyTruck like this.
  9. Aug 28, 2019 at 7:36 AM
    #699
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    For any tickets that have not been updated yet they will be by this friday, no later than. Including some who have submitted datalogs.
    We had a problem with zendesk misplacing some of our tickets, specifically if you have a "yahoo" email account we may not be getting the email from you at all.
  10. Aug 28, 2019 at 7:52 AM
    #700
    Duneflyer
    Duneflyer MGM is the light at the end of the tunnel
    Darren
    Yuma AZ
    2017 1794 edition Crewmax 4x4
    Nitro 4:88 gear package with locker in rearend, Procomp 6" lift, mid travel arms, with devers on back, Fox 2.5 coilovers
    Sounds like some people on the thread need to go shopping on eBay for used laptops with Windows 7. :spending:
    TruckyTruck likes this.
  11. Aug 28, 2019 at 8:08 AM
    #701
    TruckyTruck
    Gary
    Ok, I'll give it a try. Thanks!
  12. Aug 28, 2019 at 8:11 AM
    #702
    TruckyTruck
    Gary
    Uh oh... I have a Yahoo account. But you've responded to it, so I guess it's not a problem?
    Wynnded likes this.
  13. Aug 28, 2019 at 9:35 AM
    #703
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    2015 Tundra DC Silver Sky
    275/65/20 Goodyear Wrangler Duratracs (May2024) Full ARH long tube system Bilstein 6112 Front +2.7" Bilstein 5160 Rear & Icon 1.5 AAL & +2.0 Shackles Fender Flares 1D6 White Knuckle sliders TRD Grille Morimoto LED Headlights with LED DRL/sequential amber switchback turns Rigid Fogs with Square TRD Bezel 4x LED bed lamps wired in OV Tune base load with iterations coming Tech12Volt remote with 2 way fobs and range extender antenna 4.88s with Auburn TRD skid plate Koyo radiator - FAILED REINSTALLED OEM Tyger tri-fold bed cover Bed mat from Boss 4x4 Front bumper spacers 0.5 inch by Boss 4x4 Pop n Lock tailgate wired in Black badging all around Classico Faux Leather Seat Covers Rough Country Floormats Halo 9 HU Underseat kicker sub JRT upgraded speakers
    Will Fridays work include 0CL42? Thank you
  14. Aug 28, 2019 at 9:54 AM
    #704
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Just covering my bases for 0CG11 Order #4706 as my truck will be available for testing and data logging over the long holiday weekend in a more unique (IMHO) environment than most. :D:plane:
  15. Aug 28, 2019 at 11:07 AM
    #705
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    We still have issues with yahoo emails sometimes being flagged as spam and auto deleted from zendesk
    Stroke250 likes this.
  16. Aug 28, 2019 at 11:11 AM
    #706
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Yahoo Vs. Zendesk. Fight! :duel:
    :infantry: :fenforcer:
    :popcorn:
    TruckyTruck, Vr0ck and shellshock like this.
  17. Aug 28, 2019 at 11:15 AM
    #707
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    Im not using Yahoo email.
  18. Aug 28, 2019 at 11:41 AM
    #708
    Midmo_tundra
    Midmo_tundra New Member
    Missouri
    Been following this since it started, haven't had a tuned vehicle before so ignore my ignorance.
    If we have an E85 (flex fuel) truck, will the truck still switch between E85 and regular fuel? Guess what I am asking is once you flash the truck is it setup for 87/Premium only or will the ECU still adjust if it detects enough E85 content? Or will it require a reflash to an E85 tune file?
    Trying to determine if this could 1. eliminate the alcohol density issues and 2. if these make good power on E85 if I would have to reflash every time I wanted to run E85 vs E10 gas.
    I see regular and tow/haul can have two different tunes set up, just wasn't sure how it worked on E85 trucks. I didn't see it covered, but if I missed it I apologize.
    Sbrakeville, Vr0ck and Wynnded like this.
  19. Aug 28, 2019 at 3:13 PM
    #709
    coTony
    Tony
    Montrose, CO
    Last week it was announced all would be taken care of by the end of the week and Friday morning I received an E-mail from you asking me a question. I was away from any computer access for the day and I responded later that evening. I also followed up again on Monday but I have yet to receive an answer. Yes I have an E-mail address through yahoo.
    Please advise how I am supposed to proceed with an open line of communication moving forward.
    Best regards
    Tony
    mzim and Wynnded like this.
  20. Aug 28, 2019 at 5:13 PM
    #710
    TruckyTruck
    Gary
    ryanwgregg likes this.
  21. Aug 28, 2019 at 5:17 PM
    #711
    TruckyTruck
    Gary
    What the hell, zendesk!!! Someone laughed at me for having a Yahoo email the other day... :rolleyes:
  22. Aug 28, 2019 at 8:33 PM
    #712
    ChargedToyo
    ChargedToyo New Member
    Mario
    2010 Grey
    I live in Phoenix and I'm supercharged. I've seen intake temps around 160-180 on hot days 110+ Idling in daily driving thru the streets. Highway some days I see 140 if its hot. Should we invest money in a bigger intercooler? When are intake temps a concern? Thanks trying to save for this OV tune as well but need gears 1st.
  23. Aug 28, 2019 at 8:42 PM
    #713
    Duneflyer
    Darren
    Yuma AZ
    Good question. I live in Yuma so I have the same heat issues.
  24. Aug 29, 2019 at 5:17 AM
    #714
    MrMax
    MrMax Introvertigo Eximious Geargasm
    Rob
    Eastern Iowa, USA
    2011 Crewmax S/C TRD Rock Warrior
    I wont answer as far a safety goes the truck will see the higher temps and should make adjustments...timing, etc to continue to run safe. Power wise it will make less power after the heat soak sets in and the computer pulls timing and such. I run a triple pass dual fan HX and a 170* thermostat and have the fans adjusted to come on a bit earlier with my GT500 to help avoid the power loss. I don't drive the truck as hard and or fast and have not felt the need to do similar with it. That said you live in a hotter climate than I :)
    ChargedToyo[QUOTED] and Wynnded like this.
  25. Aug 29, 2019 at 5:44 AM
    #715
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Yes I am aware Tony, the moment our developer has the new version of our logger ready everyone will be receiving it. I am really lost on why it is not working, nothing has changed.
    In regards to development testing, we just need the dang logger to work.
    We tuned a magnuson FFV truck in Arizona. Temps do get extremely hot but the truck is still running amazing and offroading all the time out there.
    Our new logger will be using a completely different framework and different library and should be completely issue free.
  26. Aug 29, 2019 at 8:27 AM
    #716
    art64
    art64 New Member
    Day 6 driving with this tune. Finally removed quite a bit of weight on the bed. Left 300 lbs for traction.
    Here are my findings:
    Heavy Loaded 800 lbs: D drive -- Lots of low rpm torque available right off the start. RPM stays low, gear stays low. Good acceleration on 6th gear compared to stock and the other tune. Really impressive.
    Tow/Haul -- a beast. All available torque for that RPM is there.
    Light Weight Truck: D drive -- bland like a stock, nothing to be really excited about. Smoother shifting than stock. Holds gear a bit better than stock.
    Tow/Haul: Super beast with this lightweight truck. All availble torque for the rpm is there. Truck accelerates quickly. Feels solid, crisp throttle response along with shifting. Breaks traction real easy.
    Tow/Haul + S: It's playtime.
    Tow/Haul + S with Nannies disabled: ?? Have not tried it yet.
    MPG: 10 MPG combined city/highway with all the testing, Aircon, idling with aircon.
    Shell 91 gas. 91 Octane tune.
    Fireace, ryanwgregg, Treemite and 5 others like this.
  27. Aug 29, 2019 at 10:28 AM
    #717
    TruckyTruck
    Gary
    Very nice report! I appreciate you taking the time to do this and I'm sure the other guys here do to.
    Wynnded likes this.
  28. Aug 29, 2019 at 11:04 AM
    #718
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Do these tunes help make the DIC "Average MPG" more realistic? I understand it's an "idiot light" or function that is merely eye-candy, but if it were a bit more accurate, I'd be glad...small digression, just curious is all...
  29. Aug 29, 2019 at 5:49 PM
    #719
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Dude. You. Are. Killing. Me.
    Chef! I'll have what he's having! ^
    art64[QUOTED], mzim and TruckyTruck like this.
  30. Aug 29, 2019 at 6:04 PM
    #720
    Midmo_tundra
    Missouri
    I looked on the website and I think this answers my question as yes the ECU will still switch between gasoline and E85. Can someone confirm if that's true? Also wonder if E85 makes more power than running premium? Sounds like it does as it's in all caps MAXIMUM POWER
    Website:
    Flex Fuel Trucks - Ethanol Custom Compensation Tables - MAXIMUM POWER!
    A custom Ignition Table has been designed for Flex Fuel trucks that will add ignition Dynamically when Ethanol content reaches a certain point and the ECU switches to Flex based mapping.
    This table works in conjunction with the stock ECUs Flex mapping to bring even more power dynamically through an on the fly Ignition adder table that increases torque as ethanol content rises.
Thread Status:
