VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Aug 23, 2019 at 7:59 AM
    #601
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'm not seeing anything for 0CG11 in my Inbox, Junk, nor Spam. I checked yesterday and didn't find any recalls/TSBs for my VIN. I don't know if there was an update from 0CG11 to something else. No one has offered such. If I'm supposed to be on something different I'd be interested in knowing what it should be and where to dig it up.
    TruckyTruck likes this.
  2. Aug 23, 2019 at 8:16 AM
    #602
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Hmmm let me double check to make sure nobody else was missed.
    OCL42 file is done, working on that email
    TruckyTruck and Wynnded like this.
  3. Aug 23, 2019 at 8:34 AM
    #603
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    2015 Tundra DC Silver Sky
    275/65/20 Goodyear Wrangler Duratracs (May2024) Full ARH long tube system Bilstein 6112 Front +2.7" Bilstein 5160 Rear & Icon 1.5 AAL & +2.0 Shackles Fender Flares 1D6 White Knuckle sliders TRD Grille Morimoto LED Headlights with LED DRL/sequential amber switchback turns Rigid Fogs with Square TRD Bezel 4x LED bed lamps wired in OV Tune base load with iterations coming Tech12Volt remote with 2 way fobs and range extender antenna 4.88s with Auburn TRD skid plate Koyo radiator - FAILED REINSTALLED OEM Tyger tri-fold bed cover Bed mat from Boss 4x4 Front bumper spacers 0.5 inch by Boss 4x4 Pop n Lock tailgate wired in Black badging all around Classico Faux Leather Seat Covers Rough Country Floormats Halo 9 HU Underseat kicker sub JRT upgraded speakers
    Ok... Thank you. 91 Octane if that matters
  4. Aug 23, 2019 at 9:02 AM
    #604
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Making sure I got my steps right for flashing so I dont muck it up:
    -Turn truck to On (not start)
    -Power off all accessory stuff (lights, radio)
    -Run p5flash app
    -Click Flash It
    -Select tune file from OV
    -Wait for flash to complete
    -Start truck
    Do we need to perform Reset LV and Reset AT?
    Thanks
  5. Aug 23, 2019 at 9:10 AM
    #605
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    These are generally the same, just for the Tacos.
    https://cdn.shopify.com/s/files/1/0...CTIONS_V.1_-_UPDATED.pdf?11913259822523419483
    ryanwgregg and TruckyTruck like this.
  6. Aug 23, 2019 at 9:49 AM
    #606
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    No need to reset LV or AT,
    all steps correct except added:
    - Wait for flash to complete
    - very flash is successful (software tells you)
    - shut truck off, then start. Truck will start 1x then die (normal)
    - start truck again
    - flash complete
  7. Aug 23, 2019 at 10:31 AM
    #607
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I don't know if I should be anticipating anything or not....
  8. Aug 23, 2019 at 10:33 AM
    #608
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    whats your ecu ID?
    I'm locating a few tickets that may have been missing or placed in the wrong section.
    (except 0CL42. you will have yours shortly)
  9. Aug 23, 2019 at 10:38 AM
    #609
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Order #4706
    ECU ID: 0CG11
  10. Aug 23, 2019 at 10:42 AM
    #610
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Thanks OV, thats exactly what I experienced when I performed the flash.
  11. Aug 23, 2019 at 10:42 AM
    #611
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Found. looks like we got that yesterday afternoon so it didn't make it to the tundra folder yet. Working on it now
  12. Aug 23, 2019 at 10:48 AM
    #612
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ya, I emailed yesterday to see if you were looking for testers of my particular ECU ID. I guess that when I sent in my ID information back in June to get the .reg file, I assumed that there'd be a file made for it. My mistake there!
  13. Aug 23, 2019 at 11:06 AM
    #613
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Tried doing datalogging earlier. I launched the ODBDataextractor app and had the unit plugged into the ODB2 port, hit connect on the app and briefly saw data, but the window suddenly closed. Is that normal? Wasnt sure if was logging or not so I drove around for a bit.
    I could not find any csv files created that showed it was logging.
    *Update: just checked the event log on the laptop and ODBDataextractor app crashed shortly after pressing connect and briefly seeing data on the screen.
  14. Aug 23, 2019 at 11:25 AM
    #614
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    First try a different USB port for the cable, second , right click "run as admin" let me know if that works.
  15. Aug 23, 2019 at 11:26 AM
    #615
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Thanks will give a shot later today.
  16. Aug 23, 2019 at 11:51 AM
    #616
    art64
    art64 New Member
    Feedback: Tune is installed. No hiccups at all. I'm a happy camper. Gear lock is a blessing!! I have almost 800 lbs in bed and at 6th gear it accelerated from 70 to 90 really well I would say and in a short time considering the weight of the load. All other gears worked really well. Power and torque are evenly distributed throughout the mechanical range of the pedal. No more "super touchy". Shift feel is smooth like stock not firm. Shift times feels stock also-meaning when I upshift from 4th gear to 5th it's not like manual or modified valve body.
    I have 91 tune. Using Tow-Haul + S mode. 91 Shell, stock single exhaust, AFE drop in filter, stock size AT P rated tires, 4x4, non flex fuel, 2010 Crewmax, Kings on all fours, sway bar delete.
    I cycled thru 4x4 modes:4Hi, 4Lo, Tow Haul On and Off, forward, reverse--no hiccups.
    I'll wait for a week, then data-log. Not sure if ECU is still learning or what but we'll see. DAP is out; OV is in.
    I forgot: Thanks to OV Tune for an awesome product.
  17. Aug 23, 2019 at 12:22 PM
    #617
    Jbtaco2002
    Jbtaco2002 Almost a Tundra
    San Diego
    nothing cool
    I just ordered this so OV will soon have additional supercharged data :burnrubber:
    Midway, TruckyTruck and Vr0ck like this.
  18. Aug 23, 2019 at 1:46 PM
    #618
    Duneflyer
    Duneflyer MGM is the light at the end of the tunnel
    Darren
    Yuma AZ
    2017 1794 edition Crewmax 4x4
    Nitro 4:88 gear package with locker in rearend, Procomp 6" lift, mid travel arms, with devers on back, Fox 2.5 coilovers
    No need to wait. I do data log pretty much immediately after installing the tune. Like, installed my newest revised tune this morning.. logged the data, and have already sent it to him. I have done 5 or 6 tunes this way.
    ryanwgregg, TruckyTruck and Wynnded like this.
  19. Aug 23, 2019 at 2:09 PM
    #619
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Combo of using a diff usb port and running as admin works. Thanks OV!
  20. Aug 23, 2019 at 2:13 PM
    #620
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    That's awesome!!! :headbang:
  21. Aug 24, 2019 at 7:07 AM
    #621
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    0CL42 - how's that email doing?
    Nothing in my inbox or spam
    Thank you.
    Wynnded likes this.
  22. Aug 24, 2019 at 7:43 AM
    #622
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Same here. I suspect that he's doing a release over for the scene at TW this morning. So he's probably getting mobbed.
    mzim[QUOTED] likes this.
  23. Aug 24, 2019 at 8:10 AM
    #623
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Frothy...
    shellshock, Vr0ck and TruckyTruck like this.
  24. Aug 24, 2019 at 12:12 PM
    #624
    art64
    art64 New Member
    2nd day since installation of OV Tune. Truck feels completely different today compared to yesterday. Throttle is more responsive and firm. Yesterday it felt soft and response was not immediate or crisp. Trans shifts also feel firmer. D mode is a beast in itself compared to dap tune. Even with the ac on, performance doesn’t seem to affected. Downshifts or engine braking is also more felt than before. This is with almost 800 lb load on the bed. Definitely more fun to drive this truck today than yesterday when I installed the tune. Have not data logged yet.
  25. Aug 24, 2019 at 1:35 PM
    #625
    TruckyTruck
    Gary
    I was wondering if I was going to feel a difference. I figured the answer would be yes, but good to hear from someone else!
    ryanwgregg likes this.
  26. Aug 24, 2019 at 1:40 PM
    #626
    TruckyTruck
    Gary
    What do you carry around that weighs 800 pounds!? 6 years of driving around with the stock tune, dap, BD, and hypertech. Finally, after all this time, hope that my dang truck will run like it should have straight from the dealership!
    @OVTune Mat, when Toyota finally hires you to program these trucks, don't forget about us little guys :laugh:
    ryanwgregg and Vr0ck like this.
  27. Aug 24, 2019 at 4:53 PM
    #627
    art64
    art64 New Member
    Lol. Feels like this truck has more low rpm torque available with heavy loads. Shifts better and in some instances gets better mpg than the empty truck.
    RPM stays low, transmission feels solid (maybe torque converter locks up sooner). I did this initially with my old 2007 RCSB 4x2, and now with the 2010 Crewmax 4x4. My first tune experience was DAP. Huge improvement over stock. And now with OV, huge improvement over DAP.
    One of these days, I will remove some of the weights and see how the truck drives. Just don't feel like unloading the Quickrete gravel bags. Some of them have holes already. lol This has just became my way of testing drivability, torque. Folks that use their trucks for towing, heavy loads will love this tune. As for MPG--too early to comment. Still enjoying a bit hard than normal acceleration from time to time. I haven't done any WOT or red lines.
    By the way, OV Tune D Mode feels like DAP tune in Tow/Haul Mode and some.
  28. Aug 24, 2019 at 4:57 PM
    #628
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    @art64
    Nice to hear. I'm waiting on my tune so I can test how it does dashing up the mountain passes. Meanwhile, watching Tom & Jerry cartoons. :p
  29. Aug 24, 2019 at 4:57 PM
    #629
    TruckyTruck
    Gary
    Very nice. I pull my camper a lot, so that sounds great
  30. Aug 24, 2019 at 6:10 PM
    #630
    TruckyTruck
    Gary
    You still watching cartoons, or loading a cartune... :homer:Yeah, I was reaching with that one. Trucktune just didn't seem right. Actually none of it does :proposetoast:
Thread Status:
