VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Mar 27, 2021 at 5:17 PM
    #5491
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Hey I figured out that issue you were having on the 3D RPM v Throttle MAF Multiplier table (usually all set to 1.0) but it multiplies the MAF, the issue you were trying to add fuel in at higher load and the ECU ignored it.
    I know why, and have found the controls that allow this table to be active full-time, which it's not stock.
    Also I sent out some more Flex fuel converted SC tunes
    vF Tuner update release expected by monday (includes support for new ecus)
    HulkSmurf14 and Vr0ck like this.
  2. Mar 27, 2021 at 6:55 PM
    #5492
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    @OVTune, is it safe to use the previous Flash Tool to flash a .p5f calibration after having used the current vF Tuner (earlier version) to flash a .vfc calibration? I'm just looking to tinker around with one of the previous calibrations that has the first version of Gear Lock while waiting for the (most recent version) vF Tuner issues to get worked out with my particular ECU version YWF63. Thanks!
    snivilous likes this.
  3. Mar 27, 2021 at 7:05 PM
    #5493
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Yes it is safe
    Wynnded[QUOTED] likes this.
  4. Mar 27, 2021 at 7:10 PM
    #5494
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    :thumbsup::hattip:
  5. Mar 28, 2021 at 11:32 PM
    #5495
    Challenger1
    Challenger1 Gramping
    Andy
    Southern California /Tustin
    I'm trying to purchase the KIT and the TUNE Pack.
    The TUNE PACK link doesn't work and I can NOT find it on the VF Tuner site..
    Can someone point me in the right direction please?
  6. Mar 28, 2021 at 11:45 PM
    #5496
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
    It looks like @OVTune has pulled the Tundra tune packs from the site. Unfortunately it looks like you won't be able to purchase the tune pack at this time.
  7. Mar 28, 2021 at 11:56 PM
    #5497
    Challenger1
    Andy
    Awe Man that sucks! I had it in my "cart" ready to pull the trigger but was waiting on my dealer to give me the thumbs up..
    I finally got my dealer to install the Supercharger and allow me to bring my own tune..
    @OVTune any insight a to when the TUNE Pack will be available for purchase?
    HulkSmurf14 likes this.
  8. Mar 29, 2021 at 6:02 AM
    #5498
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Temporarily down as we are about to put up a new version of vF Tuner with additional ECUs
    Vr0ck, Challenger1, Oats87 and 3 others like this.
  9. Mar 29, 2021 at 9:37 AM
    #5499
    Challenger1
    Andy
    Thanks for the info.
    Any idea when it’ll be back up?
    jc153 likes this.
  10. Mar 30, 2021 at 4:59 AM
    #5500
    kamdogtundra
    kamdogtundra New Member
    Larry
    2018 Crew Cab
    Hey guys, I have a 18 5.7 CM that is basically stock and I don't plan on doing much to it. I don't tow often. I've been trying to read through this thread but was wondering if there is any benefit to either performance of MPG for someone like me.
    Thanks for any advice.
  11. Mar 31, 2021 at 7:53 AM
    #5501
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    No ETA at this time. Sorry. Supporting new ECU versions can be very difficult, and we have enough Tundra Dev to do right now. We thought we had all the IDs and now we have 3 more new IDs..
    I am looking for someone to hire to work specificaly on our Tundra R/D
    FitsofRage88 and TX210Tundra like this.
  12. Mar 31, 2021 at 8:10 AM
    #5502
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    @OVTune For those of us that don't have the tire size option on our tune, can we adjust the "gear size differential 2" parameter to correct for larger tires?
    What do we adjust to make the torque converter stay locked under heavier throttle?
    Vr0ck likes this.
  13. Mar 31, 2021 at 8:12 AM
    #5503
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    @OVTune And while your attention is here for the moment :D. Is the older Flash Tool capable of flashing the newer .vft/.vfc calibrations?
  14. Mar 31, 2021 at 8:13 AM
    #5504
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    No, doing that won't affect tire size. We are adding in the tire size tables.
    The gear size diff table is if you have 5.29s, or 4.88s etc.
    on our forum we will be releasing some calibration guides here very soon, basics on the tables, controls, setting up a file for a SC, etc
    ZPMAN and helidave[QUOTED] like this.
  15. Mar 31, 2021 at 8:13 AM
    #5505
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    VFT yes, VFC no
  16. Mar 31, 2021 at 8:14 AM
    #5506
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Copy, thanks!
  17. Apr 1, 2021 at 11:13 AM
    #5507
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Woop woop!
    vFT ver 1.2.9.9.4 is out!
    HulkSmurf14, Wynnded and TX210Tundra like this.
  18. Apr 1, 2021 at 11:25 AM
    #5508
    Tyger
    Tyger New Member
    2014 Silver Tundra TRD 4X4 off Road
    2 1/4 inch lift kit, SPC front upper arms, Tyger running boards, TRD rear sway bar, TRD Pro shift knob, Spyder headlights, Bak flip MX4 bed cover, R17 TRD Rims wrapped with 285/75/r17 Nitto Terra grappler G2
    What was added/changed? Thanks
  19. Apr 1, 2021 at 11:27 AM
    #5509
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    VF VERSION 1.2.9.9.4 RELEASED
    vF Tuner 1.2.9.9.4 Release Information:
    - 07-17 Tundra Updated support (0CL43, others)
    - Map updates - several ECUs
    - Pro Tuner - Map updates
    - Gen2 ECU Recovery flash mode (in case of ECU brick)
    - Clear DTC
    - Logger speed update (OBD CAN)
    - Other useful changes
  20. Apr 1, 2021 at 11:30 AM
    #5510
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Unfortunately, no tire size map for my ecu: 0CM21
  21. Apr 1, 2021 at 11:34 AM
    #5511
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Vr0ck[QUOTED] likes this.
  22. Apr 1, 2021 at 11:40 AM
    #5512
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ya, I see the Date modified is 3/5/2021. So...patience...
  23. Apr 1, 2021 at 12:04 PM
    #5513
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    tire size maps not included yet. This update had a much needed recovery mode for folks, along with getting some other IDs in.
    the file itself wont modify when we release more tables
    Wynnded likes this.
  24. Apr 1, 2021 at 12:09 PM
    #5514
    Kung
    KG, VA
    Fixed it for you.
    (Relax, I'm kidding around. :p As a fellow IT guy I know you guys are busting your butts. I'll wait patiently.)
  25. Apr 2, 2021 at 6:51 AM
    #5515
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    new version of vF Tuner includes 0CL43, along with some other fixes. We are going to start ramping up production of tune packs now.
    Also, we will be releasing a version of vF tuner really soon that includes Gen1 ECU Recovery tool so that in case you have a bad flash you can recover the ECU. It is not 100% effective though, due to the nature of these ECUs but works 95% of the time.
    Edit*
    we will make sure to include tire size
    Wyndded, I've solved your issue as well and will email you regarding that
    Wynnded, HulkSmurf14 and Vr0ck like this.
  26. Apr 2, 2021 at 9:16 PM
    #5516
    Tyger
    Tyger New Member
    Hopefully I will get to try tune pack before my truck will be picked up by its new owner next week! Otherwise I’ve waisted 6$$
  27. Apr 5, 2021 at 3:59 PM
    #5517
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Ver. 1.2.9.9.5 is out
  28. Apr 5, 2021 at 4:22 PM
    #5518
    Tyger
    Tyger New Member
    Tune packs out? Thanks
  29. Apr 5, 2021 at 6:12 PM
    #5519
    tonybologna
    tonybologna New Member
    Tony
    My truck was flashed with the dap tune years ago and id like to upgrade it with this one. Is it possible to save the dap file with the software and revert back or will it be lost? I did not get the handheld tuner as this was flashed in person with his laptop.
  30. Apr 5, 2021 at 7:18 PM
    #5520
    art64
    art64 New Member
    Unfortunately not without the handheld. I still have my handheld and I flashed back the stock tune before I flashed with OV tune. You probably won't even miss the DAP once the OV tune is loaded.
    apbreaux and HulkSmurf14 like this.
Thread Status:
