VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Nov 5, 2020 at 12:33 PM
    #4981
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Were you able to include any data logs of the behavior when you sent this to his Zendesk? I imagine that would truly expedite the troubleshooting process.
    HulkSmurf14 likes this.
  2. Nov 5, 2020 at 12:38 PM
    #4982
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    2015 Tundra DC Silver Sky
    275/65/20 Goodyear Wrangler Duratracs (May2024) Full ARH long tube system Bilstein 6112 Front +2.7" Bilstein 5160 Rear & Icon 1.5 AAL & +2.0 Shackles Fender Flares 1D6 White Knuckle sliders TRD Grille Morimoto LED Headlights with LED DRL/sequential amber switchback turns Rigid Fogs with Square TRD Bezel 4x LED bed lamps wired in OV Tune base load with iterations coming Tech12Volt remote with 2 way fobs and range extender antenna 4.88s with Auburn TRD skid plate Koyo radiator - FAILED REINSTALLED OEM Tyger tri-fold bed cover Bed mat from Boss 4x4 Front bumper spacers 0.5 inch by Boss 4x4 Pop n Lock tailgate wired in Black badging all around Classico Faux Leather Seat Covers Rough Country Floormats Halo 9 HU Underseat kicker sub JRT upgraded speakers
    I will have to record some and send.
    So this is a thing then huh?
  3. Nov 5, 2020 at 2:40 PM
    #4983
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Can't say. That's Mat's cup of tea.
  4. Nov 5, 2020 at 8:34 PM
    #4984
    downhilldragon
    downhilldragon New Member
    Brody
    2017 Tacoma TRD Pro - OVTuned
    SSO Slimline Bumper with Stage 2 Kit + BajaDesigns 20" Light bar with Amber Backlight + Smittybilt Winch x2o 10,000lb Synthetic NFAB RKR Rock Rails w/Removable Steps OV Tune - VF Tuner SUSPENSION FRONT Stock Fox TRD Pro Shocks RevTek Front Spacer Dirt King Upper Control Arms (on order) A.D.S. - 2.5 Adjustable Dampening Remote Resi Fronts SUSPENSION REAR Stock Fox TRD Pro Shocks Icon AAL (on order) A.D.S - 2.5 Smoothie Piggy Back "Rear" Shock With Compression Adjuster (on order) Deaver Leaf Pack Cab Mount Chop BFG KO2 284/75/R16 + Full-size Spare with OEM TRD Pro Wheel + Rhino-Rack Spare Wheel Strap 4x Rigid Cube Ditch Lights + Cali Raised Ditch Light Hood Mount Brackets + Cali Raised Ditch Light Extension Brackets + 3x Cali Raised Switches + Light Switch Mount Bracket Snugtop Camper Shell with Carpeted Ceiling and Mounting Tracks Prinsu Top Rack Hi-lift Jack + Hi-lift Jack Mount on roof DEFEND INDUST Recovery Traction Tracks (knockoff Maxtrax) Trimax ST30 Trimaflex Spare Tire Cable Lock (Round Key) 36" x 12mm K&N Intake Canvas 270 RV Awning Rooftop Sun Shelter + Prinsu Awning Brackets Fire Extinguisher w/mount Campbell Hausfeld FP209499AV - 3 Gallon Air Compressor (on order) Nitro Gear Pack Front/Rear 5.29
    So that's good to know. I'll probably be unlocking 0CP50 (it's a 2019 ECU) here in a minute and starting to mess with that, since my customer has simple requests and I should be able to crank it out relatively quickly... just throttle changes, small shift map changes, and I'd like to try my hand at gearlock (but it seems the example of gearlock in the Installer folder is missing, the folder is empty?). Worst case, I'm out $75, but it'll be a learning experience haha.
    Also, I get the impression from @OVTune that he's not going to be releasing "tunes" for the Tundras, just the stock files and people can edit them from scratch. If there are ANY .vft's of any tunes out there that Matt or anyone has made, I'd LOVE to study them.
    pnw.tundra likes this.
  5. Nov 5, 2020 at 11:17 PM
    #4985
    downhilldragon
    Brody
    Okay, quick update, just finished my first pass at a Tundra tune, using a lot of learnings from studying Mat's Tacoma 2.0 tunes, along with studying some of the collabs the guys in the Tacoma forum are doing. Will hopefully get a chance to flash this to a coworker's 2019 Tundra tmrw to get some feedback over the weekend. Tried to keep the changes minimal but meaningful to start, and I'm hoping for some marginal improvements in several areas. If it goes well, I'd love to potentially get feedback from people on here with the 0CP50 to see how it compares to @OVTune 's custom tunes, make sure I'm going in the right direction.
  6. Nov 6, 2020 at 4:00 AM
    #4986
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think that you're the only one that's posted that they've unlocked an ECU. They just aren't available yet, meaning our personal particular IDs. That's simply what stage things are at right now. Some of us are chomping at the bit, but understand that this takes time. Keep us apprised of how your Tundra tuning experience goes, anything you've done is all new to us.
  7. Nov 6, 2020 at 5:29 AM
    #4987
    downhilldragon
    Brody
    So I've only plugged in to identify two Tundras so far, one was 0CP50 which is the 2019 I played with last night, and 0CR00 which is a 2020 that isn't supported yet.
    I saw the list of supported ECU IDs a few pages back, so I'm surprised so many people have trucks that aren't supported yet, seemed like a pretty long list?
    I'm sure Mat @OVTune is cranking to get support out for those, I've had a great experience with him so far. I can't believe he used to do custom tunes for EVERYONE on top of adding features across all the products he has. I'm pretty sure duder has not slept in years.
    One thing I found odd, though, is that in the stock tune for I was editing, the "Engine - Cruise Control Active Min Speed" was set to 180kph, which at first glance would pretty much disable cruise control almost entirely, so I set that back down 15 kph, which is what's standard for Tacomas. Unless I'm reading something wrong?
    Wynnded[QUOTED] likes this.
  8. Nov 6, 2020 at 6:24 AM
    #4988
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    All 2018-2019 ECUS are available and ready to unlock in vF Tuner.
    We have several older ECUs done (09-17s) which will be released in the next update.
    Our appointment system to finish tunes in 1 day is working great! so much easier to get everyone's files knocked out in 1 round of flash,log, flash, log.
    I used to custom tune hundreds of cars a month. Mentally, physically, spiritually exhausting.
  9. Nov 6, 2020 at 6:25 AM
    #4989
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Well done on the revised concept of getting these tunes knocked out! We're all looking SO forward to this!
  10. Nov 6, 2020 at 6:53 AM
    #4990
    downhilldragon
    Brody
    Nice, I didn't realize you were still doing custom tunes for Tundras? I assumed support for that would have ended like with Tacomas?
    How does that work as far as cost? I'd love to at least poke around at a custom Tundra 0CP50 vft file to see how close my values are to yours... Any way to make that happen?
  11. Nov 6, 2020 at 1:10 PM
    #4991
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    What about mine? Do I still NEED to get my ECU updated? 0CP80 2019 flex. About ready to pull the trigger on a D3 branded one.
  12. Nov 6, 2020 at 2:36 PM
    #4992
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Yes, you have to get it updated or send it to us.
    It's very unlikely that ANY product can flash your ECU unless it is capable of updating it at the same time.
  13. Nov 6, 2020 at 4:57 PM
    #4993
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    How am I supposed to get it updated if one is not showing available for it? I thought about buying the ecu flash level of TIS and update myself but I don't want to buy it and not 100% know I would have the file available. The other company seems faithful they can flash it. Kinda like bully dog. Read ecu, send file, get file , flash. Something like that.
  14. Nov 6, 2020 at 5:02 PM
    #4994
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    with our cable you can update it with techstream to 0CP81 right from home. Brick proof software, zero chance anything can go wrong.
    But just know that it just gives you access to make your own tune. vF Tuner doesn't come with tunes.
    I am sorry I don't know what else to tell you.
  15. Nov 6, 2020 at 5:06 PM
    #4995
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Ok. I meant any time I search for an update, I dont find one. When putting in my VIN it only shows a TSB for the turn signals. Nothing about ECU updating. I figured I could use the cable I have since I can use TIS already. Do you not offer any type of tune for the 2019's anymore?
  16. Nov 6, 2020 at 5:08 PM
    #4996
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    if you have the cable, get techstream, click "health check" and it will find the update I'm sure.
    No I do not offer any tunes at the moment. Our Tundra Tune pack will return once we finish up these last few. With our appointment setup it's looking like that will be done with 99% in a few days.
    ** Tundra tune pack will return once we finish that AND finish vF Tuner support for older ECUs, which is also almost done
    Vr0ck, HulkSmurf14 and Wynnded like this.
  17. Nov 6, 2020 at 5:14 PM
    #4997
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Ok. I'll try that. That's good to hear because I've been wanting your custom features. I'm not looking for insane power improvements, but any bump is nice. I really want the features.
  18. Nov 7, 2020 at 9:47 AM
    #4998
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Alrighty guys, 4 more people finished!
    vF tuner support on the way!
    great way to end this year...with everything else going on. lol.
    have a good weekend everyone!
  19. Nov 7, 2020 at 9:59 AM
    #4999
    Jbtaco2002
    Jbtaco2002 Almost a Tundra
    San Diego
    nothing cool
    Mat's knocking me out today!!! thank you! are we done though or are you sending one more iteration?
    thanks again!
    Order#5058
  20. Nov 7, 2020 at 10:04 AM
    #5000
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    sent! yes, almost finished
    Jbtaco2002[QUOTED] likes this.
  21. Nov 7, 2020 at 11:21 AM
    #5001
    Jbtaco2002
    San Diego
    nothing cool
    I got it installed and it went for a quick ride and everything is feeling okay but it is raining in southern California for the first time in 7 months so I'll have to wait for a dry day to really test out some full throttle action
    Thanks Mat!
  22. Nov 9, 2020 at 5:15 AM
    #5002
    coTony
    Tony
    Montrose, CO
    Been kind of quiet in here, good for us all
    OVTune[OP] and MTRock like this.
  23. Nov 9, 2020 at 7:44 AM
    #5003
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    We are crunching away in the back ground, prepping vF Tuner for all ECUs, and re-release of premade / tune packs is expected in january.
    2020 Support expected soon too, as folks are sending us ECUs now.
  24. Nov 9, 2020 at 9:03 AM
    #5004
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    :woot:
  25. Nov 9, 2020 at 9:18 AM
    #5005
    lawfarm
    lawfarm New Member
    2018 Tundra SR5 Premium TRD Crewmax
    I had dropped an email to @OVTune on Thursday and hadn't heard back, but I know they're super busy. I had posted on here a few weeks ago and said I'd come back and sing their praises if everything went swimmingly.
    I’ve had the tune installed for several weeks now, and done a few tows with it, along with regular driving.
    I’m still having challenges with the TC not locking. It never locks under 2,000 rpm when towing, except at incredibly light throttle, which I assume is some sort of self-protection feature.
    In 4th, if I can get it to lock, it will stay locked until roughly 70% throttle (based on the TPS sensor readout in the OBDII), and will then unlock.
    In 5th, it will unlock at any meaningful throttle application. Towing at 65 ish, probably 2200rpm, any throttle = unlock.
    In 3rd, it’s hard to get it to lock at all. If I’m in S mode and select 3rd, it will stay unlocked.
    As this was my primary purpose (forcing TC lockup), it's been frustrating. Gearlock works, but TC lock does not. Hopefully, there is an update that will help with this.
    osidepunker and HulkSmurf14 like this.
  26. Nov 9, 2020 at 3:56 PM
    #5006
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Give me a little time to further investigate and get it sorted out, which I will do.
    It would be great to get you scheduled so we can figure it out, knock it out and finish in a day. I emailed you.
    If you give us a chance to get back to you before just coming to the forum it will be easier, we are really trying to get everyone done and happy.
  27. Nov 9, 2020 at 5:31 PM
    #5007
    Seuqoia11
    Seuqoia11 New Member
    Once we have vf tuner, how does somebody know what “safe” air fuel ratio is? Or when knock occurs?
    Mat has said that the built in air fuel ratios are not very accurate. I know a wide band could be added, and read or logged manually/separately but even with a wide band without knock data how would you know if your over the knock threshold of fuel/timing adjustments.
    Is there a knock reading from the ecu that can be data logged or some other method to find the fine lean line for mpg or max Timing advance before knock?
    I know the factory knock sensor and ecu will do some work to prevent damage but I would prefer the tune/adjustments to stay safe from requiring the factory knock system doing it’s thing full time! Not sure how sensitive or affective the factory knock system is?
    can’t wait for vf tuner!
  28. Nov 9, 2020 at 5:38 PM
    #5008
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    I'm subscribing to your newsletter... since I have this same ECU in my 2020. :thumbsup:
  29. Nov 11, 2020 at 7:35 AM
    #5009
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Have you scheduled everyone that has responded to the appointment email? Just want to make sure I don’t slip through the cracks. Thanks
    Vr0ck and Wynnded like this.
  30. Nov 11, 2020 at 7:38 AM
    #5010
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Not yet. still scheduling people, and some haven't responded yet.
    ALSO, we finally figured out what is causing our emails to be sent to spam or blocked and why some of you guys may not be seeing our emails, or why we may not be seeing yours
Thread Status:
