VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Oct 4, 2020 at 8:10 AM
    #4891
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    2015 Tundra DC Silver Sky
    275/65/20 Goodyear Wrangler Duratracs (May2024) Full ARH long tube system Bilstein 6112 Front +2.7" Bilstein 5160 Rear & Icon 1.5 AAL & +2.0 Shackles Fender Flares 1D6 White Knuckle sliders TRD Grille Morimoto LED Headlights with LED DRL/sequential amber switchback turns Rigid Fogs with Square TRD Bezel 4x LED bed lamps wired in OV Tune base load with iterations coming Tech12Volt remote with 2 way fobs and range extender antenna 4.88s with Auburn TRD skid plate Koyo radiator - FAILED REINSTALLED OEM Tyger tri-fold bed cover Bed mat from Boss 4x4 Front bumper spacers 0.5 inch by Boss 4x4 Pop n Lock tailgate wired in Black badging all around Classico Faux Leather Seat Covers Rough Country Floormats Halo 9 HU Underseat kicker sub JRT upgraded speakers
    Thanks for your detailed response. Ill try S mode manually shifting up after a stop later on today. Just suprised me the first time messing around with it.
  2. Oct 4, 2020 at 8:22 AM
    #4892
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ya, play around with it a little so see what happens. Maybe at some point it may make a little more sense. Then maybe let us know here, so we can have an idea what to anticipate.
  3. Oct 4, 2020 at 8:57 AM
    #4893
    Cuban11182
    Cuban11182 New Member
    Hope Mills, NC
    2018 Tundra Limited
    Kings w/ adjusters, Icon Rebound with Discover AT3 LT 285/75/R17, Airlift bags, ARB dual compressor, OV Tuning,
    I'm going to agree. Mine did the same thing when I had the older version of Gear Lock. Basically S-Range GL is manual in the same way that Tow/Haul GL was. You should treat it as a manual, minus the clutch pedal.
  4. Oct 4, 2020 at 12:07 PM
    #4894
    4firemandan
    4firemandan Superduper Member
    SWFL
    2016 Crewmax 4x4, 5.7
    TRD Supercharger, Ported SC inlet, RCF TB, 4.5” intake, WMI, 2.38 pulley, custom tune, DW660 inj, aeromotive fpr, msd boost-a-pump
    It will shift into 4th as soon as its able to with the safety parameters build in.
    From a stop you will start in 2 and then it will quickly go 3..4 and stay there unless you slow WAY down and it has to downshift again because of the safety. From what I remember the indicator stays in S4, same as it does in a regular ECU.
    Like stock, the gear light is what you're "shifted (set) to" not what your trans is actually in.
  5. Oct 4, 2020 at 12:26 PM
    #4895
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Does there seem to be a minimum speed where it'll upshift from a stop?
  6. Oct 5, 2020 at 6:21 AM
    #4896
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    when in gearlock mode you must be in S and shift manually.
    Ideally, think of it as a manual without a clutch.
    Vr0ck and HulkSmurf14 like this.
  7. Oct 5, 2020 at 4:12 PM
    #4897
    4firemandan
    SWFL
    I may not fully understand the Q. I guess it depends on what gear you're in?
    It goesto the next gear as soon as the trans is in a "safe" place for that gear.
    So for example, we cant start in 5th.. it would bog and stall...
    It would bog and stall going from 1-5 also...
    If in manual mode and S5... from a stop it will start in 2 (because thats "safe" and do-able but 3 isnt from a stop) and then as soon as it deems it "safe" it will progress asap to the selected gear. It moves to 3 almost immediately, only a few mph.
    I dont know what the actual minimums are. I know that its enough that it feels ok to start from a stop and let it progress through them at the bare minimum "safe" shifts. Its a little less torque obviously.
    Wynnded[QUOTED] likes this.
  8. Oct 5, 2020 at 4:45 PM
    #4898
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Thanks. I think I understand what you're saying.
    I'll work out the details when I get the chance to play with the tune for my truck when it is done.
    4firemandan[QUOTED] likes this.
  9. Oct 6, 2020 at 12:11 PM
    #4899
    art64
    art64 New Member
    OV tune, can you incorporate TC lock up also when you work on my tune? I know you need to troubleshoot it for GL not working. Thank You.
    89663-0CD33
  10. Oct 6, 2020 at 7:27 PM
    #4900
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    @OVTune Mat, is this something we need to be requesting? I assumed this would be built into the gear lock.
    snivilous and Vr0ck like this.
  11. Oct 7, 2020 at 4:18 AM
    #4901
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    This is the one thing I wish we could've had/done from the beginning (and have it evolve as new things were found). Do you want GL? Check this box. Do you want to remove the 4wd low range limits? Check this box.
    That way we know what is/was available and we can custom tailor our tune(s), instead of reading about it and then inundating Mat with more tune revisions. I'm sure that alone has caused many delays in the timeline for tune receipt (besides COVID).
  12. Oct 7, 2020 at 4:39 AM
    #4902
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Has anyone actually built their own tune yet in VF?
  13. Oct 7, 2020 at 7:15 AM
    #4903
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Agreed. A sheet with all the options laid out that you submit would be nice, and perhaps simplify things by saying THIS is what I (Mat) am willing to change. Can we change tons of things? Sure, but to keep matters fast and efficient these are the 12 parameters that are a yes/no option.
  14. Oct 7, 2020 at 10:40 AM
    #4904
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Hey amigo, are these giving you some grief? I can go out to my truck and yell and berate it if you think that will make it more cooperative. :argue:;):D
  15. Oct 7, 2020 at 11:21 AM
    #4905
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    Mat,
    So I went out to test my direct shift tune and ran into some issues. When shifting into A mode it acts very weird. Sometimes it goes to 3 sometimes to 4. Regardless though it will not shift up or down. When trying to start out in first from a stop it seems like it's starting in second. As soon as I toss it into D, it works fine. There was also a hiccup (but only once) where in tow/haul mode it was acting like it was in gear lock. I flashed my "stock" tune that you provided and it's back to normal. Any ideas?
  16. Oct 7, 2020 at 11:40 AM
    #4906
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I've had this happen on a completely stock vehicle but have never been able to reproduce it at will.
  17. Oct 7, 2020 at 11:47 AM
    #4907
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    I was going 45 to 55 after leaving my neighborhood. I was trying everything out to make sure that it worked, and had just finished tow/haul test in D. When I was heading away from the house, I was probably around 45 mph and it shifted over into S and it showed 3. When I gave it gas it accelerated, and when I shifted into 4, nothing happened. I shifted back into D, and then I shifted back into S going around 55. It would still not shift up or down, and beeped at me when I tried to put it into 2nd lol. So I switched back to D, and then turned down a side road and pulled a u-turn. When going up to the stop sign, I shifted in S, and down into 1st and turned right. It was very sluggish, and felt like it was starting in a higher gear. I switched back into D, came home, plugged the laptop, and flashed back to stock.
    It was very strange to be honest.
  18. Oct 7, 2020 at 11:58 AM
    #4908
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Hmmm, that's not what I would expect either, for sure. I would bet that Mat would want logs sent to Zendesk though, that way he would be better able to see what "all the things" are doing in relation to each other at specific points in time. I know that would require you to flash again and more of your time, but any data feedback, versus the relatively intangible subjective "seat or the pants feeling" that he can get, the better he can sort out these crazy TCUs.
    shellshock likes this.
  19. Oct 7, 2020 at 12:13 PM
    #4909
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    I messaged Mat through the email he sent me the files in. I know that some folks like to come here and bash him without telling him on Zendesk, and I didn't want to be accused of that, lol. I'll post back once he replies and/or we figure this out.
  20. Oct 7, 2020 at 12:15 PM
    #4910
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ya, sounds perfect.
  21. Oct 8, 2020 at 4:19 AM
    #4911
    4firemandan
    SWFL
    This sounds like it was in gear lock. Thats what mine does.
    I think the ECM picks the best gear for you when you flip over into S mode based on your speed/load/rpm ... with gear lock then you need to manually shift up/down if you arent in the gear you want.
    Starting off in 2 definitely sounds like gear lock. Were you in S mode? T/H?
    When I was first trying to figure out if it worked for me the best thing I did was scanned (either with the tuner software or a BT OBD2 scanner).. and watched the parameter that shows actual gear. A lot of time when I though it was shifting up/down it was just the converter.
    Also, the beeping at you for 2 was just because you were going too fast for 2nd. Thats a safety from the factory that we will still have.
  22. Oct 8, 2020 at 4:28 AM
    #4912
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    I've had gear lock in the past, and didn't personally see a need for it so I asked for only direct shift. This was not in tow/haul mode.
    art64 likes this.
  23. Oct 8, 2020 at 7:32 PM
    #4913
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    @OVTune
    Might I casually inquire as to the progress of these?
  24. Oct 9, 2020 at 5:23 AM
    #4914
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Will have an update on YWF files as soon as possible.
    For some ECUs gearlock and directshift are just not working, even though everything in the code looks exactly right. If we can't get it resolved soon then we may have no choice but to pull the plug on those features for those ECUs.
    It's really weird because the code is literally identical...
  25. Oct 9, 2020 at 5:43 AM
    #4915
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Copy that, appreciate the information. Thank you.
    HulkSmurf14 likes this.
  26. Oct 9, 2020 at 5:52 AM
    #4916
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    FWIW, after work this afternoon I'm off for the next 8 days if you want to conduct some trial and error/experiments.
  27. Oct 9, 2020 at 6:54 AM
    #4917
    TruckyTruck
    Gary
    Whoa! That’s a bummer...
    what about 0CK06?
  28. Oct 9, 2020 at 7:21 AM
    #4918
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    It is what it is. Guess I'm one of the unlucky ones.
    Thanks for the reply.
  29. Oct 9, 2020 at 10:23 AM
    #4919
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    I'd like to give you guys an update on what we are going to do. Because I honestly don't know why it is not working on certain ECUs.
    1. We are going to make a list of all known ECUs that the features are working without issue.
    2. If your ECU is on this list and you received your features / tunes, great. Your tune is complete and you shouldn't need further updates.
    3 If your ECU is not on this list, but you are waiting for an update, we are going to make any necessary updates to your tune that you need, and then finalize it.
    Then, we will continue testing in the back ground with anyone with an ECU version that the features are not working properly on, to correct it and make it functional.
    After we have verified that, we will prepare new versions of your completed tune with those features.
    I'm not really sure what else to do, the code is literally identical and does not work from one ECU to another. Truly I am trying to figure out why but it just doesn't make sense.
    If you purchased the flash kit specifically for S mode Gear lock or Direct Shift features and it is not functioning on your ECU, please email me and we can discuss testing further on your ECU, compensation, etc.
    We are not giving up, we just don't want to keep some people in limbo. If it currently isn't working on your ECU, lets finish any other things needed and finalize your tune, then revisit the features later.
  30. Oct 9, 2020 at 10:31 AM
    #4920
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Okie dokie. This makes sense and is reasonable in my mind. We'll check out the list when it's released and go from there.
Thread Status:
