VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Sep 28, 2020 at 2:41 PM
    #4801
    lawfarm
    lawfarm New Member
    2018 Tundra SR5 Premium TRD Crewmax
    Ok, @OVTune just tried normal (not tow/haul) S mode. I can select and hold gears, but the TC still doesn’t lock and hold. As soon as you’re on the throttle, it unlocks. Any suggestions? Is there a fix for that? With the TC unlocked, there’s not really a benefit to holding a gear; the transmission builds a ton of heat.
  2. Sep 28, 2020 at 3:34 PM
    #4802
    Cuban11182
    Cuban11182 New Member
    Hope Mills, NC
    2018 Tundra Limited
    Kings w/ adjusters, Icon Rebound with Discover AT3 LT 285/75/R17, Airlift bags, ARB dual compressor, OV Tuning,
    Granted I had the original version of GL (the one that required me to have the Tow/Haul button on), but I know that my TC wouldn't stayed locked. I noticed the same thing, where temps would rise. If we can keep it locked I can see the benefit to having the most amount of torque we can have available for when we need it. Otherwise, I will downshift to save my fluid.
    HulkSmurf14 likes this.
  3. Sep 28, 2020 at 3:38 PM
    #4803
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Not that my confirmation is needed, but same with my tune. The tc has never stayed locked. I was hoping this would be looked into.
  4. Sep 28, 2020 at 3:57 PM
    #4804
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I just thought that GL was supposed to hold the gear, not lock the TC too...I guess I'll watch the video again when I get home...
  5. Sep 28, 2020 at 3:58 PM
    #4805
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    It is, but the question has been asked a ton of times, and I believe the response was that we could. Otherwise GL is just to show higher numbers on the dyno, because it will just increase temps
  6. Sep 28, 2020 at 4:07 PM
    #4806
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I forget a lot of things o_O and simply don't recall reading that. But fwiw, locking the TC wasn't mentioned in the Tundra features video. Ah well :hattip:
  7. Sep 28, 2020 at 4:28 PM
    #4807
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    Just got my truck back from the fuel pump recall. ECU is still 0CP50. No change.
    Ruggybuggy likes this.
  8. Sep 28, 2020 at 5:29 PM
    #4808
    lawfarm
    lawfarm New Member
    Yes, that's why I purchased the tune. Hopefully @OVTune will respond with an update regarding how we can have the TC locked when in S mode. My goal is to lock the TC and hold a gear, to avoid building up heat on hills while towing. If it won't do that, it has no value for me.
  9. Sep 28, 2020 at 5:50 PM
    #4809
    lawfarm
    lawfarm New Member
    I just wanted to quote this and bring it back to the forefront...the thread talks extensively about TC lockup being a feature with gear lock...which is why I purchased the tune. Looking forward to hearing from the vendor on implementing this in my base 87 octane tune!
  10. Sep 28, 2020 at 5:55 PM
    #4810
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I had to use The Way Back Machine for these :thumbsup:
  11. Sep 28, 2020 at 6:28 PM
    #4811
    lawfarm
    lawfarm New Member
    Perfect--thanks! I knew it was in here!
  12. Sep 28, 2020 at 7:36 PM
    #4812
    TruckyTruck
    Gary
    Yes, torque converter lock was a huge selling point. When I had my truck on the dyno, the tq converter stayed locked. But not since then.
    remember all of the times I’ve asked Mat this question and never got an answer... tq converter staying locked should happen
    Oops, I see the previous post from Mat quoted :poking:
    I’ll return to my cave now
    Wynnded[QUOTED] likes this.
  13. Sep 28, 2020 at 7:56 PM
    #4813
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    All of your questions showed up in my search! :rofl:
  14. Sep 28, 2020 at 8:16 PM
    #4814
    TruckyTruck
    Gary
    Haha yes!
  15. Sep 28, 2020 at 9:16 PM
    #4815
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Well if the TC doesn't stay lock I'll be passing on the tune. One of the major reasons I wanted it along with the GL. I pull a TT in the hills and need to keep the heat down.
  16. Sep 28, 2020 at 9:37 PM
    #4816
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Just for the record, my tune (which is about 9 months old) and had the "original" gear lock where you press tow haul in S mode DOES lock the converter. I use it all the time while towing, and it is very noticeable since it can be in 5th unlocked and press tow haul and it drops rpm and locks up, and I can floor it and it'll stay locked up in 5th (or whatever gear). I haven't received an updated tune since then (supercharger things take longer it sounds like) but if the current tune isn't doing it, it's not because it can't be done.
    This thread and the OV hate threads make me feel like I'm the only one that ever got a functioning tune. It has it's quirks, but ultimately it seems to have the features Mat said it would at the time and those features all worked great right out the door. Maybe my truck just lucked out lol. Hopefully you guys get it sorted out.
    shellshock and HulkSmurf14 like this.
  17. Sep 28, 2020 at 9:40 PM
    #4817
    lawfarm
    lawfarm New Member
    I’m sure he’ll get it sorted for all of us. It’s why I bought the tune too, and what it was advertised to do.
  18. Sep 29, 2020 at 4:16 AM
    #4818
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Same here...TC lockout has been working well for over a year. I am more than happy with OVT's tune and looking forward to the update!
    snivilous[QUOTED] and Wynnded like this.
  19. Sep 29, 2020 at 4:41 AM
    #4819
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Fully locking the TC is no problem. The problem is first getting all ECUs working to make it work.
    The only other way is the old method of having it lock when you press Tow button
  20. Sep 29, 2020 at 5:17 AM
    #4820
    lawfarm
    lawfarm New Member
    I’m happy to have either method. How do I get a version that does fully locking TC?
  21. Sep 29, 2020 at 5:47 AM
    #4821
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ah yes, the unpredictability of the various Toyota ECU programming within a vehicle model. I don't tow often enough nor heavy enough to fret about transmission temps, I'm content to give Mat the time to make it work how he's planned.
  22. Sep 29, 2020 at 6:14 AM
    #4822
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Edit ** disregard I see you did on your ticket
    shellshock likes this.
  23. Sep 29, 2020 at 6:53 AM
    #4823
    Sbrakeville
    Sbrakeville Go Hawkeyes
    Scott
    Plano,TX
    2018 Tundra TRD sport
    Where you able see if all the OCN61 files have been sent yet? Still waiting on mine and have check my spam folder and haven't seen anything yet. Order #5063
  24. Sep 29, 2020 at 7:09 AM
    #4824
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    emailing to you now
  25. Sep 29, 2020 at 8:03 AM
    #4825
    Sbrakeville
    Scott
    Plano,TX
    Thanks Matt!
  26. Sep 29, 2020 at 8:50 AM
    #4826
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    @OVTune So is that something we need to specifically ask for? Does it only do full lock up in tow/haul mode? I haven't had a chance to try it with tow/haul on mine, but I know it doesn't stay locked in 5th and 6th in normal/S-mode. #5177
  27. Sep 29, 2020 at 9:06 AM
    #4827
    lawfarm
    lawfarm New Member
    @OVTune does this mean I have a present incoming? :bananadance:
  28. Sep 29, 2020 at 9:54 AM
    #4828
    DanoDavis
    DanoDavis New Member
    Dallas
    2018 White Tundra -5.7 -4x4 -TRD Sport - Leather
    Shell - OV Tune
    So, my tune was just the tune. Somehow it got mixed up I’m assuming, as I have no GL/DS.
    I’ve got an 87 and a 91/93.
    I’m rolling with the 93, and the truck feels SO MUCH better. Not lethargic- responsive, power is there when I need it. Hardly downshifts anymore.
    I drive the same routes weekly- I know how my truck operates. If all I got was this base tune, I’m happy.
    But once I get GL+DS, I’m gonna be stoked.
    I drove my buddy’s truck that has a bullydog tune on it as a comparison, and mine just drives way better. His feels like it’s got a tiny bit more on the upper end, but, it shifts harsh, power and isn’t near as smooth- very pulsy.
    Refined, but responsive- How it should’ve driven from the factory.
    Very happy!
    Looking forward to adding on the other features.
  29. Sep 29, 2020 at 10:16 AM
    #4829
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    Just my opinion here... but maybe it would be easier if Matt got away from doing "tunes" and focused solely on jailbreaking the ECM.
    Sell the VF Tuner package and provide a basic tuning tutorial for users to do it themselves. (like HPT)
    This will keep OV Tune from having to deal will bullshit complaints about individual/personal preference issues.
    Just my two cents.
    pnw.tundra, ArXane and Saltyhero13 like this.
  30. Sep 29, 2020 at 10:20 AM
    #4830
    shellshock
    Iowa
    2019 TRD PRO
    That’s exactly what he’s doing and the move to vF..
    The early adopters still get a tune though.
Thread Status:
