VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Aug 31, 2020 at 12:54 PM
    #4501
    Cuban11182
    Cuban11182 New Member
    Hope Mills, NC
    2018 Tundra Limited
    Kings w/ adjusters, Icon Rebound with Discover AT3 LT 285/75/R17, Airlift bags, ARB dual compressor, OV Tuning,
    That makes sense. With the data you can search the hex file and find areas where that data exists. Then you can use some educated guesses to figure out the map size (but I'd wager it's the same as the 4WD Low) and it's location (s). I always found that there was more than one location for some of the maps and you just had to figure out which one was pertinent.
  2. Aug 31, 2020 at 12:54 PM
    #4502
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    How am I not being honest?
    by asking you for a datalog ??? You are saying it doesn't work, I'm asking for a datalog.
    is "it bogs and struggles" data? Seriously...
    why would you do a datalog. Why would you do ANYTHING to help us finish your tune.. ??
    ArXane and shellshock like this.
  3. Aug 31, 2020 at 12:56 PM
    #4503
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    I search through the code by following the assembly language to ram which corresponds to certain parameters. With logs I can take the value in the log, convert it directly to the value it would be in hex, follow the assembly back and see if it matches to that specific code control.
  4. Aug 31, 2020 at 12:57 PM
    #4504
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Dammit Mat stop editing your forum posts and changing the information. Every time I refresh the screen your posts are different
    The bottom line is you never answered me about 4hi shifting or throttle limits or requesting data logs
    If you had, I would have gotten logs 2 days ago.
    I will get logs next time I go off road.
  5. Aug 31, 2020 at 12:58 PM
    #4505
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    Okay, that's above my paygrade (lol). Thank you for the reply though, I just haven't done that before, so it's a little over my head.
    So what you're saying is "show me your problem in a data log, so I can fix the problem." Placebo problems are difficult to figure out.
    rockmup likes this.
  6. Aug 31, 2020 at 12:59 PM
    #4506
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    You sent it to me on July 27th.
    Literally a few days later we started releasing our Gearlock / Directshift map updates.
    Give me a break....
    Get me datalogs. Do like all of our other customers do and datalog it if you have an issue.
    Just like your two haul issue.
    You expect me to freaking GUESS what is going on?
    (it's not even an issue, you seriously need to read how our first version gearlock works)
  7. Aug 31, 2020 at 12:59 PM
    #4507
    osidepunker
    Alex
    2013 Tundra DC 4x4
    There you go changing your posts again so I have to refresh the screen to see what you're saying
    I never said I wouldn't get you data logs wtf
    Cavalrysr5 likes this.
  8. Aug 31, 2020 at 1:00 PM
    #4508
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Did I say you wouldn't get logs?...
    No more responses to you.
    Need something fixed? datalog it.
    Need something looked at? Datalog it.
    nothing else to say.
  9. Aug 31, 2020 at 1:01 PM
    #4509
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Jeezus man. I am like this close to spending an hour and screen shot every damn email between us and posting the whole thing
    Stop acting like I'm not being cooperative with you. You know damn well I will get you what you need if I KNEW WHAT YOU NEEDED
  10. Aug 31, 2020 at 1:04 PM
    #4510
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Great then, get me a log of 4High being limited, get me some logs of whatever issue you have or may have from your tow haul.
    Just like you don't know what to get us, I cannot work based on guessing either.
    it would be much more productive instead of just continually arguing with eachother here.
    and please, seriously, read how our tow haul gearlock works.
  11. Aug 31, 2020 at 1:06 PM
    #4511
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Placebo problems are very difficult to fix, mainly because sometimes the problem doesn't exist at all.
  12. Aug 31, 2020 at 1:07 PM
    #4512
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    Hence why they're placebos, lol. I'll leave you to it Mat, and look forward to the final release.
  13. Aug 31, 2020 at 1:09 PM
    #4513
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Great. I will get you logs. Thanks for responding to this issue over a month later on the forum instead of by zendesk
    And what is it with you telling me I don't understand gear lock. I know damn well how gear lock works
    But are you telling the class that when you engage tow haul that D doesn't work? That you HAVE to use s mode??
  14. Aug 31, 2020 at 1:11 PM
    #4514
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    You said your truck does not want to downshift when you press the tow haul button.
    Yes, when you press Tow Haul, you have to be in S because it disables downshifting. I can't even count how many times I've said this. Maybe you didn't know, maybe you didn't see the posts. That is why I said PLEASE go read about how it works.
  15. Aug 31, 2020 at 1:14 PM
    #4515
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    If you're referring to gear lock, then my old version of it does that. If I hit tow/haul-ass, my D doesn't work, but rather it works in the gear-lock fashion. If I switch it to S, while tow/haul-ass is still on, then gear-lock is still working.
    Is that what you mean?
  16. Aug 31, 2020 at 1:16 PM
    #4516
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Well that sucks that we lose tow haul mode.
    I tried to find this info on your website. I don't see it under faq. I don't see it under general nor under tuning. I also don't see it under instructions. You also didn't explain it in any of my emails. Where is this information located?
  17. Aug 31, 2020 at 1:17 PM
    #4517
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Yes. D does not shift right when it's engage tow haul mode. Apparently, that's how it's supposed to be. But this is the first I am hearing about it.
    Cuban11182[QUOTED] likes this.
  18. Aug 31, 2020 at 1:18 PM
    #4518
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    You don't "lose" tow haul. you just have to manually shift it.
    page 1 of this thread.
    https://www.ovtuned.com/blogs/news/the-ultimate-5-7l-tundra-tune-map-switching-tow-lock
  19. Aug 31, 2020 at 1:21 PM
    #4519
    osidepunker
    Alex
    2013 Tundra DC 4x4
  20. Aug 31, 2020 at 1:21 PM
    #4520
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    That's the way it is. You can technically do it in HPTuners as well, but I haven't tried it, nor have I flashed HPTuners on the truck yet.
  21. Aug 31, 2020 at 1:22 PM
    #4521
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    it does not contain anything harmful. This is some issue we have with google. Just like our emails.
    it's literally text and pictures.
    But because my blog posts *also* have links to my Amazon server, google flags it as harmful.
    I have no idea how to get around it.
    There is a lot of BS we have to deal with on the side ever since google made *some change* about 3 months ago.
    emails go to spam
    emails get blocked completely,
    our blog posts do this..
    etc.
  22. Aug 31, 2020 at 1:23 PM
    #4522
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I can accept that.
    Does anybody (not directed at you) seriously think I would ask Mat over and over for more than a month to fix this issue if he had just clearly told me it works as designed??? sheesh
  23. Aug 31, 2020 at 1:24 PM
    #4523
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    That's how mine works too, though it's an "old" version from like 9-12 months ago. S mode locks the truck in that gear when tow haul is turned on, otherwise tow haul button shouldn't be used for anything else. S mode is "normal" the rest of the time where it limits the highest gear the truck will be in.
    osidepunker[QUOTED] likes this.
  24. Aug 31, 2020 at 1:40 PM
    #4524
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    Mat, just a question, is it possible to add the throttle sensitivity that we experience in tow/haul to the normal state? IE can I have it with tow haul off, but have the snappiness of tow/haul? For those that want gear lock, this would make them happy ass they are probably used to that.
    This is why I asked for direct shift. I like having tow/haul as an option when I want/need it, but gear-lock kept me from that.
    HulkSmurf14 likes this.
  25. Aug 31, 2020 at 1:49 PM
    #4525
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    I am going to say this sincerely, because I truly don't want to argue.
    Please go look at how you communicate with me. Look at your own posts in this thread, from the beginning.
    When you send me emails, you send them nice, polite.
    When you post here, it's like Dr. Jekyl and Mr. hide.
    I did say to go read how our gearlock function works, several times. If you want me to communicate with you and not argue, then try doing the same on your side. Not this Dr. Jekyl / Mr. Hide.
    By email you communicate pleasantly.
    In this forum "I'm going to hold him accountable. I'm so unhappy. My hard earned money. etc"
    Try to hold yourself accountable for some of it. Our blog post has been up since before you were our customer.
    It's been on page 1 of this thread ... forever.
  26. Aug 31, 2020 at 1:54 PM
    #4526
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I'm always professional in my emails. That's simply good life habits.
    And as far as my conduct on this forum goes, I have been extremely frustrated. I am the customer. If you don't like doing business with me then give me my money back. But as long as you have my money you will have to deal with me speaking my mind. I'm allowed to have my opinions and I am allowed to express them here as long as I follow the rules of the community.
  27. Aug 31, 2020 at 1:56 PM
    #4527
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    I was also confused as to how it worked, but that was my fault and not Mat's. There was one comment that was made by him that came off a little condescending (in my opinion), but it could've just been me being a little bitch. Either way, I can't complain about something that I've purchased if I didn't read the instructions, that's my fault.
  28. Aug 31, 2020 at 1:57 PM
    #4528
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    DanoDavis and osidepunker like this.
  29. Aug 31, 2020 at 1:57 PM
    #4529
    osidepunker
    Alex
    2013 Tundra DC 4x4
    That your opinion.
    It's my opinion that he should have replied to my zendesk email last month and told me that D does not work when tow haul is engaged
  30. Aug 31, 2020 at 1:59 PM
    #4530
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Well it's my opinion that you should at least try to read about things you purchase. This information isn't hidden. it was also on the product page, that you had to go to to click "buy."
    and that's where I once again, end this conversation.
    Have your opinions. Speak your mind. But don't call our product broken because you don't know how it works.
    ArXane likes this.
Thread Status:
