VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Jun 19, 2020 at 8:21 AM
    #3811
    Colorado Calvary
    Colorado Calvary Cavalry blue Tundra
    CO
    2019 TRD Sport
    Boost/ vacuum readings?? They are coming from somewhere....
    Please let me know if I should be posting this in another thread, but I thought the guys here would know best... I really want to figure this out, so if there is a better thread for it, can you help me move it?
    I have been repeatedly told that there is no MAP sensor on the Tundra, however, using both a scanner and the cheap TorquePRO app I am getting vacuum and boost readings from somewhere. The readings are consistent with what I would expect (pics below).
    Is it possible the 2019's (and possibly 18's) have added a MAP sensor? Or are the readings coming from some MAF calculation? Can they be trusted?
    Here is a link to a part number I found from Toyota for a MAP sensor for 2018-2019. On their site it says it fits 4.6L v8 and couldn't confirm on the 5.7. I was pretty sure there was no 2019 4.6L, so this must be the part for the 5.7, right?
    Manifold Absolute Pressure Sensor - 89421-47010
    https://parts.toyota.com/p/Toyota_2019_Tundra-CREW-MAX-SR-5-46L-V8-AT/62971950/8942147010.html
    I also found it on Rock Auto under 5.7L MAP sensor:
    https://www.rockauto.com/en/catalog/toyota,2016
    Below are the readings from my NON-TUNED 2019 with harrop 2650. I know it is running to lean under BOOST after reading this forum and am just waiting on the base tune now from the Tundra tune pack.
    -Idle - >1,000 RPM's - 17-20 in/HG vacuum
    - Driving light load > 2,000 RPM's - 8 in/HG (generally under 10) vacuum
    - Medium acceleration- 2500 - 3500 RPM's (ish) - 2 - 4 PSI Boost
    -Close to WOT- 7 PSI boost
    No pic
    I also took some pictures of the MAP sensor from Rock Auto as well as the diagram from Toyota (trying to point to it with my finger). I looked for the sensor and couldn't find it, looks a little different now due to the supercharger.
    Thanks for your thoughts!!!
  2. Jun 19, 2020 at 8:33 AM
    #3812
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The only thoughts that I have that may be relevant, are that any of my information is based on my experience with my 2011, things get updated and changed. Looking at the pictures, I can say that my MAF sensor does not look like that, I don't think my truck has a MAP sensor anywhere, not that I've noticed. Maybe it's something that's been added to the systems on more recent models. I hope that I haven't been muddying the waters too much.
    I think that this information is related enough to discuss in this thread...I'm okay with it.
  3. Jun 19, 2020 at 8:34 AM
    #3813
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    I’ve been a Toyota tech for 15 years.
    There is no MAP sensor on the 5.7l Tundra engine.
    Only the 4.6l engine has one.
    The ECU has no idea what vacuum or boost there is in the manifold.
    The readings you are seeing are likely approximations done by your app.
    Wynnded likes this.
  4. Jun 19, 2020 at 8:35 AM
    #3814
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    OKAY! Next subject! :rofl:
  5. Jun 19, 2020 at 9:10 AM
    #3815
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Pop your hood and see if you can find that sensor.
    I am 99.99% sure no 5.7L has a MAP
    Toyota has MAP sensors on some of their odd engines like the 2.7L, for emissions stuff
  6. Jun 19, 2020 at 9:21 AM
    #3816
    Colorado Calvary
    CO
    2019 TRD Sport
    Thanks for your help! Do you think I can trust the readings for my purposes, or do I need to order a boost gauge? Is everyone else running boot gauges?
    I was originally going to buy this before I saw the readings on my app, Innovate MTX-D 3851
    https://www.innovatemotorsports.com...light-gauge-kit-p-n-3851.html?category_id=273
    I like the display to the decimal point, but it also says it has a serial port/cable if I ever want to use it for data logging.
    Since were on the subject of gauges, can you also explain about the o2 sensors? The engineer at Harrop told me that the stock ones (at least in the 2018-2019, did not ask about other years) are wide-band sensors and will work for the readings I need, just might take slightly longer for readings since the data has to run through the ECU.
    Is the correct on the new Tundra, or do I need to add an additional o2 gauge also?
    Thanks!
  7. Jun 19, 2020 at 9:25 AM
    #3817
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Pop your hood and see if you can locate that sensor. I'd like to know for sure
    Most toyotas have wide band AFR sensors on the front.
    Thing is they are only scaled to read as rich as 11.88. Below that it is "unknown"
    Toyota actually has their own 4 wire wideband design that uses a control current and voltage reading off that, where stoic is maintaining 0.3 volts blah blah blah etc.. it's widebandish
    HulkSmurf14 likes this.
  8. Jun 19, 2020 at 9:30 AM
    #3818
    Colorado Calvary
    CO
    2019 TRD Sport
    Ill check for the sensor later today when I get back to my truck and update. Sounds like I should probably add a dedicated o2 sensor to be safe.
    BTW, I purchased the VF + cable and the Tundra tune pack. Super excited for that!!
    PeakIT likes this.
  9. Jun 19, 2020 at 3:05 PM
    #3819
    Jbtaco2002
    Jbtaco2002 Almost a Tundra
    San Diego
    nothing cool
    as far as boost, i'm tapped into the nipple on the driver's side of the S/C to my gauge, and i "believe" the readings are accurate. the gauge came with 3 bar sensor. Innovate powersafe PSB-1 boost/wideband. on my build page.Screen Shot 2020-06-19 at 3.04.59 PM.jpg
  10. Jun 22, 2020 at 6:52 AM
    #3820
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    @OVTune, Can I ask if these are going to be sent out some time, or are we just going to skip to the next phase? Thanks!
  11. Jun 22, 2020 at 6:53 AM
    #3821
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    planning this week as I have a few people who must be updated.
    We just got 2.0 out on the tacoma so we are finally clearing our plate
  12. Jun 22, 2020 at 6:55 AM
    #3822
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Delightful!
  13. Jun 22, 2020 at 7:13 AM
    #3823
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I have vFTuner setup on my new laptop, do I use my credits for anything at this point or am I probably as far as I can go until the transition from .p5f files to .vft files?
    shellshock and HulkSmurf14 like this.
  14. Jun 22, 2020 at 7:17 AM
    #3824
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    That's the same port and gauge I use for boost too, I also used a cheapo analog gauge to confirm the boost and it seemed accurate and the wideband matches the trucks O2 sensor readings from the OBD2 readout exactly.
  15. Jun 22, 2020 at 7:41 AM
    #3825
    Dakar650
    Dakar650 New Member
    Shawn
    2019 Cement Limited
    Is anyone using the VF Tuner yet? Was looking at doing the upgrade for my 2019 Tundra.
  16. Jun 22, 2020 at 7:42 AM
    #3826
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    I’m using it on my Tacoma. Tundra is next up
  17. Jun 22, 2020 at 8:01 AM
    #3827
    Cuban11182
    Cuban11182 New Member
    Hope Mills, NC
    2018 Tundra Limited
    Kings w/ adjusters, Icon Rebound with Discover AT3 LT 285/75/R17, Airlift bags, ARB dual compressor, OV Tuning,
    I have the vF Tuner, but apparently I was confused when I ordered it as a brand new ticket, instead of as a current customer with the Tundra tuning. I haven't used any of the credits, and don't plan to unless I'm told otherwise. I realized my goof when I asked Mat if I should just use my current OV Tune file instead of the base one.
  18. Jun 22, 2020 at 8:12 AM
    #3828
    4firemandan
    4firemandan Superduper Member
    SWFL
    2016 Crewmax 4x4, 5.7
    TRD Supercharger, Ported SC inlet, RCF TB, 4.5” intake, WMI, 2.38 pulley, custom tune, DW660 inj, aeromotive fpr, msd boost-a-pump
    This was my biggest question, if the vf tuner can be used to tweak the OVTune for my specific truck... I don't want to have to start over and try to get back to the OV, just want to modify if I need a little more or less fuel, if I want to change shift points, change injectors, etc.
  19. Jun 22, 2020 at 8:14 AM
    #3829
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    From what I've read we will get copies of our tunes so we can turn on gear lock, or turn it off. That's what I've read here (I believe), but I believe someone will let me know if I'm wrong.
  20. Jun 22, 2020 at 8:42 AM
    #3830
    shellshock
    Iowa
    2019 TRD PRO
    yeah you can modify the tune you have, you just need to request it and mat will hook you up.
    Wynnded likes this.
  21. Jun 22, 2020 at 8:55 AM
    #3831
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    How I'm imagining it in my head is that he'll get all the (hundreds of) tunes updated with fixes, patches, etc. Then they'll all need to be rejiggered from their current existence as .p5f files to .vft files that can be manipulated in vFTuner so that we can pretend we know what we're doing, until we realize we don't. :D See, I think I've even convinced myself that what I said makes sense. ;)
    shellshock likes this.
  22. Jun 22, 2020 at 9:07 AM
    #3832
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    This was my mindset as well. Then I got to wondering if I would be able to somehow get a .vft file to toy with in the software in an effort to familiarize myself with it in the interim, as I seem to have some free time at present.
  23. Jun 22, 2020 at 9:18 AM
    #3833
    Dakar650
    Dakar650 New Member
    Shawn
    2019 Cement Limited
    I'm just wondering since I dont have any tune on my truck if I am going to be able to do anything with it. I'm just looking to refine it and leave it alone with no knowledge of what I'm doing!
  24. Jun 22, 2020 at 9:22 AM
    #3834
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I guess that you could just wait to see how you feel about the base tune that you'll get first, then worry about what comes next.
  25. Jun 22, 2020 at 9:53 AM
    #3835
    Seuqoia11
    Seuqoia11 New Member
    @OVTune URGENT cant you check your ZenDesk Email. I got the drive and got you the files you needed but need verification before I leave my shop for a job. Thanks!!!!
  26. Jun 22, 2020 at 10:39 AM
    #3836
    shellshock
    Iowa
    2019 TRD PRO
    hes working on making tutorials and stuff so people can learn how to do everything. most people just want to do fairly simple stuff
  27. Jun 22, 2020 at 11:53 AM
    #3837
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Anyone with a 2019 tune their truck yet?
    MR TRD PRO likes this.
  28. Jun 22, 2020 at 2:37 PM
    #3838
    Colorado Calvary
    CO
    2019 TRD Sport
    @OVTune Hey guys. I have tried to download the data logger and the VF program and my Norton keeps marking it is a virus and blocking it. I haven't had this happen with any other programs so I just wanted to see if anyone else has had this. I just want to make sure I am 100 % good before overriding Norton. Is this usual? Here are the logs from Norton. Thanks!
    VF Tuner main program download:
    Filename: vFFlashTool.exe
    Threat name: Heur.AdvML.BFull Path: C:\vF Tuner\vF Tuner\vFFlashTool.exe
    _________________________
    On computers as of
    6/22/2020 at 3:32:02 PM
    Last Used
    Startup Item
    No
    Launched
    No
    Threat type: Heuristic Virus. Detection of a threat based on malware heuristics.
    vFFlashTool.exe Threat name: Heur.AdvML.B
    Locate
    Few Users
    Fewer than 50 users in the Norton Community have used this file.
    Mature
    This file was released 2 months ago.
    High
    This file risk is high.
    __________________________
    Source: External Media
    File Actions
    File: C:\vF Tuner\vF Tuner\ vFFlashTool.exe Blocked
    ____________________________
    File Thumbprint - SHA:
    Not available
    File Thumbprint - MD5:
    Not available
    VF Tuner Datalogger:
    Filename: OVTuned_DataLogger_Installer_1.3.0_x86.exe
    Threat name: WS.Reputation.1
    On computers as of
    6/22/2020 at 3:16:17 PM
    Last Used
    6/22/2020 at 3:18:22 PM
    Startup Item
    No
    Launched
    No
    Threat type: Insight Network Threat. There are many indications that this file is untrustworthy and therefore not safe
    OVTuned_DataLogger_Installer_1.3.0_x86.exe Threat name: WS.Reputation.1
    Locate
    Few Users
    Mature
    This file was released 5 months ago.
    Medium
    This file risk is medium.
    https://ovtune.s3.us-east-2.amazonaws.com/installers/OVTuned_DataLogger_Installer_1.3.0_x86.exe
    Downloaded File from amazonaws.com
    File Actions
    File: OVTuned_DataLogger_Installer_1.3.0_x86.exe Removed
    6488ff8ee55f5039ee7e7656bb4ab380be7119f4475176dfabc56569b192de2b
    71941471c7536a2899e827c968058f8c
  29. Jun 22, 2020 at 2:55 PM
    #3839
    shellshock
    Iowa
    2019 TRD PRO
    Yeah you are totally fine. Some AV flags the software protection thats used in the tuning software
  30. Jun 22, 2020 at 2:56 PM
    #3840
    Colorado Calvary
    CO
    2019 TRD Sport
    Thanks!!
Thread Status:
