VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Jun 7, 2020 at 6:52 PM
    #3751
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    At ones where they don't sell 93 because it isn't worth the bother. :rofl:
  2. Jun 7, 2020 at 7:16 PM
    #3752
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    There are several complicated formulas. Air density at higher altitude is less. also temperature changes it. static pressure Vs boosted pressure boosted is more forgiving, but pressurizing causes heat.
    Imagine a sea level 6 lb boost turbo system puts out 4 lbs at 4000 feet but thats only part if it because the volume stayed the same At altitude. Google it and get lost in a rabbit hole.
  3. Jun 7, 2020 at 8:04 PM
    #3753
    Ericsopa
    Ericsopa Old man and the sea
    Basically, as PeakIT said, there are lots of factors that determine the density of the air, but basically, at higher altitudes the normally aspirated engine can handle lower octanes because the thinner the air, the slower the travel of the flame path in the combustion chamber. Because of all the complexities of air pressure, humidity, density altitude, and on and on, this is why your engines have knock sensors, O2 sensors, IATs, MAFs, etc. They send all the factors to the ECU and the ECU calculates the ignition timing, valve timing, injection timing and duration, etc. based on the inputs. They do all the work, so you don't have to. :rofl:
    EDIT....I'll add one more thing to answer your question. You are safe to use 91 octane at ANY altitude with a 93 octane tune. What will happen, is that your engine will produce slightly less power, because if needed, the ECU will compensate by slightly detuning the engine with things such as retarding timing or enriching the mixture, because the knock sensor detects some detonation. There are limits to how much the ECU can compensate for lower octanes, but I'm pretty sure you won't ever have a problem driving from Texas into and through the Rockies with 91 octane. Don't put any diesel in your Tundra, because the octane numbers for diesel really really suck!! :D
    TruckyTruck[QUOTED] and PeakIT like this.
  4. Jun 7, 2020 at 9:02 PM
    #3754
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    My answer was easier to type on a phone. :burp:;)
  5. Jun 9, 2020 at 10:07 AM
    #3755
    4firemandan
    4firemandan Superduper Member
    SWFL
    2016 Crewmax 4x4, 5.7
    TRD Supercharger, Ported SC inlet, RCF TB, 4.5” intake, WMI, 2.38 pulley, custom tune, DW660 inj, aeromotive fpr, msd boost-a-pump
    Anyone getting hard 2-3 shifts with OV?
    My 15 SC felt amazing but this truck (16 FFV SC) on the initial OV will have pretty ugly hash banging into 3rd under light to moderate throttle. Sometimes it almost feels like a slip, others just feels like a hard (increased pressure) shift.. then about 50% of the time its kind of ok feeling.
    Kinda hard to figure out the exact circumstances. I HAVE noticed that in S mode and in D or S with tow/haul I dont see it. Only Drive, non-tow.
  6. Jun 9, 2020 at 10:28 AM
    #3756
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The only two things that come to mind for me are to try to get a log of the occurrence, and to make sure that the transmission fluid level is correct.
  7. Jun 9, 2020 at 10:41 AM
    #3757
    4firemandan
    SWFL
    Yeah. Im waiting on an email reply (zendesk) from them. Sent him logs about a week ago. After we get the update onboard ill scan and drive some more and try yo get an exact scan using whatever parameters he needs.
    Just curious if anyone else experienced this. I remember hearing about BD SC FFV tune having a harsh 2-3 shift so I was wondering if its a truck/year issue.
    Wynnded likes this.
  8. Jun 9, 2020 at 11:23 AM
    #3758
    MrMax
    MrMax Introvertigo Eximious Geargasm
    Rob
    Eastern Iowa, USA
    2011 Crewmax S/C TRD Rock Warrior
    My 2011 with the BD SC FFV tune had 2-3 shift issues. It would run the gear out too long and sort of lazily slip/shift up to 3rd. It was usually only an issue after first start up and mostly went away once warmed up. It was more pronounced when I was towing. I drove that tune for a couple of years until I got OVTuned over a year ago. Sadly I just sort of learned to drive around the shortcomings using throttle pressure
    Wynnded likes this.
  9. Jun 9, 2020 at 12:42 PM
    #3759
    4firemandan
    SWFL
    Very interesting. Mine seems worse when cold too.
  10. Jun 11, 2020 at 6:26 PM
    #3760
    4firemandan
    SWFL
    @OVTune
    Hey Matt,
    I just got my wideband in today and it's definitely very lean. At a pretty hard throttle (maybe 75%) I'm into boost at 5psi and still 14:1AFR for a solid 3 to 4 sec before it drops down to around 13s. I let off and really haven't going too "full throttle" afraid to hurt something.
    I sent you some logs like you asked via email June 3rd... #5357
    I wanted to send you another email but I think you said once that it kicks it back to the bottom.. so Im hoping you'd see this here.
    HulkSmurf14 likes this.
  11. Jun 11, 2020 at 7:28 PM
    #3761
    Colorado Calvary
    Colorado Calvary Cavalry blue Tundra
    CO
    2019 TRD Sport
    Is 14.1 too lean in those conditions?
    What AFR should I be at with 90% throttle and say 7 PSI boost?
    I always thought under 14.7 was ok
  12. Jun 11, 2020 at 9:02 PM
    #3762
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    You would want below 12:1 on a boosted Tundra under full load
    Toyotoholic, DR132 and Wynnded like this.
  13. Jun 11, 2020 at 9:36 PM
    #3763
    DR132
    DR132 New Member
    ALASKA
    2014 Tundra CM Platinum Blue Ribbon Metallic
    AWD Conversion, BAMuffler 8", Custom tuned with HPTuners, 2018+ LED Headlights, TRD front and rear sway bars
    I generally shoot for 11.6-11.8 under load in boosted applications as a "safe" ballpark on pump gas.
  14. Jun 11, 2020 at 10:15 PM
    #3764
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Just don't floor it, as long as it isn't pinging you're 100% fine. You could run on 85 octane totally fine for 90% of the time I bet. I've run 85 octane and have a 93 octane tune with a blower. Carrying fancy concentrates or race gas is a waste of money imo, just be smart and don't go crazy if you can't find high octane.
  15. Jun 11, 2020 at 10:33 PM
    #3765
    Colorado Calvary
    CO
    2019 TRD Sport
    What AFR are you at under normal loads and say around 3 PSI boost?
    I just installed a harrop 2650 on my 2019 , but I'm not running any tune as it has not been available. Running 91 octane as that is the best we have here in most of Colorado, no pinging or other issues as far as I can tell.
    With high quality Shell gas my timing Advance is about 12 degrees at idle, up to 35 degrees under load, which is only a couple degrees higher than it was stock.
    Under full load I think the richest I get is about 12.5:1. But a lot of the time I am in the 13s even up to 5 PSI or so.
    I'm seeing about the same numbers as stock which I thought was a good thing, so honestly I was pretty happy that I didn't have to be in a rush to tune it as I've read up multiple things about hard shifting and other issues while the tune is getting worked out that I just don't want to deal with right now when everything seems to be running great.
    Should I be worried that I'm not necessarily running richer than stock for the time being? What damage can be done if I keep running it like that? Harrop engineering and the shop that installed it told me that I should be very happy if I'm running the same as stock numbers with a supercharger installed. Maybe not though?
    Thanks for the help! Never supercharged a Tundra before
  16. Jun 15, 2020 at 5:41 AM
    #3766
    Seuqoia11
    Seuqoia11 New Member
    @OVTune I have not received the hard drive or any response to my emails I don’t think your zen desk is getting my messages? Order 5221
  17. Jun 15, 2020 at 5:59 AM
    #3767
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    When will you be able to actually buy everything for the 2019''s ?
    Well, the sites been updated but not seeing the tundra tune pack.
    MR TRD PRO likes this.
  18. Jun 15, 2020 at 7:49 AM
    #3768
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    tracking info I emailed to you
    everything for 19 is available
  19. Jun 15, 2020 at 7:53 AM
    #3769
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    @OVTune, Sorry to badger, I was just wondering if you've been able to find any time to ponder sending out the remaining tunes that were hinted at from a week or so ago? (#4706) Thanks man.
    TruckyTruck likes this.
  20. Jun 15, 2020 at 8:00 AM
    #3770
    4firemandan
    SWFL
    Matt,
    Also sorry to badger but any update on 5357?
    I sent another zendesk, very concerned with the AFR.
    My old SC15 was into the 12s at any kind of boost and this 16SC is 14s well into 4/5psi... Eventually hitting 11.5 or so well into WOT.
    I flashed the SC912 file you sent, confirmed that today.
  21. Jun 15, 2020 at 8:21 AM
    #3771
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    I don't see the 2019 tune pack. I seen the vf software and flash combo. I want a starting point on tune and features and thought it was a separate item.
    Nevermind, I looked in the 2018 pack and seen it is for 2019 also. Thanks!! Will be ordering ASAP.
    4Running Daily and Wynnded like this.
  22. Jun 15, 2020 at 8:45 AM
    #3772
    Seuqoia11
    Got the email thanks!
    Wynnded likes this.
  23. Jun 15, 2020 at 10:16 AM
    #3773
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Will get back to you asap, this is an easy fix, just changing the throttle angle requirement for enrichment to start.
    FYI, for anyone with a 18, 19, or 2020 (as harrop is even offering "no tune" 2020s.........) you will get no enrichment at all until after 70% throttle, so you can be full boost all day and 14.7 AFR
    which is waht you are seeing, except your throttle % is not that high.
    Wynnded likes this.
  24. Jun 15, 2020 at 10:17 AM
    #3774
    Colorado Calvary
    CO
    2019 TRD Sport
    Any help with this?
    Should I be worried about damage at 12.5 - 13 AFR under full boost?
    Thanks!!
  25. Jun 15, 2020 at 10:19 AM
    #3775
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Being in Colorado you can likely get away with it. That high elevation reduces atmos pressure by almost 3 psi, and overall 20-25% less total power output. So your cylinder pressures are way down compared to that of sea level.
    But at sea level it is a recipe for failure (eventually). Especially if you were creating excess heat like towing in boost.
  26. Jun 15, 2020 at 10:20 AM
    #3776
    ViktorG
    Viktor
    Calgary, Canada
    Yes, you should be worried, especially on stock bottom end. Also, you said timing is at 35 degrees under boost - that’s crazy advanced!
  27. Jun 15, 2020 at 10:21 AM
    #3777
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    32 degrees under full throttle? there is no way, it would have already blown up
  28. Jun 15, 2020 at 10:23 AM
    #3778
    ViktorG
    Viktor
    Calgary, Canada
    That’s what he said in post 3770
  29. Jun 15, 2020 at 10:25 AM
    #3779
    Colorado Calvary
    CO
    2019 TRD Sport
    Thanks man. When I am ready for a tune, where do I go to purchase it and how to get started?
    I do think I should tune it now that it is available for the 2019's, I am just worried about mak
    Sorry for confusion, I said under load but I meant under very light load. Like when coasting at 2K RPMS. Last I remember seeing I was close to 15 degrees when I was at like 5 PSI boost. Does that sound normal?
  30. Jun 15, 2020 at 10:28 AM
    #3780
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    okay that makes more sense. 32 degrees at full boost and pump gas would likely kill this engine from detonation even if your fuel was *perfect*
    yes 2019 full support is ready and we have cables
Thread Status:
