VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Mar 18, 2020 at 1:11 PM
    #3031
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It may not be settled as yet what Map 2 actually is. It may or may not necessarily be a different octane, it may be more of a mileage map. It may be something that you could request. In your case Mat may make it a different octane by default because that's what you have already. Someone else, like me for example, it would be the same octane as my primary tune due to that being the min required/max octane available in my region of the country, but it may have expanded VVT tuning by default or something I request that's more applicable to towing, like what I would expect @MrMax to request.
    MrMax, TruckyTruck[QUOTED] and Vr0ck like this.
  2. Mar 18, 2020 at 3:28 PM
    #3032
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    Matt, will there be a tune for the 19 and 20 model years soon???
  3. Mar 19, 2020 at 7:33 AM
    #3033
    coTony
    Tony
    Montrose, CO
    I did the tune because I was told I could get 2 tunes for different octanes and that is still what I want. Hopefully the dust settles soon
    Midway likes this.
  4. Mar 19, 2020 at 8:27 AM
    #3034
    Jbtaco2002
    Jbtaco2002 Almost a Tundra
    San Diego
    nothing cool
    this was always my thought as well, because i wanted to switch between 91 octane tune (tow/haul off) to a 93 octane tune (tow/haul on) and both tunes with gear lock in S-mode.
    i don't see how that is confusing, until people start request configurations that are outside of that box i guess
    Wynnded[QUOTED] likes this.
  5. Mar 19, 2020 at 8:32 AM
    #3035
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Agreed. I think that once we have the chance to experiment with how the tunes work, it will become just about second nature, not unlike knowing where other vehicle controls and switches are, what they do and how they operate.
  6. Mar 19, 2020 at 12:15 PM
    #3036
    coTony
    Tony
    Montrose, CO
    Been driving with the Tow/Haul option for my tune for 10 months now, yep I am used to it
  7. Mar 19, 2020 at 1:00 PM
    #3037
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    @OVTune just wanted to touch base. Ive put in a few emails over the past month asking for updates, haven't heard back at all. Can you just shoot me a msg and let me know what's going on with my situation. thanks
    Order #5255
  8. Mar 19, 2020 at 1:46 PM
    #3038
    MrMax
    MrMax Introvertigo Eximious Geargasm
    Rob
    Eastern Iowa, USA
    2011 Crewmax S/C TRD Rock Warrior
    Yes...Tune(Map2) for me is simply a towing oriented tune. Both Tune's(Map's) are 91 octane tunes. I'm not sure what all the confusion is, because if you have a second tune you must have requested it. Be it a different octane, towing oriented, etc. If you did not specifically request this I imagine you are simply running one primary tune normally and the same primary tune when tow/haul is activated.
    Also I think there may be some confusion regarding gear locking feature. It does and will work with either tune(if you have two). However if you want the Torque Converter to lock up as well you need to use tow/haul activated.I think the confusion stems from guys that have two tunes(maps) and want to be able to lock up the torque converter using the primary tune(Tow/haul off). That is not possible as it was described.
  9. Mar 19, 2020 at 1:54 PM
    #3039
    MrMax
    Rob
    Eastern Iowa, USA
    Quoting and re posting to add clarity to my previous post...If you have two tunes you can not run tune1(Map1) and get the Torque Converter fully locked feature.
  10. Mar 19, 2020 at 1:55 PM
    #3040
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Here is the problem. You move into S mode, your gears are locked and you decide you want your torque converter locked also. So you press the tow haul button. What happens? Well the way I read, your torque converter locks, but you also switch into a different octane map. (If you requested a second octane map)
    If I'm wrong about that, great. But the way Mat has explained it, this is what will happen. I wouldn't want my map changing when all I want to do is lock the torque converter...
  11. Mar 19, 2020 at 2:01 PM
    #3041
    MrMax
    Rob
    Eastern Iowa, USA
    Trucky...I'm assuming you have two tunes(maps) if 93 octane is your primary tune at start up it will not lock up the torque converter using gear lock. Torque converter is only going to lock up in your tune/map2 when tow haul is activated and you move the shifter to S mode.
  12. Mar 19, 2020 at 2:04 PM
    #3042
    MrMax
    Rob
    Eastern Iowa, USA
    Again...the only time you will be able to lock up the torque converter is while using your tune/map2(tow/haul activated) and in S mode.
  13. Mar 19, 2020 at 2:05 PM
    #3043
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    we have an option for 2019s, but it's pricey.
    2020 is still in testing.
    I plan to get back to a lot of people this weekend. We have wrapped up a lot and ready to start pushing out updates.
    But at the same time please be aware shipping and other things can / will be delayed due to Coronavirus things.
    Yea so it seems like you guys are still confused about map switching????
  14. Mar 19, 2020 at 2:06 PM
    #3044
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Your tune still has map switching so no worries there.
  15. Mar 19, 2020 at 2:08 PM
    #3045
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    We have it ready to go on all ECUs. Just waiting to release at the right time.
    4firemandan[QUOTED] likes this.
  16. Mar 19, 2020 at 2:12 PM
    #3046
    MrMax
    Rob
    Eastern Iowa, USA
    I think the only confusion is from the guys who have two different octane tunes and want to be able to use the gear lock/Torque converter lock with their primary tune
    Wynnded likes this.
  17. Mar 19, 2020 at 2:14 PM
    #3047
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Some of us are stubborn and think we have a handle on it. ;) Send it buddy. Naw, when you're ready.
    MrMax likes this.
  18. Mar 19, 2020 at 2:16 PM
    #3048
    MrMax
    Rob
    Eastern Iowa, USA
    I second this sentiment... :)
  19. Mar 19, 2020 at 2:19 PM
    #3049
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Too much time on my hands.....:rolleyes:
  20. Mar 19, 2020 at 2:55 PM
    #3050
    TruckyTruck
    Gary
    Yes I fully understand that the only time you can lock the torque converter is while you are in S mode AND press the tow haul button.
    Assuming you have 2 different octane maps in your tune:
    Mat says the octane map is assigned to the tow haul button and regardless of being in s or d mode, pressing this WILL activate the second octane map.
    My whole point is, in S mode, if you press the tow haul button, you will not only lock your tc, you will be in a different octane map.
  21. Mar 19, 2020 at 3:11 PM
    #3051
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The only resolution that I see here is that you'd need to either be very, very careful about High Gear/Low RPM predetonation, or not operate in S-Mode + Tow/Haul when there's inadequate octane in the tank.
    MrMax and TruckyTruck[QUOTED] like this.
  22. Mar 20, 2020 at 7:16 AM
    #3052
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Shipping, i don't have that issue, I need my updated tune and updates with the stuff I requested. My biggest concern is you are actually getting my emails, ive sent a few with tracking and none have been opened lately.
  23. Mar 20, 2020 at 9:01 AM
    #3053
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    I see all of them. and even looked at them again yesterday. Maybe your email tracker isn't working, or doesn't work with Zendesk?
    Also patches are done for most ECUs. You guys will be getting emails this weekend.
    Anyone awaiting a base file / tune file etc as well.
  24. Mar 20, 2020 at 9:35 AM
    #3054
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    What is the option for 2019-2020?
  25. Mar 20, 2020 at 9:38 AM
    #3055
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Xmas in March!!!
    woot!
  26. Mar 20, 2020 at 9:45 AM
    #3056
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Awesome! thanks thats probably a possibility so thanks for the update. I know you are slammed, just making sure i didnt fall off the radar :)
  27. Mar 20, 2020 at 9:48 AM
    #3057
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    Pretty sure read receipts etc don't work with zendesk.
  28. Mar 20, 2020 at 10:03 AM
    #3058
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    That would explain
  29. Mar 20, 2020 at 10:13 AM
    #3059
    TruckyTruck
    Gary
    Oh cool! That's fun.
    Mat, could you confirm that I have this correct:
    If the above is correct, it doesn't sound like having a second octane map is a good idea and a guy should probably just have the tow haul button optimized for towing on a single octane map.
    Do I have this right?
    Ericsopa, Cuban11182 and Wynnded like this.
  30. Mar 20, 2020 at 11:45 AM
    #3060
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    This is how I want mine. Tow haul button for towing. I'll run a 91 tune and data log it and get revisions.
    But I will also have a 87 base tune in case Im in the sticks and cant find 91. I'll just flash the base tune real quick and keep driving.
    I bought a cheap 12" laptop that I keep in the truck specifically for OVTune and Techstream use
    2Tall, MrMax, Ericsopa and 1 other person like this.
Thread Status:
