Very light, jumpy steering off-road in 2HI
Discussion in '2.5 Gen Tundras (2014-2021)' started by wiretwister, Jun 1, 2020.
  1. Jun 1, 2020 at 7:54 AM
    wiretwister
    wiretwister [OP] Sorta new guy
    NJ
    '22 SR5 CM
    Does/should the steering feel different off-road being in 2wd vs 4wd?...
    I took the tundra out on some unmaintained double track roads yesterday for the first time. Nothing that required 4wd, so I was in 2hi the whole time. I noticed that, especially while climbing, the truck's steering felt very light, jumpy and experienced a ton of jittery bump steer. As if the steering wheel was following every little imperfection in the trail.
    This is my only truck so far, so my experience with a true full-size 4wd is minimal. My last vehicles have been Subaru Foresters which I took on similar trails including some much harder stuff quite often and never experienced a steering feel like that.
    Does this sound normal? Am I overthinking it?
    Would being in 4hi/4lo lessen this as there would be power going to those wheels and this 'tightening/damping' the steering rack?
  2. Jun 1, 2020 at 7:58 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 70mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    Normal, for the reasons you describe, i.e. power to the front drivetrain a.k.a. torque-steer.
  3. Jun 1, 2020 at 8:00 AM
    wiretwister
    NJ
    '22 SR5 CM
    But there wasn't power going to the front wheels. Torque-steer and bump-steer are two completely different things.
  4. Jun 1, 2020 at 8:13 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    299.9k Supercharged 2008
    Yes it'll feel different. The front end putting power down and grabbing things will make it feel stiffer versus in 2WD where it's just pushing and sliding around.
  5. Jun 1, 2020 at 9:54 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Yep, that's why it felt lighter and was more prone to bump-steer, there wasn't power to front end. You're thinking is sound.
  6. Jun 2, 2020 at 3:22 AM
    StoneyWV
    StoneyWV New Member
    Calvin
    2020 Tundra TRD Sport
    Rough Country Level,
    He is saying that in 2WD the truck feels like there is too much slop in the steering when in small bumps like number 2 stone. Mine feels exact same way; my 2017 4 Runner was way tighter feeling. I am considering placing a steering stabilizer on the truck if I ever end up living in an area where I'm in that type of terrain every weekend.
  7. Jun 2, 2020 at 8:11 AM
    wiretwister
    NJ
    '22 SR5 CM
    Yeahhhh.... Don't do that. You're pissing in the wind putting a damping/stabilizer bar on power rack and pinion steering. All it would do is fight the system.
    Wynnded likes this.
  8. Jun 2, 2020 at 10:25 AM
    StoneyWV
    StoneyWV New Member
    Calvin
    Good to know, thanks
  9. Jun 3, 2020 at 9:04 PM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    Mine does this too. I have a 3” king lift and SPC upper arms. Do you have a Lift?
  10. Jun 3, 2020 at 10:04 PM
    wiretwister
    NJ
    '22 SR5 CM
    Bilstein 6100/5160 with shims up front and shackles in the rear. Makes for roughly a 3/1" lift.
  11. Jun 4, 2020 at 6:12 AM
    StoneyWV
    StoneyWV New Member
    Calvin
    I have Rough Country level block that are 1.75 up front. Didn't try it without the front lift so not sure if this is making it worse or not.
  12. Sep 13, 2020 at 4:25 AM
    wiretwister
    NJ
    '22 SR5 CM
    Revisiting this...
    So I was on similar, unmaintained farm roads yesterday and decided to put it in 4hi. Same exact sensation.
    Can anyone else chime in? This is really disconcerting to me. The truck is brand new (5k miles). Is this possibly an alignment issue? Tire pressure? Something actually loose in the front end from the lift installation?
    The truck feels absolutely fine on the road. What am I missing here?
