Valvoline Zerex Red Asian Vehicle Coolant
Discussion in 'General Tundra Discussion' started by Scuba, Oct 30, 2019.
  1. Oct 30, 2019 at 10:46 PM
    Scuba
    Scuba [OP] Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Anyone use it?
    I found this at the parts store a while back after I bought my 1997 Camry.
    https://www.valvoline.com/our-products/antifreeze-products/zerex-asian-vehicle-antifreeze-coolant
    I’ve never seen it before and actually haven’t ever bought coolant other than Toyota Red/ Pink from a dealer. This can be a bit inconvenient.
    From what I remember reading years back: Toyota vehicles that come with red/ pink coolant should not be switched/ topped off with standard green coolant without a complete flush of the system. Doing so can/ will cause the coolant to degrade and crystallize causing blockages and damage to your cooling system.
  2. Oct 30, 2019 at 11:38 PM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    I've been using it for years. It's formulated to meet all the requirements for Toyotas. I use the Zerex blue for my G35 coupe.
    BubbaW and Black Wolf like this.
  3. Oct 31, 2019 at 12:31 AM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    I also used it in my solara.
  4. Oct 31, 2019 at 3:25 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    2nd that and have had no issues over the years on our 2004/2017 Highlander or 2004 Tundra.
    BestGen[QUOTED] likes this.
  5. Oct 31, 2019 at 3:54 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Why are you asking about green coolant, that link doesn't reference green coolant anywhere that I can see.
  6. Oct 31, 2019 at 4:17 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I recall there's 2 labels but the same Zerex. Walmart and any other auto parts store.
    There's more Walmart than Toyota dealers by me. $12.xx a jug. Only inconvenience is having to walk thru Walmart.
    I just used 3 gallons 2 mos ago flushing my 08. And I use it on any of the other Toyota's that come into my garage.
    revtune, HbbTundra08 and Wynnded like this.
  7. Oct 31, 2019 at 4:59 AM
    Professional Hand Model
    Hand Protectors
    Just put 3 gallons in the 2002 Tundra a few months back. IIRC, it ticks all the spec boxes required for Toy/Japanese cars. Phosphate is the key to offset the corrosion process caused by dissimilar metals sharing the coolant tunnels.
    Wynnded likes this.
  8. Oct 31, 2019 at 5:05 AM
    Been using Zerex for 5 years now. Perfect OEM substitute.
    BestGen and Wynnded like this.
  9. Oct 31, 2019 at 5:22 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Definitely shouldn't mix the two colors. I haven't tried mixing them, so I can't relate the consequences, but it can't be good...the two colors represent entirely different antifreeze chemistries. See the chart in the link below:
    https://www.valvoline.com/our-products/antifreeze-products/antifreeze-education/engine-coolant
    Wynnded likes this.
  10. Oct 31, 2019 at 5:34 AM
    minter66
    minter66 2007 TSS CrewMax
    Used it in my 2007 when I replaced the water pump and I plan on putting it into my 2014 tC (2.5L Camry Engine) whenever I can get the engine block replaced.
    revtune likes this.
  11. Oct 31, 2019 at 5:51 AM
    Hand Protectors
    Remember to flush out the heater core separately as it holds about 1/4 to 1/2 gallon of fluid that doesn’t drain and needs gravity/pressure to force out its contents. Put on a new rad cap every 5 years. Cheap insurance.
    YardBird and FirstGenVol like this.
  12. Oct 31, 2019 at 6:02 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I use this. When I bought my Sequoia used, I drained the radiator and refilled with Zerex. It was cheap and convenient as Advance auto parts has them and stack them with online coupon 25% off. Order online, pick up in store. Stack with online shopping cash back sites or credit card offers and save even more.
    Black Wolf likes this.
  13. Oct 31, 2019 at 6:53 AM
    Scuba
    Austin, Tx.
    I only had one question in my post and it was:
    It was in reference to the product that is mentioned in the title and in the link.
    I was reminding others that green and red aren’t compatible in case they didn’t know.
    YardBird and Black Wolf like this.
  14. Oct 31, 2019 at 6:55 AM
    I used the Advance Auto 25% off too. Used it to save $50 off my Red Top battery. Best discount you can get.
    omgboost[QUOTED] and Jrharvey02 like this.
  15. Oct 31, 2019 at 7:18 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I would have no issues using this.
  16. Oct 31, 2019 at 7:36 AM
    Scuba
    Austin, Tx.
    Thanks.
    I’m going to need to refill my Tacoma when I put it back together. It’s looking like I’ll use it.
    I put it in the Camry a couple months ago but I wanted to get everyone’s feedback before I filled up my baby.
    YardBird likes this.
  17. Oct 31, 2019 at 7:37 AM
    JohnLakeman
    I used the green coolant in an old Toyota (iron block) with no problems. I have not used Zerex Asian coolant yet, but I would have no problem using it since it appears to have the same P-HOAT inhibitor chemistry as Toyota coolant.
    The only coolant I would absolutely never use again in a Toyota would be Dex-cool (orange). It has been reformulated slightly into a great extended life coolant if the vehicle cooling system is compatible with OAT chemistry; e.g. GM vehicles. My experience with a 97 Avalon was that organic acid inhibitors in Dex-cool will attack the sealing elastomers in Toyotas and will cause the drain cocks and other rubber sealed parts to begin leaking. Unless the formulation of Dex-cool has been changed again, or Toyota has re-spec'd the elastomers, this will still be true.
    CmdrDaniels and Black Wolf like this.
  18. Oct 31, 2019 at 7:49 AM
    Scuba
    Austin, Tx.
    And these are the things I wanted others to read by starting this conversation.
    Thanks for posting about your experience with Dex-Cool.
  19. Oct 31, 2019 at 10:15 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I thought that maybe you wanted to continue the green theme of your paint job to the color of your coolant.
  20. Oct 31, 2019 at 3:36 PM
    blizz86
    blizz86 New Member
    Does anyone know pink (new toyota) and red (older toyota) are compatible ?
  21. Oct 31, 2019 at 3:38 PM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    Peak has a concentrated form OET brand for Asian. It's a little harder to find but I think I got it from autozone. Sames money when you just buy a $1 bottle of distilled water. It's a little hard to find and I don't see it advertised
    Edit and yes mine is green. Thought I had a leak and put the fluorescent dye in. It's going to stay green for the next 100K
  22. Oct 31, 2019 at 3:50 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    mve likes this.
  23. Oct 31, 2019 at 4:04 PM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    I worked for Toyota for several years. During a V06 campaign and other head gasket campaigns, I noticed that the majority of the blown head gasket’s were from aftermarket antifreeze that was put in the Toyota vehicle. I highly recommend using Toyota OEM antifreeze.
  24. Oct 31, 2019 at 4:19 PM
    The Zerex is virtually identical to OEM in chemical makeup. Haven't seen one single bad review or issue when used in place of OEM.:thumbsup:
  25. Oct 31, 2019 at 4:52 PM
    BestGen
    BestGen New Member
    Paul
  26. Oct 31, 2019 at 5:19 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Wouldn't surprise me if black gallon containers go down the assembly line and splits 3 ways. At the end of line is a jug each of Zerex, Toyota Super Long Life Cool and Aisin ACT-002 :rolleyes:
    Zebruaj, Black Wolf, YardBird and 2 others like this.
  27. Oct 31, 2019 at 5:25 PM
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    $13 delivered free to your door.
    Zerex 675130 Engine Coolant/Antifreeze, 1. gallons https://www.amazon.com/dp/B0033QO022/ref=cm_sw_r_cp_taa_aT3UDbA25K8AG
  28. Nov 9, 2019 at 2:01 PM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
  29. Nov 9, 2019 at 5:30 PM
    gdisarray
    Looks like it moves a lot. Just set up an ap to catch it at the right time.
  30. Nov 10, 2019 at 5:13 AM
    BestGen
    BestGen New Member
    Paul
    Please let us know when it bottoms out again! :thumbsup: Just checked, currently $15.62
