Valve Cover Bolting
Discussion in '1st Gen Tundras (2000-2006)' started by kbuild, Jun 23, 2018.
  1. Jun 23, 2018 at 1:57 PM
    kbuild
    kbuild [OP] New Member
    Rik
    2006 TUNDRA sr5 6 CYL
    None
    anyone have specs for torque for v6 4liter cover bolts?
  2. Jun 23, 2018 at 2:02 PM
    Professional Hand Model
    Professional Hand Model Fred Brookes
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    No sir. They do need snugging every couple years due to contraction and expansion. I snug mine by feel a little at a time alternating to each bolt in a random zig zag pattern to keep the compression equal.
  3. Jun 23, 2018 at 2:32 PM
    Casper421
    Casper421 Adventure in a 1st gen
    N. Cal
    06 DC
    According to Haynes, they’re 80 in-lbs. around 6-7 ft-lb.
  4. Jun 24, 2018 at 3:11 PM
    kbuild
    Rik
    None
    Thx for quick response. I was guessing at least 55 in-lbs. I'll set them at 80 and keep an eye on them over time.
  5. Jun 26, 2018 at 5:01 PM
    Need to know stuff
    Need to know stuff New Member
    2000 black Tundra TRD
    3 front 2 rear leveling
    Could that be why my valve cover gasket is leaking? Or just a bad seal?
  6. Jun 27, 2018 at 4:25 AM
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    Tighten those bolts up carefully and we shall find out. Probably the gasket is old, but I’ve tightened mine about 3 times in 6 years. First time was because I noticed the leak. Second and third time was prevent maintenance. Believe its 16 bolts 10mm. A couple of bolts it is better to have a longer extension for the socket reach. Or, a short throw 10mm wrench. Just alternate the bolts a little at a time. Some may be looser than others. Let us know how it goes!
