Valley Plate Leak - FIPG sealant failure - coolant leak at heat exchanger
Discussion in '2.5 Gen Tundras (2014-2021)' started by Double DC, Dec 1, 2021.
  1. Aug 28, 2024 at 4:27 PM
    Double DC
    Double DC [OP] New Member
    2005 DC & 2021 DC
    Interested to hear how this can be repaired in the driveway for under $100? From prior post, it took a Toyota tech 8 hours. I saw the extent of engine dismantling to fix my issue. It's a significant undertaking, parts everywhere - sure didn't seem like a driveway job to me. Definitely not a $100 repair. Frankly I was glad to see a couple repair costs around $1k.
  2. Aug 28, 2024 at 4:33 PM
    AZBoatHauler
    So.Arizona
    All it takes is a handful of metric tools and some patience. Nothing difficult about it from everything I’ve seen and read. A tube of FIPG (in my tool box from doing the timing belt on the sequoia) some coolant and intake gaskets are the only materials needed.
    The timing belt on a 2uz is also about 8 hours of time - doesn’t mean you can’t do it in your driveway for the cost of a couple beers.
    Tunrod likes this.
  3. Sep 4, 2024 at 4:44 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Almost certain my 2016 with 107,000 miles is leaking from the valley heat exchanger, but need to do a pressure test for sure. Is the Toyota FIPG sealant being used when repaired ? Wondering since this is not uncommon and if there is a better sealant..
  4. Sep 4, 2024 at 6:09 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    You're hired!
  5. Sep 4, 2024 at 9:12 AM
    AZBoatHauler
    So.Arizona
    There is a better sealant - it’s pricey. Most people just use the Toyota black since it’s $15 instead of $100 but if I ever have to tear into one I’d probably use the expensive.
    https://209yota1.com/products/seal-packing-silicone-liquid-gasket-genuine-for-coolant-1282b/
    Double DC[OP] likes this.
  6. Sep 4, 2024 at 11:05 AM
    agrestic1
    2016 CrewMax
    AZBoatHauler[QUOTED] likes this.
  7. Dec 25, 2024 at 4:50 PM
    kbahus
    kbahus New Member
    MI
    2015 MGM Tundra Limited Crewmax
    Started on this project on my 08 Sequoia with 335k on the clock. Pulled the manifold tonight to find the standard mouse nest and coolant leak in the same spot making a nice slurry of mouse crap. For anyone doing this job, grab a pick and bend it like shown to get the wire harness clips off in short order.
  8. Dec 25, 2024 at 6:00 PM
    Double DC
    2005 DC & 2021 DC
    Wish I had the knowledge and balls to take on an effort of this magnitude. Well done as far as I can tell....so far. Merry Christmas!
    AZBoatHauler likes this.
  9. Dec 27, 2024 at 4:44 PM
    kbahus
    kbahus New Member
    MI
    Finished it up tonight, really it was a DIY job and not that difficult for anyone with experience turning a wrench. I used The Right Stuff for sealant in the the handy quick dispenser bottle, I can assure you that the $100 tube of 1282b is not magical. I also pressure tested the system before putting it back together just in case I messed up. The only "gotcha" moment I had was trying to get the bolts back in the air injection valves, those metals gaskets have little tabs that are razor blades, I sliced my thumb pretty good on one. For those looking at the DIY's for the 460's and other chassis, while similar, the Tundra/Sequoia 3UR is much easier to work on. I would rate this as a 2 banana job all day. Even if you had to buy a bunch of tools you could still save yourself $1000 doing this yourself.
  10. Dec 27, 2024 at 5:05 PM
    AZBoatHauler
    So.Arizona
    :101010:
  11. Feb 10, 2025 at 3:19 AM
    backcountryj
    backcountryj New Member
    GA
    2016 Crewmax
    Looks like I’m the next contestant on the valley coolant leak show. I’m considering doing the repair myself.
    Any chance you could share a parts list breakdown of what’s needed? My truck is a 2016 with 219k on the clock. If there’s any other low hanging fruit you’d suggest I replace while I’m in there, I’m all ears.
    Sorry for the potential newb request. I’ve got roughly 2 months on tundra ownership under my belt.
    Double DC[OP] and hagrid like this.
  12. Feb 12, 2025 at 9:11 AM
    kbahus
    kbahus New Member
    MI
    Sorry, just seeing this. You don't need much:
    Left and Right side intake manifold gaskets Part No.: 17171-0S030, Part No.: 17171-0S010
    2x water pipe o-ring Part No.: 96761-35031
    1 can of Right Stuff Black (not the factory recommended sealant 1282B 08826-00100, but this works well)
    3 gallons Toyota coolant
    Intake Manifold Gasket Set: https://www.rockauto.com/en/moreinfo.php?pk=11464397&cc=3310258&pt=5424&jsn=538
    O-Rings: https://www.rockauto.com/en/moreinfo.php?pk=2172176&cc=0&pt=0&jsn=565
    Right Stuff: https://www.amazon.com/dp/B000HBM4FQ?amp=
  13. Mar 15, 2025 at 10:09 AM
    backcountryj
    GA
    2016 Crewmax
    That water pipe o-ring part number isn’t showing as a match for my truck? Is that correct for the 5.7 flex fuel?
    Is the 7oz can of Right Stuff enough?
    My truck has 220k miles on it. No issues beyond the suspected coolant valley leak. Is there anything else you’d change out/swap while you’re in there doing the reseal?
    96761-35031
    Maybe this guy?
    96761-35035
    kbahus[QUOTED] likes this.
  14. Mar 16, 2025 at 2:10 PM
    kbahus
    kbahus New Member
    MI
    I would absolutely order parts off your specific vin number just to be safe. One can if Right Stuff is plenty.
    backcountryj and AZBoatHauler like this.
  15. Mar 28, 2025 at 6:26 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    What makes you think it's leaking ?
  16. Mar 29, 2025 at 2:16 PM
    backcountryj
    GA
    2016 Crewmax
    All the pink stuff that should only be on the inside but that’s on the outside is a pretty good indication.
  17. Mar 29, 2025 at 6:40 PM
    Vince
    Vince New Member
    Vincent
    Rock and roll
  18. May 20, 2025 at 6:33 PM
    Haulmode
    Haulmode New Member
    2021 CM SR5 Cement
    Bilstein 6112/5160, Falken Wildpeak 285/75r18, Demello Rock Crushers, Tech12Volts Sound, Trans cooler
    My '21 was diagnosed with the valley plate leak today. I bought it in March of 2021, and currently at 51k miles, so within the power train warranty. The service tech didn't think so, however, and strutted out a $2100 quote!! She said warranty coverage was denied (no reason), but she will file a claim on my additional warranty. That warranty doesn't kick in until the manufacturers warranty expires... :thumbsup:
    I called toyota and entered a claim. They didn't get a response from the dealer, but I'm supposed to be getting a call back in the next couple days. This smells like I'm going to be on some long phone calls...
    Anyhow, thanks to this forum, there are plenty of examples where this job is covered by warranty. I've watched a couple videos on this, and feel comfortable doing this job myself, but I shouldn't have to!!!
    AZBoatHauler and Double DC[OP] like this.
  19. May 21, 2025 at 4:25 AM
    #49
    agrestic1
    2016 CrewMax
    Correct you should not have to do this job. Leak at 51,000 miles and being 2021 , warranty for sure...Keep us posted..
  20. May 21, 2025 at 6:14 AM
    #50
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    Mine was covered under warranty. No questions asked. The dealership had my truck for a little over a week and provided a 4Runner as a loaner. No issues since.
    Haulmode[QUOTED] likes this.
  21. May 21, 2025 at 6:38 PM
    #51
    Haulmode
    Haulmode New Member
    2021 CM SR5 Cement
    Dealer called today and said Toyota would not cover under warranty - again, offering no explanation. However, this is covered under my extended warranty I bought through the dealer. They will waive my deductible. I asked for a quote with parts and labor, showing no cost to me, and am supposed to get that tomorrow. I'm wondering if they are reimbursed more for this job through their warranty than what they would get from Toyota?
  22. May 21, 2025 at 9:24 PM
    #52
    AZBoatHauler
    So.Arizona
    Probably. They can eat the deductible and still come out ahead.
  23. May 22, 2025 at 11:59 AM
    #53
    Haulmode
    Haulmode New Member
    2021 CM SR5 Cement
    Confirmed with the dealer, they're doing the job under their extended warranty, and no cost to me. They sent the parts list, and they've got the gaskets, o-rings, and FIPG i expected to see. They also included the valley plate and a complete engine gasket kit... hope they don't go that far! That might have been to justify their initial quote of $2100...
    Thanks again for examples here. :cheers:
  24. May 22, 2025 at 4:11 PM
    #54
    agrestic1
    2016 CrewMax
    The valley plate I can understand, the engine gasket kit is odd. They could be padding the quote to the extended warranty company to come out ahead on this.. It's good that its getting covered..
