Valhalla's Catalytic Converter Shield Installation
Discussion in '2.5 Gen Tundras (2014-2021)' started by Netmonkey, Jun 13, 2021.
  1. Jun 15, 2021 at 7:24 AM
    bwh
    bwh New Member
    No rattles on my install, after I used one set of the spacers. First install was without them (and removing the t-case sheild), but it rattled when sitting in reverse with my foot on the brake. Spacers took this rattle away.
    Second, it was a major challenge to get the bolts tightened for two reasons:
    1) You need skinny arms to reach behind the plates and get a wrench behind the bolts for tightening. Not the easiest. Bring a girlfriend or wife.
    2) The holes in the rear brackets were not fully straight, so I had to spend a fair amount of time removing excess material before they would fit the bolt holes and the little bumps on the frame. Not a knock on the product, more of an FYI for people to check before climbing under the vehicle.
  2. Jun 15, 2021 at 7:47 AM
    Cthulhu
    Thanks, I added what Tyler told me about the WKOR sliders to the first thread you quoted.
    equin likes this.
  3. Jun 15, 2021 at 8:03 AM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Your rear shield has a scratch on it.:itllbuffout:
  4. May 16, 2022 at 7:29 AM
    engineer
    engineer Drive it 4ever
    Seattle, WA
    '21 Limited Double Cab
    thanks for the write-up.
    Netmonkey[OP] likes this.
  5. May 17, 2022 at 11:12 AM
    clarkritchie
    clarkritchie New Member
    Cthulhu[QUOTED] likes this.
  6. May 19, 2022 at 11:27 AM
    blaserdude
    blaserdude New Member
    Eugene
    2019 Tundra Limited Double Cab
    none
    In month 2 waiting for my shield.
    bc
    Rocko9999 likes this.
  7. Jul 2, 2022 at 12:15 PM
    paknakal
    paknakal New Member
    2018 Tundra
    I just finished installing mine and Tyler said the spacer plates are no longer needed. I have a 4WD and just took the stock t-case cover off per his recommendation.
    mom going to buy the bolt head protectors for the 4 bolts on the front and rear plates. For the Z bracket to rear plate and Z bracket to frame I’m not going to bother since it’s more for protecting the bolt heads and less about theft. Besides a thief who gets the Z brackets off would still have trouble slipping the rear plate off I would think considering how tight the front bolts are.
    I’m still waiting on the engine skid plate from Tyler as well, but that should be here soon.
    Classy63 and NewImprovedRon like this.
  8. Jul 2, 2022 at 12:35 PM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    I installed mine this morning including the front / engine skid plate. Only issue I had was the 3 plastic clips in the stock skid plate to hold the trim piece from the front bumper were all broken so I just rigged it with self tapping screws. Tyler makes a great product.
    Classy63 likes this.
  9. Jul 5, 2022 at 12:56 PM
    9DivDoc
    9DivDoc New Member
    Wisconsin
    2021 TRD PRO CM MGM 2021 SKM CM Limited
    Got my cat guard a few weeks ago and got my front skid plate this morning...these are awesome.
    Classy63 and ATV25 like this.
  10. Jul 18, 2022 at 5:22 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Looking over this insulation for some help. My plates have been on for a few thousands of miles and only notice I’am having creaking or metal noise pulling in the driveway when truck is turning or flexing.
    Under the truck yesterday and pulling and flexing the back plate it’s making noise on the passenger side. Not sure yet if any is coming from the Pro skid plate. Going to try and put a rubber or vinyl O ring in with the bolts and maybe put some insulation in the plates between the frame.
    Going to stop today at my friends garage who did it and see about dropping the Pro skid plate and put insulation maybe in there if the plate is making noise?? I have not had any noise since they were on. I’m herring the same noise when I flex the plate on the passenger side as when I’m in driving the truck.
  11. Jul 18, 2022 at 6:28 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Thanks for posting this.
    I hope to get my truck back Wednesday morning, drive home, and immediately put my plates on.
    Thanks for the heads-up on the spacer plates.
    I was wondering why I didn't have any..
