Valhalla’s Shield theft deterrent/skid plates info and ordering post
Discussion in 'Valhalla’s Shield' started by Classy63, Mar 8, 2021.
Thread Status:
Not open for further replies.
  1. Mar 18, 2021 at 10:06 AM
    #211
    newtauk17
    newtauk17 New Member
    K
    2018 Tundra
    Tyler - I am ready to order. Please PM me instructions.
    thanks
    K
  2. Mar 18, 2021 at 10:34 AM
    #212
    fbingha
    fbingha New Member
    Bakersfield, CA
    How many bolts do we need for both plates? 1.5", 4" what? Assuming no other plates need to be dealt with.
  3. Mar 18, 2021 at 10:36 AM
    #213
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Front
    (2) - 5/8 x 4
    (2) - 3/8 x 4
    Back
    (2) -1/2 x 1.75
    (2) 3/4 x 1.75
    Classy63[OP] likes this.
  4. Mar 18, 2021 at 10:43 AM
    #214
    fbingha
    fbingha New Member
    Bakersfield, CA
    Screwd seems to only carry the 3/8 bolts. Yeah, the frustration with this is real.
    Bammer[QUOTED] likes this.
  5. Mar 18, 2021 at 10:53 AM
    #215
    Bammer
    Monroe, CT
    Yes it is !!! Thinking of using the supplied hardware and getting the bike alarm for 16 bucks..
  6. Mar 18, 2021 at 1:00 PM
    #216
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    At the end of the day, you're still just discouraging the "smash and grab" tweaker with a battery sawzall. If someone is gonna hit your truck with a full socket and box wrench set, and has the time to use it, then you're going to be filing an insurance claim either way...
  7. Mar 18, 2021 at 1:51 PM
    #217
    Classy63
    Classy63 [OP] Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    I 100% agree, that is why there is no guarantee with my product. BUT that being said, 99.999% of the time it is smash and grab
  8. Mar 18, 2021 at 1:56 PM
    #218
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    i am pretty sure im going to keep using the bike alarm. I always back into my driveway and can stick it on the tailpipe on my way in through the garage, then take it off in the morning during my morning smoke. works well for me.
  9. Mar 18, 2021 at 1:56 PM
    #219
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    realistically, with just the 3/8, nobody is going to be able to bend the steel plates down far enough to get a saw in there from the front.
  10. Mar 18, 2021 at 1:59 PM
    #220
    fbingha
    fbingha New Member
    Bakersfield, CA
    I understand that bolt choice isn't going to affect the percentages much. I'll get the screwed that fit then some of the more common HD style for the rest of the bolts.
    Bammer and RainMan_PNW[QUOTED] like this.
  11. Mar 18, 2021 at 2:01 PM
    #221
    Classy63
    Tyler
    Cypress Texas
    I can tell you from experience, NONE of the plate I sell well bend by hand, it is why I discontinued the 1/8 aluminum. Even if they unbolted one side of the plate, they still won’t have access
  12. Mar 18, 2021 at 2:26 PM
    #222
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles. Dirty Deeds standard 10 exhaust. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5.
    This plate seems like a great idea with all of the theft going around, but what are the chances this will reduce the life of a catalytic converter if we cover it up this way? Will the catalytic converter run hotter with this on?
  13. Mar 18, 2021 at 2:31 PM
    #223
    Classy63
    Tyler
    Cypress Texas
    So, in my own testing, when I have had customers from months ago arrive to get the rear plate installed, I always feel the plate under the catalytic converters, it has never been hot, the holes in the plate with the airflow through the engine compartment seems to do the trick. If it would get hot on my truck it would discolor my powder coat or damage it, I have put thousands of miles on my truck with the plates installed and never seen anything to say it would cause issues
    BamaMan44, equin, kittyhawk and 7 others like this.
  14. Mar 18, 2021 at 7:18 PM
    #224
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    I know that powder coating is an option, but for those who purchased bare metal has anyone tried painting with something like Rust-oleum truck bed coating or rubberized undercoating. Seems like these would be an easy and low cost solution with some durability. The only thing that gives me pause is the applications are for less than 200F. Though from Tyler's previous post this may not be an issue. I actually used the Rust-oleum truck bed coating on the stock skid plate on my old 2007 Tundra TRD offroad. Seemed to work well, but I never contacted anything with that flimsy plate.
  15. Mar 18, 2021 at 7:21 PM
    #225
    Classy63
    Tyler
    Cypress Texas
    My early plates before I had powder coating, most of the plates were spray can bed lined, I saw one about a month ago and it still looked good
    honestly it is much simpler for me not to powder coat the plates and I don’t make money on powder coat
    Bammer and RainMan_PNW like this.
  16. Mar 18, 2021 at 7:24 PM
    #226
    3rdTundra
    Central Texas
    Thanks Tyler. Good to know. Did you use a self etching primer before the spray bed liner or directly on metal?
  17. Mar 18, 2021 at 7:29 PM
    #227
    Classy63
    Tyler
    Cypress Texas
    They pretty much said they scrubbed it let it dry and bed lined it
    1lowlife likes this.
  18. Mar 18, 2021 at 8:19 PM
    #228
    Quicksand_Tundra
    Quicksand_Tundra New Member
    Jon
    2019 Quicksand Tundra CM 4x4
    -Color keyed grill & bumper -Diode Dynamic SAE LED Foglights -Headlight Revolution LED Light upgrade -SCS SR8 18x9 with 295/70/18 Toyo Open Country AT3 -Go Rhino Dominator D6 Steps -TRD OEM Intake & Dual exhaust -Bilstein 6112 front and 5160 in rear -JL Audio C2 6.5" speakers upgrade powered by JL Audio RD 400/4 amp -Pair of AudioFrog GS25 speakers front dash -10” Kicker Hideaway subwoofer under driver seat -All doors covered with Soundskins deadening mat (inside/outside) -Front window tinted at 35% -Paint protection film full front -30” Rigid Industries SAE light bar -Body Mount Chop -Diode Dynamics SS2 (red) setup for brake light & turn signal -Katzskin Custom leather upgrade (Black/Bamboo) -Amber led running lights (Hood bulge) -AJT Design: Black vent rings, steering wheel trim, shift gate trim, emblem overlay -AJT Design: Quicksand door handle cover -Carbon fiber wrap (silver part on door panel) -Air Design tailgate applique (Line-X in smooth gloss finish) -Air Design tailgate spoiler (Line-X in smooth gloss finish) -Smittybilt beaver step (Line-X) -Valhalla Cat Shield (Line-X) -Coachbuilder Shackles kit +2 -Coachbuilder Strut/Coilover shim (0.5" for driver side) -Sumosprings (rear bumpstop) -Meso Custom Led front and rear cab lights -Teton shop shift knob -TRD Seat belt shoulder pad -Husky floor liner front/back -LED courtesy door/step light -LED bed light kit w/ outside switch
    Hey Tyler, looking to purchase the front plate. Let me know what you have available and options, would appreciate it. Thx.
    Currently have a Trd skid plate on the truck.
  19. Mar 19, 2021 at 8:39 AM
    #229
    Classy63
    Tyler
    Cypress Texas
    Look at the first post and send me a message and I will get you set up
  20. Mar 19, 2021 at 11:03 AM
    #230
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    For those asking if these plates are compatible with the RCI front plates, yes. I used the existing RCI hardware (they use a carriage bolt), just loosened them up and slid the Valhalla plate underneath. I got the drivers side tightened up easy enough. I think passenger side I’m gonna loosen up front hardware enough to get to passenger side. Rear plate will mount up fine, however I have to move something before I can mount it up. I have victory 4x4 sliders and there are no issues mounting the rear plate with them. 4E9FEE73-6B77-4E4F-A834-85F6A0AAECEC.jpg
    Mater, WAtundra4x4, equin and 5 others like this.
  21. Mar 19, 2021 at 3:58 PM
    #231
    GREENwithENVY
    GREENwithENVY New Member
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    Please do better than Cali Raised...show us all the hard shit to do. :yes:
  22. Mar 19, 2021 at 3:59 PM
    #232
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    my question exactly...LOL
  23. Mar 19, 2021 at 4:04 PM
    #233
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    @Classy63 I'd bet you'd make more money if you offer them scribed with a funny message. :bananadance:
  24. Mar 19, 2021 at 4:40 PM
    #234
    Classy63
    Tyler
    Cypress Texas
    I have had many many many requests for that. I suggest adding your own colorful vinyl
    AggiePhil and MoonRock2021 like this.
  25. Mar 19, 2021 at 6:34 PM
    #235
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Be patient LOL. In time someone will post a install video how to install the front and rear and maybe even if it’s a Pro owner since that area is a little tight.
  26. Mar 20, 2021 at 5:10 AM
    #236
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    It isnt magnets, the magnets are attached to the alarm to make mounting on the metal exhaust easier. Simply slap it on anywhere metallic on the exhaust, which is 99.9% of it.
    Bammer likes this.
  27. Mar 20, 2021 at 5:30 AM
    #237
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    This is not a bad idea... I am sure even with the plate some tweaker would cut the back exposed cat before realizing they can’t get to the other side! The bike alarm is a great poor mans solution.
    https://www.amazon.com/Wireless-Anti-Theft-Vibration-Motorcycle-Waterproof/dp/B0734QN8KR
  28. Mar 20, 2021 at 7:17 AM
    #238
    Classy63
    Tyler
    Cypress Texas
    Update for all those waiting on powder coated plates, my main powder coater was supposed to do one more batch for me before he shut down to move to another shop, he shut down without doing that... I have 3/16 steel front cat plates at my other powder coater. My other powder coater recently down sized to his garage while looking for a new shop to work out of. So if you are waiting on powder coated plates, it will get done, but it may take a bit
  29. Mar 20, 2021 at 9:46 AM
    #239
    Seaflea
    Seaflea New Member
    William
    Hey Tyler, I ordered on the 10th. Any word on when the plate will ship? I know you are swamped, just a ballpark will be fine
  30. Mar 20, 2021 at 11:15 AM
    #240
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I don’t know if this is going to help anyone but w the RCI front plates w carriage bolts I managed to get to the passenger side bolt through the wheel well. I removed the splash guard w a trim removal tool. Jacked the front up to give more room in the wheel well (might have just been easier to remove wheel) stuck a mid deep socket with a universal joint and several extensions to snug it up. Very much a pain in the ass. If you don’t have the RCI or I’m guessing the pro plates you won’t have the same issues. Other than being a tight fit to get wrenches to Tyler’s plates fit great.
    equin likes this.
Thread Status:
