Valhalla’s Shield theft deterrent/skid plates info and ordering post
Discussion in 'Valhalla’s Shield' started by Classy63, Mar 8, 2021.
Thread Status:
Not open for further replies.
  1. Sep 28, 2021 at 3:55 PM
    #2131
    Classy63
    Classy63 [OP] Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    It should be cut this week, the aluminum order delayed the steel order
  2. Sep 28, 2021 at 3:56 PM
    #2132
    Classy63
    Tyler
    Cypress Texas
    Yes, any of my “standard” plates fit with the PRO, it is just a tighter fit the thicker it is
    Enjoihavok[QUOTED] likes this.
  3. Sep 28, 2021 at 4:08 PM
    #2133
    outlaw.taco
    outlaw.taco New Member
    Houston
    Took more time adjusting the rear plate, specifically tighten the two bolts connecting the rear plate to the z bracket slowly, and back and forth to ensure the gaps were split. No 1/8 spacer were needed with this technique.
    twistedcricket and Hightide like this.
  4. Sep 28, 2021 at 4:24 PM
    #2134
    Ne1tHeRe
    Ne1tHeRe New Member
    2021 Cement Tundra CrewMax Limited TRD Off-Road
    I need the Z brackets. Will send a message.
  5. Sep 28, 2021 at 4:42 PM
    #2135
    tyst8
    tyst8 New Member
    PHX, AZ
    well, just ordered mine. hope I ordered correctly, Aluminum front cat theft deterrent/transmission plate and Aluminum Rear Catalytic Converter/Transfer Case Theft Deterrent Plate. I should expect to see it in October/November (maybe)?
  6. Sep 28, 2021 at 4:46 PM
    #2136
    Classy63
    Tyler
    Cypress Texas
    Late October
    tyst8[QUOTED] likes this.
  7. Sep 28, 2021 at 4:53 PM
    #2137
    That was me. :D @GarTX526 no issues with heat and I'm in Fl. IIRC, after a 20 mile drive the highest temp I hit on the plates was around 219 degrees. I have front and rear plates. You won't have any issues.
  8. Sep 28, 2021 at 5:10 PM
    #2138
    Enjoihavok
    Enjoihavok New Member
    Erik
    Chandler,AZ
    Got my set ordered then, thank you.
    Classy63[QUOTED][OP] likes this.
  9. Sep 28, 2021 at 5:12 PM
    #2139
    GarTX526
    GarTX526 New Member
    2016 QuickSand TRD-Pro
    Many pending.....
    Thanks for the message. I’m reading through this thread and hope to come across that.
    That’s great to know especially with the heat in Florida and Texas! Thanks for the reply.
    G
  10. Sep 28, 2021 at 5:26 PM
    #2140
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    219F wow, I drove 500 miles at 75mph in 95F and pulled into gas station. max temp with IR gun was 150F. If you saw 219 f you must have caught the catalytic converter through the ventilation holes.
  11. Sep 28, 2021 at 7:14 PM
    #2141
    tyst8
    tyst8 New Member
    PHX, AZ
    curious to know what the temp is w/o the plates on. 88 degrees is fine but what about 115 degrees AZ/NV temp during the summer?
  12. Sep 28, 2021 at 8:52 PM
    #2142
    dlouly76
    dlouly76 New Member
    Yes they did - Thank you so much!
  13. Sep 28, 2021 at 11:39 PM
    #2143
    18TMSTundra
    18TMSTundra New Member
    Spring,TEXAS
    2018 Red Tundra TSS CrewMax 2WD
    TRD rear anti sway bar. Rear SumoSprings - Black. Toyota Factory Tow mirrors. Advantage - Hard Hat Premier Tonneau Cover.
    5ED917E8-CA7A-4582-84CE-D9D8F201B020.jpg WOW! Just got my plates and they are GREAT!! Well worth the 100 day wait. Now I can safely leave her outside the garage.
    Thanks Tyler for all your hard work and honest dealing!!
    Us TUNDRA folks really do appreciate you!
    kittyhawk and Classy63[OP] like this.
  14. Sep 29, 2021 at 4:35 AM
    #2144
    Post #355 has the temps that I took.
  15. Sep 29, 2021 at 4:37 AM
    #2145
    See post #355. I was a little off...I blame getting older for memory loss lol.
    kittyhawk likes this.
  16. Sep 29, 2021 at 5:57 AM
    #2146
    hinow41
    hinow41 New Member
    Rob
    ETA for Order R458975474?
  17. Sep 29, 2021 at 6:04 AM
    #2147
    Classy63
    Tyler
    Cypress Texas
    2-3 weeks
  18. Sep 29, 2021 at 6:40 AM
    #2148
    tyst8
    tyst8 New Member
    PHX, AZ
    will I need to rust proof the bare aluminum front and rear plates?
  19. Sep 29, 2021 at 6:48 AM
    #2149
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Aluminum doesn't rust :thumbsup:
    JuanTon21 likes this.
  20. Sep 29, 2021 at 6:49 AM
    #2150
    tyst8
    tyst8 New Member
    PHX, AZ
    Oooo shiznit. well now i know.
    ** i only asked because i saw some plates that look like it had rust on it or what appear to be rust
    Uhhhh....[QUOTED] likes this.
  21. Sep 29, 2021 at 7:33 AM
    #2151
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    That’s why I went with the aluminum not to deal with rust. Even if you go with steel and have them powered coated and it comes off from off roading it will probably rust.
    18TMSTundra and tyst8 like this.
  22. Sep 29, 2021 at 8:48 AM
    #2152
    Classy63
    Tyler
    Cypress Texas
    I am packing orders up all day today. I am working my way out of June with bare aluminum orders now
    18TMSTundra and Dsptundra like this.
  23. Sep 29, 2021 at 1:50 PM
    #2153
    Classy63
    Tyler
    Cypress Texas
    I made it out of June except for powder coated aluminum and 3/16 steel. Both are getting worked on. I am excited to plow into July tomorrow.
  24. Sep 30, 2021 at 8:28 AM
    #2154
    Highsierraguy
    Highsierraguy New Member
    Nor Cal
    Installed the plates today. Kind of annoyed with a few things considering how much these cost, the fact I had to wait 10 weeks, and that several other people have had the same issue in this thread which hasn't been fixed.
    The gap between the brackets and the rear plate end was about a half inch when tight. I threaded an extra nut in between which seemed to work, but looks pretty tacky. Also, the rear plate rests up against the transfer case shield. I'm hoping this doesn't make noise when going off road but haven't had a chance to test it.
    Sunnier likes this.
  25. Sep 30, 2021 at 8:33 AM
    #2155
    As mentioned many times, you are supposed to remove the shield from the transfer case. Valhalla is a small operation producing alot of these plates, so most didn't have an issue with the wait. He @Classy63 is the go-to for these plates.
  26. Sep 30, 2021 at 8:34 AM
    #2156
    Highsierraguy
    Nor Cal
    Must have missed that in the instructions... Oh wait there is none. I'll take the shield off and see how it looks.
  27. Sep 30, 2021 at 8:42 AM
    #2157
    There are 4 spacers that go between the rear plate and the crossmember. There are 2 different thicknesses so you will need 1 of each thickness on each side.
  28. Sep 30, 2021 at 8:43 AM
    #2158
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Coming up on week 12…..
  29. Sep 30, 2021 at 9:50 AM
    #2159
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    I know you’ve been busy.
    This was 7 weeks ago.
    What’s the status?
    Sunnier likes this.
  30. Sep 30, 2021 at 10:14 AM
    #2160
    Classy63
    Tyler
    Cypress Texas
    Yours will be shipping this week. I am working into July now.
    Hightide[QUOTED] likes this.
Thread Status:
