Valhalla’s Shield theft deterrent/skid plates info and ordering post
Discussion in 'Valhalla’s Shield' started by Classy63, Mar 8, 2021.
Thread Status:
Not open for further replies.
  1. Sep 24, 2021 at 2:27 PM
    #2101
    Classy63
    Classy63 [OP] Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    Ok, all the aluminum is home, i sent out a lot of ready for pick up notifications this afternoon and I will resume shipping Monday
    GODZILLA, BamaMan44, Bammer and 3 others like this.
  2. Sep 24, 2021 at 8:16 PM
    #2102
    gacosta153
    gacosta153 New Member
    Which size you got?
    I got the 1/2" to 9/16" Bolt Head Protector and it fits
    Mike59 likes this.
  3. Sep 25, 2021 at 4:58 AM
    #2103
    outlaw.taco
    outlaw.taco New Member
    Houston
    Did end of July order make the cut? :fingerscrossed:
  4. Sep 25, 2021 at 2:35 PM
    #2104
    Classy63
    Tyler
    Cypress Texas
    I haven’t checked against my orders yet, but I think it is very safe to say yes
  5. Sep 25, 2021 at 6:19 PM
    #2105
    Groot70
    Groot70 New Member
    Phil
    2011 Silver Sequoia SR5
    Just a quick review… I live local and drove my “Tree” over to Tyler’s place midday to pickup my front and back plates. Went ahead and had Tyler install them with the penta bolts and he does a primo job! Tyler, Enjoyed meeting you and hearing the inspirational story of how you got started with this business! Highly recommend this product and this guy Tyler!
  6. Sep 26, 2021 at 10:31 AM
    #2106
    Classy63
    Tyler
    Cypress Texas
    Just got these from the powder coater, had them done in white for this customer
    fshams, equin and trucknut like this.
  7. Sep 26, 2021 at 10:33 AM
    #2107
    JuanTon21
    JuanTon21 New Member
    2021 Barcelona Red CM 4x4 TRD
    Hey Tyler,
    I got a delivery today!
    unfortunately it was only the rear cat plate, and not also the front plate, and no hardware, mounting brackets.
    Was this a mixup?
    order number R050445112 July 1
    1/8” steel front and rear, black powder coat.
  8. Sep 26, 2021 at 10:48 AM
    #2108
    GREENwithENVY
    GREENwithENVY New Member
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    I've been lazy...just now got around to painting and prepping the 1/4" aluminum plates received last July. (I am jealous of the next gen plates - bends and cuts look great.) Some random commentary so far:
    1. Wet sanded the plates and took a mill file to all edges to knock any rough ones down.
    2. Used self-etching primer to prep the surface for paint.
    3. Used Majic farm implement paint (matte black) to paint surface, brackets, etc. I'm really beginning to like this paint...it has more solids and is for tractors, so it holds up really well (Rural King and Tractor Supply has it).
    4. Bought the bolt head protectors - good buy, expensive (about $20 for two shipped).
    5. Upgraded the 3/8" fasteners to 1/2" Grade 8 (the holes in my plates were large enough without drilling them out - interesting the truck's frame bottom hole is large enough to accept the 1/2" bolt but the top side, where the washer and nut reside is not. I threw a caliper on it and it was 2-3/1000" smaller than the bolt, so a quick zip with a 1/2" drill bit fixed that problem. Literally, it was so slight of an enlargement, I thought I'd snapped the bit when it didn't result in any resistance. I did use low speed on my drill).
    6. Got a little more painting to do and will get them installed next weekend.
    7. I expect the rear plate to require a bit of finessing because I have Cali-Raised rock sliders on but have seen some other's solutions and will do something very similar.
    8. Overall, a great product and look forward to finally getting them on.
    Mike59 likes this.
  9. Sep 26, 2021 at 10:49 AM
    #2109
    Classy63
    Tyler
    Cypress Texas
    I just texted you the other tracking number, it is on it’s way
    JuanTon21[QUOTED] likes this.
  10. Sep 26, 2021 at 10:52 AM
    #2110
    Classy63
    Tyler
    Cypress Texas
    The new plates are so much cleaner. I could have upgraded to 1/2” bolts, but it would make it where I can’t say no drilling required. I know the pro comp lifts use 1/2” bolts which is why I opened the holes up.
    GREENwithENVY[QUOTED] likes this.
  11. Sep 26, 2021 at 11:32 AM
    #2111
    Classy63
    Tyler
    Cypress Texas
    Yes, these are the ones that required the washers. In the future these will have about the same length seen here but won’t need extra washers. It is how I am eliminating the square spacers
    GREENwithENVY likes this.
  12. Sep 26, 2021 at 11:55 AM
    #2112
    GREENwithENVY
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    @Classy63 are you saying on the old z-brackets for the rear plate, if I install a "spacer" (washer or whatever), the plate doesn't bow and I would not need to remove the transfer case guard?
  13. Sep 26, 2021 at 12:06 PM
    #2113
    Classy63
    Tyler
    Cypress Texas
    The transfer case plate needs to be removed still, honestly I haven’t checked yet to see if everything clears with it still there
  14. Sep 26, 2021 at 2:04 PM
    #2114
    Explorer
    Explorer New Member
    Battle Ground WA
    2019 Silver Tundra SR5 TRD Offroad
    Finally installed my plates today. Some of the bolts are a bit of a pain but I got it done. Looks great. Thanks so much @Classy63 for a great product.
    Used some remnants of horse mats I use for lifting and a weight ball to help hold the plates as I was going.
    20210926_135859.jpg 20210926_135947.jpg 20210926_140021.jpg 20210926_122957.jpg
    otherjeff, equin, panicman and 8 others like this.
  15. Sep 27, 2021 at 9:33 AM
    #2115
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    Looks like you are missing the washers for the bolts that tie the plastic bumper tabs to the engine skid plate. I was missing them as well and had to make a quick Home Depot run.
  16. Sep 27, 2021 at 9:38 AM
    #2116
    Explorer
    Explorer New Member
    Battle Ground WA
    There is a washer there, but maybe I need another washer. I have it bolt, plastic bumper, washer, plate. I was having a hard time putting the washer below the plastic and the bolt not being long enough.
  17. Sep 27, 2021 at 9:41 AM
    #2117
    3rdTundra
    Central Texas
    I must admit, I think I went with a longer bolt as well.
  18. Sep 27, 2021 at 9:42 AM
    #2118
    Explorer
    Explorer New Member
    Battle Ground WA
    That would make sense. I will have to look at a little longer bolt.
  19. Sep 27, 2021 at 9:46 AM
    #2119
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Tyler, what is the current lead time on a set of front engine skid plates? These would be going on I guess your first gen cat skid. Does this accomodate diff drop as is or is there additional hardware needed?
  20. Sep 27, 2021 at 12:20 PM
    #2120
    Classy63
    Tyler
    Cypress Texas
    Lead time is 3-4 weeks. It is designed around the diff drop, if you don’t have a diff drop or you are 2wd, there is just some extra room in there.
    MadMaxCanon[QUOTED] likes this.
  21. Sep 27, 2021 at 12:20 PM
    #2121
    Classy63
    Tyler
    Cypress Texas
    I am adding white as an option, this turned out amazing!
  22. Sep 27, 2021 at 1:02 PM
    #2122
    Classy63
    Tyler
    Cypress Texas
    I updated the website with the white and added new pictures instead of whatever I had on my phone
    twistedcricket likes this.
  23. Sep 27, 2021 at 1:24 PM
    #2123
    outlaw.taco
    Houston
    Thanks Tyler
    panicman, GarTX526, equin and 4 others like this.
  24. Sep 27, 2021 at 1:32 PM
    #2124
    Classy63
    Tyler
    Cypress Texas
    These new plates look amazing! Also, thank you for the heads up, the Z bracket for aluminum is fixed for this batch! There is about 1/8” total gap instead of 1/2-3/4”
  25. Sep 27, 2021 at 1:42 PM
    #2125
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    I hope to see mine in a couple of days. Yeah that aluminum looks awesome!!
    Classy63[OP] likes this.
  26. Sep 27, 2021 at 5:17 PM
    #2126
    BamaMan44
    BamaMan44 Roll Tide Roll! Bama Fan till I die! & Go 'Hawks!
    Andre
    Tucson
    Trailbreaker - 2017 Black CrewMax SR5 4x4
    I didn't have any gap with my Z brackets! Great work Tyler!
    Classy63[QUOTED][OP] likes this.
  27. Sep 28, 2021 at 11:54 AM
    #2127
    GarTX526
    GarTX526 New Member
    2016 QuickSand TRD-Pro
    Many pending.....
    Any heat related issues to be aware of with covering the cats?
    I see the ventilation holes and cutouts. Issue was brought up by muffler guy who may see a drop in business if these things are as effective as I believe they can be.
  28. Sep 28, 2021 at 12:09 PM
    #2128
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    There was a previous post of someone measuring the transmission temp before and after cat shields. He determined no temp increase.
    I bought the aluminum ones. Still have my cats.
  29. Sep 28, 2021 at 12:38 PM
    #2129
    jarby
    jarby New Member
    Joe
    2021 Limited DC
    @Classy63 I would appreciate an update to Order# R677367182 (Date: 2021-06-29). This is for 3/16" bare steel front and back skid plates. Thanks!
  30. Sep 28, 2021 at 3:27 PM
    #2130
    Enjoihavok
    Enjoihavok New Member
    Erik
    Chandler,AZ
    @Classy63 sorry if it was mentioned somewhere obviously a ton of pages to filter threw, but in the 1st post it says “standard plate” will fit with the trd skid, by standard do you mean the 3/16 aluminum, or will the 1/4 fit, this would be for a 2021 stock pro.
Thread Status:
