Valhalla’s Shield theft deterrent/skid plates info and ordering post
Discussion in 'Valhalla’s Shield' started by Classy63, Mar 8, 2021.
Thread Status:
Not open for further replies.
  1. Jul 20, 2021 at 9:21 AM
    #1471
    Classy63
    Classy63 [OP] Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    I think I talked to you already, but 100% doable. The plates are going to start getting cut tomorrow, we have been going back and forth making sure everything is right. I should be able to pick up maybe some Thursday, but all Friday
    twistedcricket likes this.
  2. Jul 20, 2021 at 9:34 AM
    #1472
    twistedcricket
    twistedcricket New Member
    Paul
    Omahell, NE
    2014 SR5
    TRD rear sway bar, power fold tow mirrors, Firestone airbags, LED OEM fogs
    Sounds great! Thank you!
  3. Jul 21, 2021 at 11:45 AM
    #1473
    cds4x4
    cds4x4 New Member
    Craig
    I just installed my front and rear plates last night. I did not install the center cross member spacer. When idling and the air conditioner is on I get a vibration. Is this due to not having the spacer in? I don't have any rattling just the vibration. Running both plates 3/16 Aluminum.
  4. Jul 21, 2021 at 11:50 AM
    #1474
    Are you talking about the 4 square plates? Are you 4 wheel drive? If you are, you have to remove the small skid plate from the bottom of the transfer case, and then those spacers go between the plate and the crossmember. If you are 2wd, those spacers are not needed.
  5. Jul 21, 2021 at 7:36 PM
    #1475
    cds4x4
    cds4x4 New Member
    Craig
    So I only received two plates and I’m 4 wheel drive. So I need 4 total to go on the front of the smaller plate correct?
    Classy63[OP] likes this.
  6. Jul 21, 2021 at 7:37 PM
    #1476
    Classy63
    Tyler
    Cypress Texas
    Is yours aluminum? If so you likely got a 1/4” spacer instead of the 2 1/8 steel ones
    equin and Tundra234 like this.
  7. Jul 21, 2021 at 8:25 PM
    #1477
    cds4x4
    cds4x4 New Member
    Craig
    Yes mine are aluminum. That answers that. Thank you everyone will fix and report back. Other then that simple install great quality.
    Tundra234 and Classy63[OP] like this.
  8. Jul 21, 2021 at 10:28 PM
    #1478
    Doubledees
    Doubledees New Member
    Hi Tyler, I was looking at the or fab antitheft cat shield and found myself here. I was interested in getting the front cat shield in 1/8 steel black powder coat. I also saw on your site you were offering the front skid plates? I would be interested in that as well.I am local to Houston and could pick up, thanks.
  9. Jul 22, 2021 at 4:40 AM
    #1479
    Or-Fab has been out of business for a while. Tyler @Classy63 is the go-to for these plates. You will be on a wait list obviously, but I and many others will tell you that his products are a :101010:. His communication and customer service is just as high. He is one of those guys that you will want to shake his hand in appreciation for the effort that he has put into his products. I refer people to his site any time that I can. :hattip:
  10. Jul 22, 2021 at 10:30 AM
    #1480
    Classy63
    Tyler
    Cypress Texas
    As I clear out the last of the plates I have in my garage, h get to decide what to do with some bad cuts and damaged pieces. So, I am putting up a 1/4” aluminum rear cat plate up for grabs for a blemish special! All that is wrong with the plate itself is that one of the holes didn’t cut the whole way. I also have another 1/4” rear cat plate that was a very ugly cut. I only have 3 Z brackets. One is decent, one was not cut right and another is just an ugly cut.
    the one that has a hole not cut is $250 local, $300 shipped
    the one that is ugly and I can only send one Z bracket, $150 local, $20 shipped
  11. Jul 22, 2021 at 4:57 PM
    #1481
    wv00097
    wv00097 New Member
    Wes
    AZ > GA
    2011 SR5 TRD OR
    BDS 7 w/ Fox 2.5 OME Dakar leaf pack CB +2 shackles 18x9 Method 308 +18mm 37x12.5 Toyo AT3 TRD intake/exhaust Infinity Kappa w/ Pioneer HU
    I'm patiently waiting for you to finish designing the plates for the BDS. I'm assuming its the front plate that requires a special structure to attach to the dropped rear crossmember. If this rear plate is universal, I'll take the ugly one. Also assuming it's $200 shipped, not $20. If you can confirm, I'll pay, save it, and ship it with the BDS front cat plate, if/when you finish engineering it.
  12. Jul 22, 2021 at 5:42 PM
    #1482
    cds4x4
    cds4x4 New Member
    Craig
    Installed the spacer today still have the vibration. All bolts are tight does any have any other suggestions? Only vibrates when air conditioning is on.
  13. Jul 22, 2021 at 6:11 PM
    #1483
    Classy63
    Tyler
    Cypress Texas
    Rear plates fit every lift I have encountered
    wv00097[QUOTED] and Tyman like this.
  14. Jul 22, 2021 at 6:12 PM
    #1484
    Classy63
    Tyler
    Cypress Texas
    I am sending you a message with my phone number, let’s fix this
  15. Jul 22, 2021 at 6:13 PM
    #1485
    I would try rubber washers.
  16. Jul 22, 2021 at 9:32 PM
    #1486
    Classy63
    Tyler
    Cypress Texas
    I am pretty sure I got it figured out
    side note, some of the last of the plates I have are coming through powder coat, you can see 3rdtundra’s plates here!
    Update on plasma cut, they got shut down for COVID… he is hoping to get my plates done by Monday.
  17. Jul 23, 2021 at 8:58 AM
    #1487
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Ordered mine on 7/13. Thank you for doing this!
  18. Jul 23, 2021 at 9:08 AM
    #1488
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Are all the rest of June orders in this plasma cut batch?
  19. Jul 23, 2021 at 11:02 AM
    #1489
    Classy63
    Tyler
    Cypress Texas
    Most, 1/4” and 1/8” will be a bit short
  20. Jul 23, 2021 at 11:38 AM
    #1490
    KS1371
    KS1371 New Member
    21 CM MGM TRD SPORT
    Update on order #R166836592?
  21. Jul 23, 2021 at 11:44 AM
    #1491
    Classy63
    Tyler
    Cypress Texas
    I can ship that today! I went through most of May yesterday and took care of everything I could, I have been busy today, but I need to start going through the list some more
  22. Jul 23, 2021 at 11:54 AM
    #1492
    BayRunner
    2017 Tundra Platinum
    since you went through most of May, does that uncles 3/16 aluminum?
  23. Jul 23, 2021 at 12:15 PM
    #1493
    Classy63
    Tyler
    Cypress Texas
    I assume you meant include? I am not saying May is clear, I am saying that everything I have and can ship is almost all gone. My garage has never been so empty… the 3/16 Aluminum should be picked up Monday, and I will be shipping them out as fast as I can starting with those who have waited the longest
    WAtundra4x4 likes this.
  24. Jul 23, 2021 at 12:39 PM
    #1494
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Somebody get this man a beer and an easy chair !!!
    AggiePhil likes this.
  25. Jul 23, 2021 at 12:52 PM
    #1495
    BayRunner
    :rolleyes:
    Highsierraguy likes this.
  26. Jul 23, 2021 at 1:29 PM
    #1496
    KS1371
    KS1371 New Member
    21 CM MGM TRD SPORT
    Great, thanks!
    Classy63[QUOTED][OP] likes this.
  27. Jul 23, 2021 at 2:22 PM
    #1497
    Classy63
    Tyler
    Cypress Texas
    I have a few powder coated pieces here that are waiting for local pick up. But otherwise, I have a few more front skid plates to finish and send with the parts that were ordered to powder coat. Including powder coated and blemish plates, I only 21 plates left here. That is the last of what I have from my previous plasma cutter. To put that in perspective, when my plasma cutter quit, I had at least 200 here. My wife and kids notice it too, they aren’t stacked up everywhere anymore, everything is in my garage… I am looking forward to having the new load from the new plasma cutter next week. I hate being this far behind…
  28. Jul 23, 2021 at 3:07 PM
    #1498
    1/68AR Ventre A Terra
    1/68AR Ventre A Terra New Member
    2019 Platinum
    Viking Heaven Cat Shields and SR5 Rims
    Hey Tyler, is May 23 order R019267614 one of those that went out? Thank you in advance for answering these messages.
  29. Jul 23, 2021 at 3:19 PM
    #1499
    Classy63
    Tyler
    Cypress Texas
    It didn’t… simply put, I am completely out of 3/16 aluminum, until next week!
  30. Jul 23, 2021 at 5:12 PM
    #1500
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Hey Tyler. I know you're busy. I also remember you saying you need someone to come by your place with a BDS lift to get measurements. I assume that hasn't happened yet? If not, do you mind if I try to find someone for you? I don't mind creating a post & trying to hunt down a BDS bracket lift in your area. I'd even pay them for their trouble if I had to.
    wv00097[QUOTED] likes this.
Thread Status:
