Valhalla’s Shield theft deterrent/skid plates info and ordering post
Discussion in 'Valhalla’s Shield' started by Classy63, Mar 8, 2021.
Thread Status:
Not open for further replies.
  1. Jul 13, 2021 at 2:53 PM
    #1381
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Hi Ryan - I had the same concern but since we are in OR it’s less of a concern because we don’t have the salt on the roads like the Midwest or East Coast (unless it is used down south where you are located). I ordered bare plates and plan to use either nylon or neoprene washers to provide some separation. Will there be some galvanic corrosion? Probably yes, but not not enough that I am concerned about. Also, if after a couple years it appears to be an issue I could then pull the plates and paint them.
    rrrobot[QUOTED] likes this.
  2. Jul 13, 2021 at 2:56 PM
    #1382
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    My Kings took 5 months so Valhalla is doing pretty good
    Classy63[OP] likes this.
  3. Jul 13, 2021 at 3:30 PM
    #1383
    BayRunner
    2017 Tundra Platinum
    If you say so.
  4. Jul 13, 2021 at 3:34 PM
    #1384
    JimboSlice413
    Bakersfield
    Material shortages are hitting every industry. Be kind
  5. Jul 13, 2021 at 4:42 PM
    #1385
    BamaMan44
    BamaMan44 Roll Tide Roll! Bama Fan till I die! & Go 'Hawks!
    Andre
    Tucson
    Trailbreaker - 2017 Black CrewMax SR5 4x4
    Did you read the entire thread before ordering? If so, you should have seen where he was transparent with how long it was taking. You have no leg to stand on to complain about the time it's taking to ship. If you didn't, you should have before ordering.
  6. Jul 13, 2021 at 4:58 PM
    #1386
    BayRunner
    Absolutely, been up on every message. Is clearly over the “about a month +/-“. I’m not really being critical of Tyler for I know he’s doing his best and making a quality product. Just venting a bit of frustration due to being out 1k for not being able to take the truck / boat on a long planned vacation trip.
    BamaMan44[QUOTED] likes this.
  7. Jul 13, 2021 at 5:13 PM
    #1387
    Classy63
    Classy63 [OP] Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    I aim for about a month, do I always hit it, heck no…. If my plasma cutter didn’t pull what he did, I was going to start catching up fast…. Once I start up again, I am willing to bet I will be able to get more cut out faster. Powder coat isn’t a problem anymore and bare aluminum is damn near at a month. I have some powder coated orders that fall below that, but I am getting there. But this is because before my plasma cutter quit, I was forcing aluminum through. And steel was next.
  8. Jul 14, 2021 at 7:31 AM
    #1388
    chuck416
    chuck416 New Member
    chuck
    Sharpsburg GA
    I am a bona fide customer of Tyler’s. You will be hard-pressed to find better customer service anywhere. Delays in ground shipping are at historic record levels. Materials. Logistics. Labor. All are running at red line, when they can be found in any quantity. My advice for those who own a tundra, get your cats protected. It’s only a matter of time till this thievery behavior comes to your neighborhood.
    BamaMan44, equin, jarby and 3 others like this.
  9. Jul 14, 2021 at 7:31 AM
    #1389
    Highsierraguy
    Highsierraguy New Member
    Nor Cal
    Any closer on the June 9 aluminum shields being shipped?
  10. Jul 14, 2021 at 7:42 AM
    #1390
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    @Classy63
    Hey Tyler. I am thinking of picking up a few of these bolt head protectors for the installation of my full plate set. (Credit where credit is due... @El Two is using them on his skid plate.) I like the idea of protecting the bolt heads, but they will also prevent the use of vice grips on the pentagon security bolts. Do you see any issue with these fitting on the plates or bolts. For the full plate set including the engine skid plate, should I pick up 4 or 6?
    Thanks!
    El Two likes this.
  11. Jul 14, 2021 at 7:42 AM
    #1391
    1794TX
    Steven
    N.TX
    '20 1794
    Uhhhh...., El Two and AggiePhil like this.
  12. Jul 14, 2021 at 7:44 AM
    #1392
    1794TX
    Steven
    N.TX
    '20 1794
    Great minds...
    El Two likes this.
  13. Jul 14, 2021 at 7:48 AM
    #1393
    Classy63
    Tyler
    Cypress Texas
    I just looked those up, not a bad idea at all! The bad news…. You could only really use those on the 3/8 bolts….
    something I have been thinking about for version 3 is going to all 1/2” bolts or 5/8” and 1/2” bolts.
    AggiePhil likes this.
  14. Jul 14, 2021 at 7:49 AM
    #1394
    3rdTundra
    Central Texas
    Meant to attach the link to the bolt head protectors as well:
    https://www.rockhard4x4.com/product_p/rh-6000-sw-496.htm
    Dimensions
    Outer Diameter: 2.5"'
    Height: 0.5"
    Recessed Hole: 1.10"
    Bolt Hole: 0.5"
  15. Jul 14, 2021 at 7:52 AM
    #1395
    3rdTundra
    Central Texas
    Is your concern that the "bolt hole" being 0.5" means that it measures 0.5" in size and not sized for a 0.5" bolt?
  16. Jul 14, 2021 at 7:54 AM
    #1396
    1794TX
    Steven
    N.TX
    '20 1794
    If you get me dimensions for the bolt heads and threads, I'll try to find them in the right size. Made in USA if possible, hardened if possible.
  17. Jul 14, 2021 at 7:55 AM
    #1397
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  18. Jul 14, 2021 at 8:06 AM
    #1398
    3rdTundra
    Central Texas
    Looking at this picture with the early engine skid, it looks like a total of seven are needed (oval in middle circles two bolt heads):
    Engine Skid: 3
    Transmission plate (front cat plate): 4
    Transfer case (rear cat plate): 0 - Uses same two from transmission plate in front and rear bolts are on the side of the plate.
  19. Jul 14, 2021 at 8:24 AM
    #1399
    Classy63
    Tyler
    Cypress Texas
    If you include the front skid plate, it is 8. Good news, those bolts are staying the same size, even in version 3.
    So! I might have a new company that will be doing the plasma cutting and bending. I am really excited to start shoving metal their way
    Bprose likes this.
  20. Jul 14, 2021 at 8:25 AM
    #1400
    3rdTundra
    Central Texas
    What are the sizes and quantities for the 8 bolts in the current version?
  21. Jul 14, 2021 at 8:30 AM
    #1401
    Classy63
    Tyler
    Cypress Texas
    1/2 4
    5/8 2
    3/8 2
    That being said, you could open the holes on the plates to make it 1/2” instead of 3/8. Also, if you got a sturdy fender washer to go on top of the frame, you could ditch the 5/8 bolt for a 1/2”
  22. Jul 14, 2021 at 8:33 AM
    #1402
    3rdTundra
    Central Texas
    Thank you and great news on the potential new plasma cut supplier!
    Classy63[QUOTED][OP] likes this.
  23. Jul 14, 2021 at 8:37 AM
    #1403
    3rdTundra
    Central Texas
  24. Jul 14, 2021 at 8:43 AM
    #1404
    1794TX
    Steven
    N.TX
    '20 1794
    These are great. As long as they can keep pliers from gripping the bolt head, and provide another minute or two's exposure to someone using a cutoff wheel, they'd be getting their job done.
    3rdTundra[QUOTED] likes this.
  25. Jul 14, 2021 at 8:51 AM
    #1405
    Classy63
    Tyler
    Cypress Texas
    These combined with the pentagon bolts would be pretty good
    RoniusMaximus likes this.
  26. Jul 14, 2021 at 11:30 AM
    #1406
    BayRunner
    Not sure he’s back up running again after his cutter left. I’m still waiting for a May order on bare 3/16 aluminum. @Classy63 any update on getting back online?
  27. Jul 14, 2021 at 11:34 AM
    #1407
    Classy63
    Tyler
    Cypress Texas
    Order number?
  28. Jul 14, 2021 at 12:32 PM
    #1408
    Highsierraguy
    Nor Cal
    R707278296 | Date: 2021-06-04
  29. Jul 14, 2021 at 12:38 PM
    #1409
    Dsptundra
    Austin TX Area
    Yes! Super excited to see this so some more bare aluminum can be pumped out.
  30. Jul 14, 2021 at 1:21 PM
    #1410
    Classy63
    Tyler
    Cypress Texas
    Yours will be in the first batch getting cut by the new plasma cutter.
Thread Status:
