Valhalla’s Shield theft deterrent/skid plates info and ordering post
Discussion in 'Valhalla’s Shield' started by Classy63, Mar 8, 2021.
Thread Status:
Not open for further replies.
  1. Oct 7, 2022 at 9:17 AM
    #5161
    MattAK
    MattAK Headin' for the hills
    Alaska and Utah
    '19 SR5 DC White
    Valhalla Cat Plates, GCS Cooler, Dobinsons, RAS
    No worries, thanks for the update.
    Classy63[QUOTED][OP] likes this.
  2. Oct 8, 2022 at 9:45 AM
    #5162
    JuanTon21
    JuanTon21 New Member
    2021 Barcelona Red CM 4x4 TRD
    @Classy63
    Didn’t get any notifications my nutplate shipped. Can you check on this again? Thanks man. Order R796873356
  3. Oct 9, 2022 at 12:44 PM
    #5163
    FuegoMCS
    FuegoMCS New Member
    East Texas
    2011 Crewmax 2WD
    Nicely done! What hardware did you use? Looks like socket head cap screws/bolts. TIA
  4. Oct 9, 2022 at 12:50 PM
    #5164
    FuegoMCS
    FuegoMCS New Member
    East Texas
    2011 Crewmax 2WD
    I've had my front and rear plates installed for a couple of months now and have had zero issues with install, or rattling. After nearly $6000 covered under insurance for CAT replacement back in January, I did not want it to happen again and have my insurance total my 2011 CM 2WD that is still in excellent condition. During the install I did slip a piece of thin ABS plastic between the two plates where they overlap as the small gap looked like it could be a potential (future) vibration opportunity. Ordering the rear vertical add-on today.
  5. Oct 9, 2022 at 1:53 PM
    #5165
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I used Valhalla's pentagon security bolts with Rock Dome bolt head protectors that would make the bolts harder to cut off..
    Not sure if they help, but they look cool.. :cool:
    I bought the medium domes for my pentagon bolts.
    I only needed 6 since I have a TRD skid plate.
    Don't really need them on the bolt to the frame but I used them.
    Rock Hard 4x4™ "Rock Dome" Tapered Bolt Head Protector for Skid Plate Systems - Medium [RH-6000-SW-400]
    NewImprovedRon likes this.
  6. Oct 9, 2022 at 2:55 PM
    #5166
    FuegoMCS
    FuegoMCS New Member
    East Texas
    2011 Crewmax 2WD
    Thanks! I apologize for the confusion, but what size bolt hardware did you use for the 8 bolts on the rear vertical plate add-on? I may go back and add the rock domes to the pentagon bolts on the front and rear plates later for the same reason.
  7. Oct 9, 2022 at 11:48 PM
    #5167
    BCTRD
    BCTRD New Member
    B.C.
    2021 MGM Tundra TRD Sport
    18"BBS Forged wheels, factory running boards, VLED's, Rigid Pro Led mod (D2 SAE), diff breather mod, Husky mats, DIY Cquartz UK 3.0, Husky liners, OCD organizers,
    What secures the two bolts going through the crossover section of frame? Considering ordering a set for my '21
  8. Oct 10, 2022 at 12:08 AM
    #5168
    BCTRD
    BCTRD New Member
    B.C.
    I'm considering the same and live in B.C.
    Current area isn't bad for theft yet but it seems things are getting worse by the month.
    Unfortunately travelling the Oregon Coast or over to Van may be a sure way to limp home with open pipes the way things are going.
  9. Oct 10, 2022 at 6:45 AM
    #5169
    Ghost Rider
    Ghost Rider Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    I would say:
    If you tend to travel light, occasionally tow or go big, get the steel, either pre-powder coated or post self powder coated, salt prevention is a must.
    If you tend to load heavy right at stick weight, or RV is your middle name, go with aluminum and power coated, pre/post don't matter.
    For those on the fence about it, just bite the bullet and get it, it is better to spend the money and not get hit than get hit and THEN wait 11 months for cats to be in stock while you are one vehicle down due to out of commission.
    BCTRD[QUOTED] likes this.
  10. Oct 10, 2022 at 7:37 AM
    #5170
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    There is a hole in the frame, then that bolt has a nut and washer on top.
  11. Oct 10, 2022 at 7:39 AM
    #5171
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    I don't know, @Classy63 includes the install bolts with the vertical plate.
  12. Oct 10, 2022 at 8:49 AM
    #5172
    lunchmeat
    lunchmeat New Member
    2018 Tundra
    Hi @Classy63
    How is order #R066049637 coming? You said it would be sent last week, so I am following up to see if you were able to get it out the door;)
    Thank You
  13. Oct 10, 2022 at 11:54 AM
    #5173
    BCTRD
    BCTRD New Member
    B.C.
    Most guys going for the 3/16" aluminum plates? Debating on whether or not 3/16" is necessary for cat protection.
  14. Oct 10, 2022 at 12:03 PM
    #5174
    Ghost Rider
    Ian
    Cypress, Texas
    For most, 1/8 is enough as a deterrent, but for those that have it double duty as off-road, 3/18 would be more ideal.
  15. Oct 10, 2022 at 2:04 PM
    #5175
    pkeawe809
    pkeawe809 New Member
    PK
    Westside, Oahu
    2018 Super White TRD 4x4 CrewMax
    ~Chrome Delete interior AJT/Tuff skins ~Driver side Grab handle OEM ~Revesol Leather Steering Wheel ~Front Console upgraded to Limited Leather Trim ~Switched Center Instrument panel from silver to black ~Switched black molding trim pieces to Wood grain ~Wood grain Shift Knob ~LED interior lights- meso customs ~Husky X-act Front Driver and Passenger Floor-mats ~Clazzio Seat covers ~Pedal Commander ~Front Windshield heat protection clear film ~VLEDS Footwell LED light kit-driver and passenger sides ~ESP Under Rear Seat storage bins ~4- Door Speakers- JL C1-650 component speakers ~Front Dash Hertz Speakers ~Zapco ST-4X DSP III 100Watt Component Speaker Amp ~Zapco ST-500XM II 500Watt Subwoofer Bass Amp ~1-Rear 10” Subwoofer and Box enclosure ~Sail panel speakers-Hertz tweeters ~Noico 80 mil Sound deadener on all 4 door panels ~Morimoto Headlights-amber DRL ~Diode Dynamics SS3 Pro Foglights ~OEM Tail lights Hot Tails” option A upgrade by Hot Shot Offroad ~Anytime Front and Rear Camera-Trail Grid Pro ~Precision LED lights-rear bed light, lic plate light ~Retrax Pro XR Bed cover ~Auto Rear tailgate lock OEM ~Repaired rust spot and Repainted Roof 7/22 ~De-badged and removed Stickers ~TRD Dual Exhaust w/black chrome tips ~Valhalla Cat Security Shields-Black powder coated ~Black powder coated TRD skid plate ~Red powder coated front Tow Hooks ~Coachbuilder +2 Shackles 1.25” lift ~TRD Pro Grille ~TRD Pro Skid plate ~TRD front/rear Sway Bars ~Bilstein 6112 front shocks ~Bilstein 5160 rear w/resi ~Nitto Ridge Grapplers 35x12.50R17 ~Icon Alloys Rebound Rims 17x8.5 ~Window Tint
    Great shields and great coverage. Highly recommend. Waited a while but with a one man operation it is totally understandable. Tyler answered all my emails and even helped take care of the shipping on the rear shield which had gotten lost somewhere in transit. Totally worth the wait IMO. Thinking about getting that back L-plate in the future but don't really see the need right now.IMG_2949.jpg IMG_2950.jpg IMG_2951.jpg IMG_2952.jpg
    BCTRD likes this.
  16. Oct 11, 2022 at 12:52 AM
    #5176
    18" TRD Off Road Wheels
    So, I'm just kinda following up here. I'll likely be making the move to a Tacoma Pro sometime next month. Any chance you'll have something compatible with the Pro Taco skid purchasable in that time frame? :fingerscrossed: I'm actually planning to buy from a dealership a few hours away from Cypress, but fuel and time would cost more than the shipping.
  17. Oct 11, 2022 at 4:01 AM
    #5177
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    Tyler doesn't offer 1/8" aluminum, just 3/16" and 1/4" aluminum. He does offer 1/8" and 3/16" steel though. If you are using it for just cat protection and not a skid plate, the thinner 1/8" steel or 3/16" aluminum would suffice. If you plan to use it for cat protection and a skid plate you'd probably want to go with the thicker 3/16" steel or 1/4" aluminum, though if I was using for a skid plate I'd probably opt for the 3/16" steel as it seems like it would do a better job of sliding over rocks than aluminum would.
  18. Oct 11, 2022 at 10:52 AM
    #5178
    FuegoMCS
    FuegoMCS New Member
    East Texas
    2011 Crewmax 2WD
    Thanks for that.
    There is no mention of the bolt hardware being included with the add-on vertical plate on Tyler's ordering site.
    1lowlife[QUOTED] likes this.
  19. Oct 12, 2022 at 4:57 PM
    #5179
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
  20. Oct 12, 2022 at 7:26 PM
    #5180
    Onelook2213
    Onelook2213 New Member
    Andres
    2014 sequoia limited
    Hello, can you update my order R852092023
    Thanks
  21. Oct 13, 2022 at 7:09 PM
    #5181
    lunchmeat
    2018 Tundra
    @Classy63 any word on #R066049637?
    Thank You!
  22. Oct 13, 2022 at 7:32 PM
    #5182
    Classy63
    Classy63 [OP] Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    I am putting together the next order. I will be adding the new V3 4x4 rear cat plate to the website tomorrow hopefully. It won’t cost much more.
    I have 2 1/8 steel and 2 3/16 steel V3 4x4 rear cat plates that are already spoken for. These will be sent out and on trucks soon for better pictures.
    IF YOU HAVE AN OPEN ORDER WITH ME AND YOU WANT THE V3 4X4 PLATE, send me a message.
    If you want to get your order in before I send the next order, you have about 24 hours to get it in.
    I am over ordering for this order so I will likely have stock. Also, I will likely have 22 1/8 steel cat plates in stock next week.
    I have not read any of the previous posts and please don’t murder me for it, I will make time to read it all. Shipping is a PITA, but it is getting done. I have ALOT of plates here now. I will ship all orders!
  23. Oct 13, 2022 at 8:19 PM
    #5183
    Onelook2213
    Andres
    Would like to add a vertical 4x4 back plate to my order R852092023
    Can you comfirm my email I sent that I want to keep my order as it is, and not the lifted plate thanks again .
  24. Oct 13, 2022 at 8:54 PM
    #5184
    Gabe0941
    Gabe0941 New Member
    I’m at 15 weeks for a rear 3/16 AL, in case anyone is wanting an idea of wait time. Hopefully I get a shipment notification soon.
  25. Oct 13, 2022 at 10:05 PM
    #5185
    Romad224
    Romad224 New Member
    2022 platinum blueprint
    25 weeks here buddy.
    Mike59 likes this.
  26. Oct 14, 2022 at 4:32 AM
    #5186
    lunchmeat
    2018 Tundra
    I am able to drive over to pick up order #R066049637 this weekend. 1/8 black steel plates + hardware. I reside in Austin.
    Also, I would help box up a few for others if you need help.
  27. Oct 14, 2022 at 9:21 AM
    #5187
    Gabe0941
    Gabe0941 New Member
    For AL?
  28. Oct 14, 2022 at 1:25 PM
    #5188
    TundraTx12
    TundraTx12 New Member
    2022 Tundra 4x2 SR5 CrewMax
    I’m at 24 weeks. for steel plates.
    @Classy63 … is my order in the upcoming batch?
    order #R729660882 from April 28.
    Thanks!
    JuanTon21 likes this.
  29. Oct 14, 2022 at 2:04 PM
    #5189
    paladinkc
    paladinkc New Member
    KCMO
    2022 Black Platinum
    Any word on
    Order: R189167725 | Date: 2022-07-03?
    Thanks...
    David
  30. Oct 14, 2022 at 5:36 PM
    #5190
    BCTRD
    BCTRD New Member
    B.C.
    Thanks and correct, I edited my original post.
    The Valhalla's do look great btw.
Thread Status:
