Valhalla’s Shield theft deterrent/skid plates info and ordering post
Discussion in 'Valhalla’s Shield' started by Classy63, Mar 8, 2021.
Thread Status:
Not open for further replies.
  1. Jul 3, 2022 at 8:33 AM
    #4711
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Has anyone sprayed their aluminum cat plates with Herculiner spray bed liner? I am considering doing this but I'm a little apprehensive doing it since the plates sit close to the catalytic converters and exhaust and I've read that Herculiner is flammable. The cats and exhaust put out a lot of heat. I understand that you don't want to spray it near a flame but how about after it has dried?
  2. Jul 5, 2022 at 10:26 AM
    #4712
    NewImprovedRon
    Ron
    NW Arkansas
    Decided to go with two coats of primer on the inside surfaces and Herculiner bed spray on the outside (visible surfaces).
    Classy63[OP] likes this.
  3. Jul 5, 2022 at 10:38 AM
    #4713
    NewImprovedRon
    Ron
    NW Arkansas
    Hello, @Classy63 . Received my rear cat plate this morning and it was packaged really well. Thanks for a fine product and for all your responses to my PM questions/updates.
    Classy63[OP], WBW and Fotnot like this.
  4. Jul 5, 2022 at 3:26 PM
    #4714
    Kichinko
    Kichinko New Member
    TRE 5ON
    VA
    SUPER WHITE 2016 Plat 4x4
    TBD
    Lookin to pull the trigger if anyone can provide insight
  5. Jul 5, 2022 at 3:58 PM
    #4715
    1794TX
    Steven
    N.TX
    '20 1794
    Shoot him a PM. he does watch the thread, but it's tough to keep up sometimes... I hope it'll work out for you.
    Kichinko[QUOTED] likes this.
  6. Jul 5, 2022 at 4:15 PM
    #4716
    NewImprovedRon
    Ron
    NW Arkansas
    What sort of insight are you looking to get?
  7. Jul 5, 2022 at 4:47 PM
    #4717
    Classy63
    Classy63 [OP] Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    If I am not mistaken, this is a subframe lift, if so, order the lifted cat plate with the BDS adapter
  8. Jul 6, 2022 at 1:50 PM
    #4718
    Kichinko
    Kichinko New Member
    TRE 5ON
    VA
    TBD
  9. Jul 7, 2022 at 10:33 AM
    #4719
    TommyTundra
    TommyTundra Oh God the anger’s changing me
    Long Island NY
    2019 PRO
    I ordered mine a week ago powder coated black. I was going to do the Raptor bedliner on them just like I did the TRD skidplate but was worried about the flamability also. I just reinstalled my skid plate yesterday morning after letting it cure for four days and it still stinks like hell.
  10. Jul 7, 2022 at 10:38 AM
    #4720
    NewImprovedRon
    Ron
    NW Arkansas
    Thanks for the reply. My cat plate bedliner will probably end up curing for a week or more at this point before my skid plates get here. Hopefully, that will give the cat plates a little more time to cure before installation.
    TommyTundra[QUOTED] likes this.
  11. Jul 7, 2022 at 2:57 PM
    #4721
    Clay J
    Clay J Yota Fan
    Clay
    DFW, TX
    2021 CM 4x4 TSS
    Eibach Stage 1, Pro LED headlights, RCI engine skid plate, Retrax MX tonneau, Ranch Hand front bumper.
    Just ordered front and rear cat plates. Neighbors were just hit by the cat thieves. Too bad Valhalla doesn’t offer 4Runner plates as well. Had to go with RCI for the wife’s ride.
    NewImprovedRon and WBW like this.
  12. Jul 7, 2022 at 4:43 PM
    #4722
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Got the ants in me pants waiting for shipping info. Apologies for the bandwidth from hitting this thread eighteen times every half hour.
    Is it worth it to put a somewhat pliable barrier between the plates and the truck, or where the plates overlap? Like a rubberized strip or some kind of plastic to keep rubbing paint at a minimum. Or are just the washers all that are needed?
    Kichinko likes this.
  13. Jul 7, 2022 at 6:16 PM
    #4723
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    I have nothing between my plates without issue, but some have put rubber or plastic washers between. I would probably put rubber washer between if I were to re-install
    Fotnot likes this.
  14. Jul 7, 2022 at 6:21 PM
    #4724
    Yzed608
    Yzed608 New Member
    Wisconsin
    I'm guessing it depends on the thickness you bought, but I'd put something between the plates. I have the thinner steel and it clangs over bumps. If I had one regret getting these it'd be not getting the thick Al option.
  15. Jul 7, 2022 at 6:22 PM
    #4725
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    That's a simple fix. Tighten up nuts and/or use rubber/poly washers between
    1lowlife and Yzed608[QUOTED] like this.
  16. Jul 7, 2022 at 6:28 PM
    #4726
    Classy63
    Tyler
    Cypress Texas
    Trying to release the 4Runner/Tacoma plate, I am hoping to get the 2nd prototype knocked out this weekend so I can test fit it on as many different setups as I can
    2wd V3 vertical plate is also planned for this weekend
  17. Jul 8, 2022 at 9:43 AM
    #4727
    NewImprovedRon
    Ron
    NW Arkansas
    According to the Herculiner web site, Herculiner is no flammable once it has dried/cured. Cure time is 3-5 days.
  18. Jul 8, 2022 at 11:13 AM
    #4728
    Classy63
    Tyler
    Cypress Texas
    I have designed the 2wd vertical plate, I am going to have a batch of 10 made to see how they work out. I will figure out pricing once I talk to my vendors, but all 10 will be 1/8 steel powder coated black
    1lowlife and DaddyPete like this.
  19. Jul 8, 2022 at 11:16 AM
    #4729
    Ghost Rider
    Ghost Rider Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    I hear my name being called..... itchy ears for sure the whole day....
  20. Jul 8, 2022 at 11:26 AM
    #4730
    Classy63
    Tyler
    Cypress Texas
    You will be my first, also, your truck will be a model for pictures
    1lowlife likes this.
  21. Jul 8, 2022 at 11:27 AM
    #4731
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    PM'd you.
  22. Jul 8, 2022 at 11:28 AM
    #4732
    Ghost Rider
    Ian
    Cypress, Texas
    That means after the oil change tomorrow, need to wash the truck and buff wax it until it shines to blind you.....lol
  23. Jul 8, 2022 at 11:33 AM
    #4733
    Yeah the RCI wasn't out yet for the 4R so I ended up getting a full set of CBI skids.....better than nothing at all. At least the CBI is made to where I can add to it at some point.
  24. Jul 8, 2022 at 11:34 AM
    #4734
    I'm in for the vertical plate as well.....let us know when they are ready for purchase. Thanks @Classy63
  25. Jul 8, 2022 at 11:43 AM
    #4735
    Hell if his works out good on fitment I would even buy one of the 10 test plates from you if you want "field testing". :thumbsup:
  26. Jul 8, 2022 at 11:43 AM
    #4736
    Ghost Rider
    Ian
    Cypress, Texas
    Time for road trip?
  27. Jul 8, 2022 at 11:53 AM
    #4737
    Classy63
    Tyler
    Cypress Texas
    I am also test fitting my prototype for the 06+ Tacoma and 10+ 4 runner if you are in the Houston area
  28. Jul 9, 2022 at 10:23 AM
    #4738
    Romad224
    Romad224 New Member
    2022 platinum blueprint
    Any estimated timeline of when the 22 plates will start shipping? @Classy63
  29. Jul 9, 2022 at 1:15 PM
    #4739
    Classy63
    Tyler
    Cypress Texas
    I was supposed to get the aluminum this week but didn’t… I really hope I get them this week
  30. Jul 9, 2022 at 1:56 PM
    #4740
    kmeindin
    kmeindin New Member
    Ken
    2021 Tundra Trail - Cement
    Lomax Cover, Adarac Rails, Yakima Bike Racks, Undercoat, 3M PP, Step
    Can I get shields for both front and rear for my 2021 tundra trail 4 x 4 sent to me in Edmonton, Alberta, Canada ?
    Is the 4 week delivery delay for both aluminum and steel ?
    Which is better to get steel or aluminum?
Thread Status:
