Valhalla’s Shield theft deterrent/skid plates info and ordering post
Discussion in 'Valhalla’s Shield' started by Classy63, Mar 8, 2021.
Thread Status:
Not open for further replies.
  1. Apr 2, 2021 at 6:44 AM
    #391
    bobbilly
    bobbilly New Member
    Full disclosure. I didn't install it. The technicians said it was a tight fit but he didn't have any issues. His exact words, "Why wouldn't I want it difficult to install/uninstall, it's suppose to be a theft deterrent".
  2. Apr 2, 2021 at 6:45 AM
    #392
    bobbilly
    bobbilly New Member
    I didn't install it, but he seemed pretty pleased with the ease of installation.
    3/16" steel powder coated black.
    tightywhitey likes this.
  3. Apr 2, 2021 at 2:19 PM
    #393
    Classy63
    Classy63 [OP] Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    The installation guide is under my vendor section and on my website
  4. Apr 2, 2021 at 5:03 PM
    #394
    tightywhitey
    tightywhitey New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    Where did you take it and how much did they charge?
  5. Apr 2, 2021 at 8:29 PM
    #395
    bobbilly
    bobbilly New Member
    Well I brought it to my work but they did me a favor and installed it while they where doing the fuel pump recall.
    tightywhitey[QUOTED] likes this.
  6. Apr 2, 2021 at 8:34 PM
    #396
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    So today, I prepped, primered and partially sprayed both skids and brackets. My plates were pretty rusty already so the prep took a little longer than I thought. It went pretty well though in the end.
    First I wiped down all the metal with paper towels, then used degreaser and scuff pad, then paper towel, then acetone and paper towel, finally plain paper towel again. It was pretty damn clean after all that.
    I then used some self etching primer very generously. It took 2 full cans, squeezing every bit out of the can. 3 cans would have been ideal for an extra layer. It dried pretty quick so I was able to spray one side of each plate with the rustoleum hammered black before it got dark. I was able to get one full side and the flaps and brackets with 1 can. 2 cans for it all is perfect. Tomorrow I'll do the other side then throw them on the truck.
    I also have an eye bolt and threaded rod setup that I prepped so I dont have to squeeze my not so small arms in the bowels of the truck for the cross member bolt up. I'll get some pics of that tomorrow.
    MoonRock2021 likes this.
  7. Apr 3, 2021 at 4:54 PM
    #397
    Johnny_E_Jet
    Johnny_E_Jet New Member
    Johnny
    Dallas-Fort Worth, Texas
    2017 Cement Tundra TRD Pro
    Tonneau cover, rear underseat storage
    Any day now.... cmon baby! Big bucks, no whammies!
    I've been living in paranoia, so i cant wait to get mine and install them for some peace of mind.
  8. Apr 3, 2021 at 4:58 PM
    #398
    Classy63
    Tyler
    Cypress Texas
    As soon as my main powder coater is up, you will be one of the first in line
  9. Apr 3, 2021 at 5:01 PM
    #399
    Johnny_E_Jet
    Johnny
  10. Apr 3, 2021 at 5:56 PM
    #400
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    So I got the install done today. I can easily say it was one of the most grueling experiences of my life.
    The plates were extraordinarily heavy and I didnt have a floor jack. Used a small stool to help. I used the 3/8 screwed security bolts in all 4 spots because I didnt want to bore out the trd plate holes for Tyler's supplied 5/8 bolts. Worked well.
    I also found out my u joints dont have zerks, which was one of the greatest moments of my life. Cant imagine taking those plates on and off again to lube joints.
    I also took this opportunity to place some weather strip between contact points between car and plate on the trd skid and torqued bolts properly and the creaking during turning and parking went away. Yay!!!
    equin and PNWTundra2021 like this.
  11. Apr 3, 2021 at 5:59 PM
    #401
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    So I assume after reading your post it would make it much easily to go with the aluminum. Does not sound that easy to install these.
  12. Apr 3, 2021 at 6:10 PM
    #402
    Classy63
    Tyler
    Cypress Texas
    The 3/16 steel plates are really heavy... I have a rough time installing then aswell. I use a floor jack to support the back of the plate when bolting it up. And it is a bit of a he man move. Every other plate is pretty easy to me
    RusPro21 likes this.
  13. Apr 3, 2021 at 6:36 PM
    #403
    Sounds like someone needs some gym time lol. I didn't have any issues with mine but I'm used to lifting heavy stuff from all of those years of changing main engine controls on jet engines.
  14. Apr 3, 2021 at 6:39 PM
    #404
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    Not sure what the weight difference is. I cant imagine the difference is huge since I thought the aluminum was 1/4 inch, which is what the trd plate is and it's pretty heavy too. I do however prefer the beefiness of the 3/16 steel. A lift and or a floor jack would help alot. In all honesty if I had to do it again I'd pay someone to do it. Tire ramps only was rough.
  15. Apr 3, 2021 at 6:41 PM
    #405
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    The weight alone was honestly not the main thing, just the small area under the truck and the awkwardness of the plate size all combined with weight.
  16. Apr 3, 2021 at 6:45 PM
    #406
    Those Screwd bolts are bad ass. I got my 4 inch bolts in the mail today. So for my DE skid, I have a total of 8 bolts holding it on in which 4 of them are Screwd 2 inch, 2 are carriage bolts from the RCI, and 2 are from the Vahalla rear plate. Those 2 will be replaced with the Screwd 4 inch.
  17. Apr 3, 2021 at 6:48 PM
    #407
    Makes sense, I'm lifted so I had a little more room lol. Tomorrow is my first oil change and hopefully have some time to work on my horn mount idea.
  18. Apr 3, 2021 at 7:02 PM
    #408
    MoonRock2021
    MoonRock2021 New Member
    2021 TRD Pro Crewmax Lunar Rock 2021 4Runner Nightshade
    I might have to do the same. How much ya wanna charge me? :yay:
  19. Apr 3, 2021 at 7:04 PM
    #409
    MoonRock2021
    Are the 4" ones 3/8" as well?
  20. Apr 3, 2021 at 7:26 PM
    #410
    Yes. They pass through the crossmember and have nuts on the top. I'm making it hard as hell for them to get my cats as well as preventing the plates from getting stolen if someone ever took the time to try.
  21. Apr 3, 2021 at 7:28 PM
    #411
    MoonRock2021
    Thank you. Ive been trying to buy on your screwd site but i keep getting screwd when they show sold out lol
  22. Apr 3, 2021 at 7:31 PM
    #412
    Yeah they were out of the 1.5 for the front so I had to get the 2 inch. I got the last set. I also got the last set of the 4 inch...it said 1 left when I ordered them.
    MoonRock2021[QUOTED] likes this.
  23. Apr 3, 2021 at 7:34 PM
    #413
    MoonRock2021
    You should bought the 100 pack and packaged them up for sale.
  24. Apr 3, 2021 at 7:44 PM
    #414
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    After knowing how hard it was first hand, the low low price of your first born....
  25. Apr 3, 2021 at 7:50 PM
    #415
    Lol....those things are expensive.
  26. Apr 3, 2021 at 8:04 PM
    #416
    Classy63
    Tyler
    Cypress Texas
    I haven’t been nice to my body, I lift these damn plates everyday, you would think I would look like the rock, but I am still a dough boy.
    another hint for an easier install, I use a little 4 wheel furniture dolly to roll the plates under the truck
    equin likes this.
  27. Apr 3, 2021 at 8:06 PM
    #417
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    Its just dormant muscle my friend.
    Classy63[QUOTED][OP] likes this.
  28. Apr 3, 2021 at 8:24 PM
    #418
    Deathstar1520
    Deathstar1520 New Member
    BRENNAN
    2017 CM SR5 TRD 4X4
    6 inch lift, 35 inch tires and 20 inch wheels, and amp power steps
    can you do like a dark purple powder coat aluminum front skid ?? I got the procomp 6 inch lift
  29. Apr 3, 2021 at 8:32 PM
    #419
    Classy63
    Tyler
    Cypress Texas
    I don’t have a solution for the bigger lifts and the front skid plates... they are all so damn different
  30. Apr 3, 2021 at 8:56 PM
    #420
    Deathstar1520
    BRENNAN
    2017 CM SR5 TRD 4X4
    damn willing to be a test dumbie if close enough
Thread Status:
