Valhalla’s Shield theft deterrent/skid plates info and ordering post
Discussion in 'Valhalla’s Shield' started by Classy63, Mar 8, 2021.
Thread Status:
Not open for further replies.
  1. Mar 23, 2022 at 6:10 PM
    #3721
    TruPatriot
    TruPatriot New Member
    Lee
    Northeast Texas
    2020 TRD Pro MGM Mall Crawler & Trail Riding Queen
    It’s tempting, but I’m going to sell it!
  2. Mar 24, 2022 at 10:25 AM
    #3722
    jgullace
    jgullace New Member
    Joshua
    2020 Tundra (Cavalry Blue)
    Question for everyone is there a major difference in the 4wd and 2wd that warrants the v3? Does the transfer case block the pipes enough to not need a vertical wall?
  3. Mar 24, 2022 at 10:52 AM
    #3723
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    twistedcricket likes this.
  4. Mar 24, 2022 at 12:48 PM
    #3724
    jgullace
    jgullace New Member
    Joshua
  5. Mar 24, 2022 at 1:40 PM
    #3725
    oogabooga289
    oogabooga289 New Member
    I've read the posts over and over and I 100% get the vertical wall on 2WD V3.
    But to be clear for 4WD V3: there is NO vertical wall for 4WD V3 version, correct? There will likely just be unpopulated holes to attach a vertical wall for 2WD?
  6. Mar 24, 2022 at 1:59 PM
    #3726
    rocsteady
    rocsteady New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    Saw the post earlier about waiting for over 100 days on new cats!? That may have sold me on doing this ASAP. Now I'm understanding the "I wish I had ordered earlier" posts.
    Mike59, WBW, toyofan87 and 1 other person like this.
  7. Mar 24, 2022 at 2:22 PM
    #3727
    Ghost Rider
    Ghost Rider Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    I have heard some waiting for four months and counting. Oh, and rear diff too. My neighbor's went in for that and it is week 4 with no news...
  8. Mar 24, 2022 at 2:32 PM
    #3728
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Yep, we all say that too and itching at the bit when will I receive them....Been there, done that...now I'm covered thanks to Tyler.. Called my local Toyo dealer for current price for my year cats, one side $2,200 other side $2,400...Holy Molly...Not cheap.
    Mike59 and AGSport like this.
  9. Mar 24, 2022 at 2:55 PM
    #3729
    Classy63
    Classy63 [OP] Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    Ok, break down of V3 to make it all make sense
    2WD
    Same plate, just have the option for a vertical panel that can be retrofitted to older plates with a few drilled holes.
    4x4
    This will add a hole and a panel to cover it to make transfer case oil changes easier. This also gives alittle more clearance for the transfer case
    Here is where both will have new options. Gusseted Z brackets, this will add triangle gussets to make cutting the Z brackets harder to cut and makes them much stronger for off-road excursions
    Reenforcement spine upgrade, this I really are as an off-road only upgrade, it will strengthen the span of the rear cat plate by adding a small vertical spine that is welded in from edge to edge.
    The 4x4 version is being designed now, the 2wd will be done right behind it.
  10. Mar 24, 2022 at 3:36 PM
    #3730
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    @Classy63 - any timeline on the production of the 2WD V3 shields?
    Thank you!
  11. Mar 24, 2022 at 3:43 PM
    #3731
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    Did you have to use the nut plate from vahalla or was the fitment just fine with the existing trd hardware. Im contemplating getting the trd skids vs the rci.
    TampaRD Pro[QUOTED] likes this.
  12. Mar 24, 2022 at 4:04 PM
    #3732
    Classy63
    Tyler
    Cypress Texas
    I don’t want to commit to a date. But I want to have it designed so I can have it made in the next batch
    WBW[QUOTED] likes this.
  13. Mar 24, 2022 at 4:07 PM
    #3733
    SimpleMan
    SimpleMan New Member
    Chuck
    2021 SR5 TRD OR 4x4
    Diamondback HD
    Any aluminum get shipped this week?:fingerscrossed:
    AggiePhil likes this.
  14. Mar 24, 2022 at 5:06 PM
    #3734
    jgullace
    jgullace New Member
    Joshua
    Awesome! Thank you @Classy63 this cleared it all up I know in our emails I forgot to mention my truck was 4x4 but this clarifies it all and solidifies waiting for the V3.
    Mike59 likes this.
  15. Mar 24, 2022 at 5:09 PM
    #3735
    Reimj
    Reimj New Member
    2016 TRD Pro
    Mine did. Ordered Jan 9th, received my tracking info yesterday afternoon. I ordered bare plates.
  16. Mar 25, 2022 at 7:07 AM
    #3736
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    You dont “have” to use the nut plate at all but it does make it MUCH easier to tighten the plate without having to contort your arm in an effort to get a wrench on the nuts for the front skid. I have big hands/large arms so it was a no brainer for me to spend the extra $20 for the nut plate. Also, I was completely dropping the TRD skid plate anyway to install a TRD front sway bar and Fumoto valve at the same time as the cat plate install.
    It’s possible to just loosen the two rear bolts on the front skid plate enough to slide the front cat shield plate under it and then tighten it back up. Many here have done it as the cat plates were sold for quite a while before Tyler came up with the nut plate for TRD skid.
    AGSport likes this.
  17. Mar 25, 2022 at 8:22 AM
    #3737
    Kung
    KG, VA
    @Classy63 - will this resolve that thing with needing to remove the transfer case tray (to eliminate vibration)? If so, is it a change we can make ourselves (with the right tools)?
  18. Mar 25, 2022 at 9:46 AM
    #3738
    Classy63
    Tyler
    Cypress Texas
    I would still advise to remove the factory black plate under the transfer case. As far as a modification that can be done yourselves, sure it could be, but it would not be something I suggest for someone who hasn’t done metal work before. The spine upgrade makes the plate more rigid which will make it better protection for the transfer case off road, the plate just won’t want to flex anymore
    Mike59 likes this.
  19. Mar 25, 2022 at 2:18 PM
    #3739
    Classy63
    Tyler
    Cypress Texas
    Well, Fed Ex should be here any minute, and my wife is forcing me to take a day off tomorrow, I will probably still sneak in some emails, but I will need taking care of y’all again Sunday
    1lowlife and doggiecareman like this.
  20. Mar 25, 2022 at 3:04 PM
    #3740
    Will the V3 add on plate for the older 2wd plates be added to the site for ordering once they are available?
  21. Mar 25, 2022 at 5:31 PM
    #3741
    Classy63
    Tyler
    Cypress Texas
    Yes
    DaddyPete and Tundra234[QUOTED] like this.
  22. Mar 25, 2022 at 5:34 PM
    #3742
    :thumbsup:
    DaddyPete likes this.
  23. Mar 26, 2022 at 9:42 AM
    #3743
    TexasCabledawg
    TexasCabledawg New Member
    2024 Land Cruiser (had a ‘22 Tundra)
    I am just curious what everyones experience is with the wait time for cat shields. I ordered from Valhalla a week ago and not a peep. I see that ********* is getting theirs shipped out.
  24. Mar 26, 2022 at 9:44 AM
    #3744
    SimpleMan
    Chuck
    2021 SR5 TRD OR 4x4
    Diamondback HD
    I ordered at the end of January. He is doing the best can.
    1lowlife, doggiecareman and ATV25 like this.
  25. Mar 26, 2022 at 9:50 AM
    #3745
    Classy63
    Tyler
    Cypress Texas
    I apologize for the discontent. The sheer amount of orders I have to process, it isn’t realistic to give everyone weekly updates. I do however invite customers to message, email, text me. I will get back to you and update you.
    The order you saw that people’s orders getting shipped out this week were from January and the beginning of February. Please hang in there, I am going to get everyone who ordered exactly what they ordered.
  26. Mar 26, 2022 at 9:51 AM
    #3746
    TexasCabledawg
    Yikes!! Sounds like I need to get refunded and go with TTunes or Talon. Thanks for the reply!!
  27. Mar 26, 2022 at 9:54 AM
    #3747
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    This is good news. Mine were ordered on February 10th so hopefully I'll be getting an email soon. Thank you for all you're doing to get them shipped out.
    WBW and Classy63[QUOTED][OP] like this.
  28. Mar 26, 2022 at 9:54 AM
    #3748
    TexasCabledawg
    I really like the looks of them, but I have to have it installed before the 3rd week of April, and it sounds like that isn't gonna happen.
  29. Mar 26, 2022 at 6:21 PM
    #3749
    kidrman
    kidrman New Member
    2020 Tundra CrewMax
    definitely great news! I ordered February 8 and have been patiently waiting. No concerns over the wait as I know he is doing his best.
  30. Mar 27, 2022 at 10:56 AM
    #3750
    Reimj
    Reimj New Member
    2016 TRD Pro
    My plates arrived yesterday. Due to other things going on this weekend I haven't had time to even pull them out of the packaging they arrived in. No idea how long it takes him to bundle up each order, but seeing how mine were packaged, I assume it is a pretty consuming process.
    Mike59, Classy63[OP] and ATV25 like this.
Thread Status:
