Valhalla’s Shield theft deterrent/skid plates info and ordering post
Discussion in 'Valhalla’s Shield' started by Classy63, Mar 8, 2021.
Thread Status:
Not open for further replies.
  1. Jan 30, 2022 at 4:41 PM
    #3271
    100% agreed. Hell, I ordered a mesh grill 2 weeks ago, and it's not expected to ship until at least 18 Feb. Everything is affected, some people just want to enjoy time on the soapbox.
    Enjoihavok and 1794TX like this.
  2. Jan 30, 2022 at 5:57 PM
    #3272
    1794TX
    Steven
    N.TX
    '20 1794
    Folks, I just bought a rug from Crate & Barrell, and it'll be here in late May at the earliest.
    There's difficulty everywhere, and it's starting to get under folks' skin. It's understandable. All around nothing's great.
    Steady as she goes.
    Enjoihavok likes this.
  3. Jan 30, 2022 at 6:08 PM
    #3273
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    To put a few things in perspective, we decided to buy a standard home with options. It took a year and 16 days till we we able it move in with a lot of pickups. In the middle of last summer I decided to get the two cat shields as I did not want to have my tundra down due to the cats missing. Anyways, delays happen and I was glad I was able to 7 moves with trailers without having to worry about my cats being stolen. The moves supplemented the 2 trucks from the moving co.. cheers..
    1794TX likes this.
  4. Jan 30, 2022 at 6:14 PM
    #3274
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    Must have patience !
    I waited 8 months last year for my 5100s, Les Schwab manager was up front and kept me informed. Just something you have to deal with now.
    1794TX likes this.
  5. Jan 30, 2022 at 8:11 PM
    #3275
    jwctundra
    jwctundra New Member
    2020 Tundra 1794
    I finally got around to installing my plates today. Kudos to Tyler for such a well designed product. I opted for the steel plates and everything fit perfectly on my truck. I was a little bit worried about getting security bolts but I finally gave up since Screwdsecurity.com seems unable to restock anytime soon. I did get the Barnes bolt protectors, (the 5/8" to 3/4") was way too big and frankly looked crazy for where I would have used them on the rear protector. I wound up just using Stainless Steel hardware from Lowe's along with the smaller Barnes bolt protectors only for the front Valhalla plate.
    The newly redesigned brackets for the rear plate worked perfectly without additional spacers and the new TRD skid plate bracket worked perfectly with my OEM TRD skid plate. I could not even imagine trying to install the front plate without it as the clearances looked impossible.
    So for finish, I became obsessed with getting Line-X done on them. If I were to give any advice, I probably would have just gotten them done with the powder coat. I love the finish of the Line-X and they feel incredibly durable but it wound up being about $300 to get done which was pricey on top of the plates. I'm posting them here in case anyone wants to see the finish.
    1lowlife, toyofan87, engineer and 7 others like this.
  6. Jan 31, 2022 at 3:56 AM
    #3276
    Yzed608
    Yzed608 New Member
    Wisconsin
    The LineX does look really good if it makes you feel better about the cost :).
  7. Jan 31, 2022 at 12:17 PM
    #3277
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Not sure if it’s been mentioned here but if anyone is wondering if both plates will work with the wnor sliders - they do, with very slight modification. I cut Tyler’s rear bracket at the bend and rounded over the corners. I had to use the pentagon security bolt instead of wnor’s grade 8 because the security bolt was just a tad longer. Worked out well
  8. Jan 31, 2022 at 4:18 PM
    #3278
    JEHTUNDRA
    JEHTUNDRA New Member
    2021 Crewmax SR5 4x4
    Does your rear plate work with the Desert Eagle Offroad plate? Is it a simple bolt on?
  9. Jan 31, 2022 at 5:13 PM
    #3279
    TS18
    TS18 Northern CO
    2018 sport
    So I installed my rear cat plate last week as per instructions. I drive 1 hour to work and had a weird vibration in the cab. I readjusted the z plate to lower the plate and vibrations are gone. Anyone else have that happen? Either way I’m sleeping better with these on
  10. Jan 31, 2022 at 5:23 PM
    #3280
    Yes it will. I have the DE plate (Tyler wasn't here in the forum at that time).
  11. Jan 31, 2022 at 5:26 PM
    #3281
    Just depends on how tight they were or if they moved slightly. You can always put a rubber strip in between the metal if it comes back.
    TS18[QUOTED] likes this.
  12. Jan 31, 2022 at 5:27 PM
    #3282
    Classy63
    Classy63 [OP] Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    Just got these pictures from my cutter, oh and this isn’t all of it. I told y’all I grossly over ordered
  13. Jan 31, 2022 at 5:28 PM
    #3283
    You will sell every single one of them. :thumbsup:. Now we just need the 2wd rear add on plate designed. :D
  14. Jan 31, 2022 at 5:29 PM
    #3284
    The Line-X will also last longer and be more durable.
  15. Jan 31, 2022 at 5:58 PM
    #3285
    TUNDRA_MIKE
    TUNDRA_MIKE New Member
    NorCal
    2019 TRD Sport, 2021 SR5 Longbed & 2008 SR5 Longbed
    X2 on the 2wd rear add on !
    1lowlife likes this.
  16. Jan 31, 2022 at 6:44 PM
    #3286
    Yep....waiting on our good friend Tyler @Classy63 :D
  17. Feb 1, 2022 at 6:49 AM
    #3287
    TFTundra
    TFTundra New Member
    I have no intention or desire to get ahead of anyone, but if one were to place an order, which metal should one order according to what you may or may not be most likely to have in stock when backlog is cleared? I’m moving to Houston in the next 8 weeks so this is a preventative measure for me! Thank you sir.
    edit* hopefully this makes sense. I’m asking which line for the roller coaster moves faster..aluminum or steel and which thickness?
    Mike59 likes this.
  18. Feb 1, 2022 at 7:15 AM
    #3288
    Classy63
    Tyler
    Cypress Texas
    Steel will be faster
    Mike59 and ATV25 like this.
  19. Feb 1, 2022 at 7:19 AM
    #3289
    TFTundra
    TFTundra New Member
    Great, thank you. 3/16” or 1/8” or does it matter?
  20. Feb 1, 2022 at 7:22 AM
    #3290
    Ghost Rider
    Ghost Rider Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    I would suggest that after maybe two weeks, go ahead and re-tighten the bolts. I had Tyler help me check them when I did the front skid which was about two and a half months after the back plates are on, and he did say it was a "tiny tad" loose, but I don't think it was that loose, and tighten it makes things solid.
    But I think, anything with bolts, always good to check the tightness once in a while, just in case.
  21. Feb 1, 2022 at 11:51 AM
    #3291
    red_5ive
    red_5ive Jedi Knight and friend of Cpt. Solo
    Southern California
    2008 4.7L CrewMax
    • 3.5" Maxtrac Spindle Lift • 2.5" Spacer • Monster XD778 18 x 9 wheels, +18 Offset • Nitto Ridge Grappler 325/65 R18 (34.6 x 12.8 - temporarily back on the 32s until I can decide on gears) • Nitro 5:29 Gears (awaiting installation - on hold for now) • Black/smoke headlights • Clazzio custom leather seats • Boss Wireless Android Auto head-unit • Backup camera
    Is there an ETA on how much longer it takes for powder coat vs bare steel?
  22. Feb 1, 2022 at 1:59 PM
    #3292
    red_5ive
    Southern California
    2008 4.7L CrewMax
    ^^Due to all the overwhelming responses :p, I'm going to go with bare steel and paint it myself since I want this sooner rather than later.
  23. Feb 1, 2022 at 2:02 PM
    #3293
    BobsYourUncle
    BobsYourUncle New Member
    2021 Super White Tundra TRD Pro
    Yeah, bare will always be faster than powder coating as he has to send the parts to a separate place to get powder coated. Now, of course, he may also have an order cancel or drop out that is powder coated. I'd recommend sending him a PM and telling him you'd be interested in that if anything does pop up.
    red_5ive[QUOTED] likes this.
  24. Feb 1, 2022 at 2:16 PM
    #3294
    red_5ive
    Southern California
    2008 4.7L CrewMax
    Good idea! I've been exchanging emails with him so I just messaged him with what you suggested. He probably hates me by now with my dumb questions lol.
    Thanks!
  25. Feb 1, 2022 at 4:18 PM
    #3295
    Classy63
    Tyler
    Cypress Texas
    It takes a lot to irritate me.
    I picked up all the steel today. I am dropping off the majority to powder coat tomorrow morning.
    I got good news from my cutter, the steel and aluminum will have about a 2 week turn around time from when I order, he found a local guy so no more freight costs.
    toyofan87, Kung, Mike59 and 4 others like this.
  26. Feb 1, 2022 at 9:42 PM
    #3296
    Photoweekender
    Photoweekender New Member
    Queens, NY
    2022 Tundra Limited DC TRD OR 4x4 Army Green
    TRD Pro Skid Plate Tonneau cover - OEM Talons Garage cat plate Emblem blackout Solar panel on tonneau cover
    @Classy63 will the bolts from the current platr work with the '22 plate?
    I am asking because I have the security bolts I bought for the 2020 plates and wondering if I should sell or keep for reuse.
  27. Feb 1, 2022 at 10:37 PM
    #3297
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    We bought a new refrigerator from NFM in Feb of 2021.
    The current 13-year-old GE fridge works, but it's making weird noises.
    They told us May of 2021, the June of 2021, then August of 2021, and then November of 2021.
    We canceled the order and got our money back.
    Fortunately, the now 14-year-old GE is still kickin' along..:thumbsup:
    twistedcricket and Tundra805 like this.
  28. Feb 1, 2022 at 10:39 PM
    #3298
    1lowlife
    DADA
    2014 MGM DC SR5
    HEY, I ordered my powder-coated steel plates Friday, aren't they coming in this week?
    Just kidding, looking forward to getting them when you can get them done..
    Your efforts are greatly appreciated...............:thumbsup:
  29. Feb 2, 2022 at 4:54 AM
    #3299
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    So correct, everyone that ordered Tyler's cat plate are so looking forward to receiving them...I'm following a member who ordered his on Thanksgiving day and he's still patiently waiting.. Myself, I'm the first week of Dec , again waiting patiently for that confirmation shipping e-mail... This gives you a general base line of the back orders and wait time for this awesome product by one guy doing it all himself... And now we're in Feb...I'm so ready for these to show up on my front door.... Thank you Tyler for doing the deed. We appreciate it.
  30. Feb 2, 2022 at 5:03 AM
    #3300
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    CBBFBD00-E101-4FF4-BC8A-029D8A02038B.jpg Here they are looking BAD!!
Thread Status:
