Vacuum lines?
Discussion in '1st Gen Tundras (2000-2006)' started by DJS Tundra, Feb 4, 2021.
  1. Feb 4, 2021 at 5:13 AM
    DJS Tundra
    DJS Tundra [OP] Lots to learn
    South Alabama
    2002 White Lmt 4x4
    In doing the valve cover gasket job I’ve noticed quite a few of my vacuum lines are cracking on the ends.
    What is the best option? is there a kit or do I just bring the lines to the parts place and get the appropriate size lines.
    Thanks
    Rex Kramer likes this.
  2. Feb 4, 2021 at 8:00 AM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Just figure out how many feet / meters you need, check the inside diameter of the vacuum line and go to an auto parts place and buy the amount needed in which ever diameter needed. Then replace it one piece at a time with the same routing as the old piece. You could nip off a piece of the old for a sample to show the parts house if needed. Buy the best quality vacuum tubing they sell, it will last longer.
    Sandy01 and jag-engr like this.
  3. Feb 4, 2021 at 8:08 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    jag-engr and Jack McCarthy like this.
  4. Feb 4, 2021 at 8:28 AM
    DJS Tundra
    South Alabama
    2002 White Lmt 4x4
    Got it
    Thanks guys
  5. Feb 4, 2021 at 3:14 PM
    Professional Hand Model
    Hand Protectors
    On some of my hoses, I’ve cut just the cracking portion of the tips off and re-connected with no problems. Most of the hoses have a little extra length to make this happen.
    Key Notes: Be clean and precise with your cuts. New Factory Hoses are High Dolla!!!
  6. Feb 4, 2021 at 3:47 PM
    Rex Kramer
    Georgia
    I have done the same, but I sprayed them with re-seal as I was putting the fresh cut ends where they belonged. It's good stuff.
  7. Feb 4, 2021 at 3:57 PM
    Hand Protectors
    This reseal seems like a good idea. The Hoses mentioned above that I cut were done about 5 years ago and they still look new on the tips. I do have one Hose going into the Air Intake Box that is currently suspect and have considered smoothing some Toy FIPG 103 on it as there isn’t much slack to cut the tip off.
    Also, all the Hoses received some Ziptie love to keep them all organized/bound up in their OEM Clamps.
    Rex Kramer[QUOTED] likes this.
  8. Feb 4, 2021 at 4:04 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    If a hose is cracked, its just best to replace it. You will save yourself a lot of headaches in the long run. vacuum line isn't that expensive.
  9. Feb 5, 2021 at 4:39 AM
    Hand Protectors
    While I agree with your basic premise, many of our hoses have custom bends and turns specific to OEM Fitment.
    Replacing with inexpensive standard straight hose may work in some but not all applications causing other problems in Vacuum thus the OEM Price dilemma. Cutting the tips works as the rest of the hose is perfectly fine. Haven’t tried the sealer trick yet but we’ll see on that one.
