V8 Radiator
Discussion in '1st Gen Tundras (2000-2006)' started by Aaronbc, Dec 23, 2021.
  1. Jan 15, 2022 at 11:48 AM
    #61
    I wish I could find a date code on mine to figure out its last replacement. It looks as if mine is really not too old.
  2. Feb 7, 2022 at 4:14 PM
    #62
    June99
    June99 New Member
    2000 Thunder Gray---Original Owner
    I will be towing my trailer through Utah/Arizona this summer-----any thoughts on adding this-----in addition to a new radiator? I will do timing belt/water pump/thermostat/drive belt as well. https://www.etrailer.com/question-264668.html
  3. Feb 8, 2022 at 9:19 AM
    #63
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    @SouthPaw swapped out his oem trans cooler with the Hayden 696 and he said it keeps temp much better, plus has a built in thermostat. Can't go wrong for $60.
  4. Feb 26, 2022 at 7:50 AM
    #64
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Yup and stupid simple install. Look under the trans cooler thread for more ideas.
