V8 Radiator
Discussion in '1st Gen Tundras (2000-2006)' started by Aaronbc, Dec 23, 2021.
  1. Dec 26, 2021 at 9:12 PM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    Maybe some people just don’t have the money…
  2. Dec 26, 2021 at 9:38 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level Lift, DIY SAIS preventer, headers.
    I would take @Shifty s advice. But, depending on how much you drive it and how long it will take for you to drive 20k… if $100 will let you sleep at night, then go for it.
    As far as fluid I would use a bottle labeled for Asian vehicles that says Toyota in the description. You will find just as many opinions about Toyota radiator fluid as oil. I would comfortably use any aftermarket fluid labeled for Toyota. However the only reason I wouldn’t use Prestone All vehicle is because I don’t have time to make sure every bit of red or pink is gone as they really shouldn’t be mixed- but short of that even it would fine. I have found that the Asian vehicle coolant choice is different in different regions of the USA. Around my area I seem to find Zerex red so that’s what I use.
    The difference between Toyota red and Toyota Pink is about one ingredient if you look at the available sds and chemical data (and it doesn’t really matter to the vehicle, I think it’s for the fish). Also, pink Toyota is pre diluted and red is not, as someone else mentioned.
  3. Dec 27, 2021 at 2:07 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  4. Dec 27, 2021 at 4:33 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
  5. Dec 27, 2021 at 6:18 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    DarkMint likes this.
  6. Dec 27, 2021 at 7:20 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Do they offer one for a 1st Gen Tundra? ie 2000-2006 ?
  7. Dec 27, 2021 at 10:17 AM
    Strangebird22
    Strangebird22 New Member
    Terry
    Ohio
    2000 Tundra AC 4.7 4X4 SR5
    I have my own pink milkshake story, hopefully wont be too long. I happen to work at a auto repair shop in the parts department. In Feb of 2020 I was on my way to work and about 1/2 mile away as I pulled away from a stop light I felt the tranny slip a little. At the next light same thing happened.
    So I pull in to work and leave the truck running so I can check trans fluid. Open the hood and see the pink milkshake flowing out of the coolant overflow bottle. I think CRAP this isn't good.
    They pull the truck in, replace radiator, hoses, and thermostat. Flush trans on a machine twice before fluid starts to look clean and clear. I drove it about 500 miles over a couple of weeks without any problems and then flushed one more time. Since then I have pulled my camper several times and once from OH to TN and back with no problems at all. Shifts great and trans temps stays between 160F and 210F in summer temps. So I guess long story short... I got lucky!!
    Since I bought an aftermarket radiator(not knowing better at the time) I decided to by-pass the trans cooler as to not have that happen again. That was about 2 months ago and so far all is good!
  8. Dec 27, 2021 at 2:54 PM
    Aerindel
    Aerindel New Member
    Montana
  9. Dec 27, 2021 at 4:11 PM
    tvpierce
    Maine
    The take-away is that American, Asian, and European manufacturers use different materials in their engines, and therefore require different coolants to prevent corrosion/oxidation. So the notion that "I've used green coolant in my Chevy for decades and have never had a problem." doesn't make sense for your Toyota or Mercedes... that's all. It's not that one coolant is superior to the other, it's that you need to use the right coolant for the right application.
    5N0W808 likes this.
  10. Dec 27, 2021 at 5:53 PM
    All you need to do is take one look at Noah's "crackie" truck and you'll get a good glimpse of what happens using the wrong coolant and/or mixing coolant colors (yellows and reds). Yellow/green isn't supposed to be used with our 4.7 IIRC... but not sure you can move to the proper coolant without a full flush to remove all the yellow, lest you get potentially caked.
    Always wonder if those same people have insurance. $100 every 10-20 years on a single part known to be a point of failure is less than many people pay for 1-2mos of insurance required to drive.
  11. Dec 27, 2021 at 5:58 PM
    2mchfun
    Did I mention mixing colors? No, I stated Peak red and OEM red could be mixed. No worries though!
  12. Dec 27, 2021 at 6:05 PM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    Very nice.
    I believe my radiator has separate transmission cooler that is kinda sorta built into the main radiator.
    Do you happen to know if Koyo would be able to handle that?
  13. Dec 27, 2021 at 6:28 PM
    Hence the "and/or". No worries though!
    Bigger focus would be on using the wrong color coolant IMO.
    FYI, reason I quoted your post was due to your reply after Aerindel this quote:
    In hindsight, I'm seeing I failed at Multi-Quote didn't and failed to add his quote, so I've edited my post to add that for context.
    2mchfun[QUOTED] likes this.
  14. Dec 28, 2021 at 5:54 AM
    BlueCrushSC16
    Charleston, SC
    Sorry, I have no idea.
    myt1[QUOTED] likes this.
  15. Dec 28, 2021 at 5:58 AM
    BlueCrushSC16
    Charleston, SC
    HBTundra[QUOTED] likes this.
  16. Dec 28, 2021 at 6:01 AM
    BlueCrushSC16
    Charleston, SC
  17. Dec 28, 2021 at 6:10 PM
  18. Dec 28, 2021 at 6:36 PM
    Toyoda Tundra
    Fact. When I replaced mine I was sold a radiator for a DC and it was too tall for my AC. Went back and got the correct one for my AC
    5N0W808 and shifty`[QUOTED] like this.
  19. Dec 28, 2021 at 7:39 PM
    #49
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Been needing to change my radiator. Assuming I have the right one for the DC? Denso 2210518. It's $158 plus shipping so almost $200.
    I can get an OEM from my dealer for $177
  20. Dec 29, 2021 at 9:12 AM
    #50
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    It's probably still denso, that's what I got from the dealer, I knew it was denso when I bought it, but it's a more general one not the OEM specific. Like you'd get on rock auto, but not damaged by shipping.
    CodyP[QUOTED] likes this.
  21. Dec 29, 2021 at 9:58 AM
    #51
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    Buyer beware. I put the all aluminum Koyo racing radiator on my truck and it lasted just over 2 years/20k miles before it sprung a leak where the tubes weld to the bottom tank. It could not be repaired and neither Koyo nor their vendor would do anything to help me out.
    I was really disappointed because it seemed to be really solid and well built, but it just didn't last and they didn't support their product.
    I replaced it with an OEM Denso unit that cost $200 less and will likely last 170k miles like the original one did.
  22. Dec 29, 2021 at 10:01 AM
    #52
    mass-hole
    mass-hole New Member
    I am running a Mishmoto radiator in my 2014 F150 and it is a nice unit. Coolant temps definitely dropped while towing and transmission temps surprisingly did as well by a few degrees.
  23. Dec 29, 2021 at 11:28 AM
    #53
    tacoguybill
    tacoguybill The Burrito Bandido
    Bill
    Saaaan Diaaago
    06 DC SR5 4x4 174k, 04 Sequoia SR5 4x4 105k
    Sooo my 06 DC had the radiator go out at 150K miles, got Denso (OEM) from Napa for $150ish. Wish I would've replaced it preemptively indicated by the brownish aged plastic. Did the thermostat too because it was only like $15. I would replace the hoses at the same time. I agree with @shifty` if you need to do your timing belt and water pump you'll be removing the radiator at the same time. Here's a photo of the crack, don't mind my creepy assistant in the background :rofl:
    FirstGenVol likes this.
  24. Dec 30, 2021 at 7:01 AM
    #54
    BlueCrushSC16
    Charleston, SC
    I wonder why it couldn't be repaired. It's all aluminum. So, a weld shop that can do aluminum TIG should have been able to fix it easily.
    A budget fix would have been to use JB Weld.
  25. Dec 30, 2021 at 12:51 PM
    #55
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Tubes are too thin. They just melt away.
    The tanks, filler neck, inlet/outlet are thick enough if those need work.
  26. Dec 30, 2021 at 1:20 PM
    #56
    NWPirate
    Zach
    WA
    This thread has me wanting to change my '04 out, 150k miles.
    tacoguybill likes this.
  27. Dec 30, 2021 at 1:30 PM
    #57
    nickrick78
    nickrick78 New Member
    Nick
    Pittsburgh PA
    2004 DC
    Might as well do that rad and hoses while you're in there for the timing stuff
    NWPirate likes this.
  28. Dec 30, 2021 at 1:32 PM
    #58
    tacoguybill
    Bill
    Saaaan Diaaago
    Cheap insurance maybe? Is it brownish? I would if it’s discolored, better you change it when it’s on your terms than in a parking lot haha
    NWPirate[QUOTED] and CodyP like this.
  29. Jan 2, 2022 at 9:44 AM
    #59
    careyrob
    Carey
    Massachusetts
    Bingo!
  30. Jan 15, 2022 at 6:29 AM
    #60
    Double DC
    Double DC New Member
    2005 DC & 2021 DC
    The radiator in my '05 DC went out at 270k miles - about 15 years. Seems like a worthwhile preventative maintenance item to me. I agree that starter and alternator will go out as well, but consequences of a radiator leak can be substantial. Glad I happened to see my temp gauge move when my radiator started to leak.
