V6 Triton amber turns
Discussion in 'Lighting' started by PonyMan, Apr 11, 2022.
  1. Apr 11, 2022 at 3:56 AM
    PonyMan
    PonyMan [OP] Old Man
    Central, Louisiana
    2021 Tundra CrewMax 4WD Limited Nightshade Special Edition MGM
    Can anybody give me some advice on how to get the bulb aligned to twist into the headlight housing? I can’t get mine to twist and lock into place. Do you have to pull the headlights to get these bulbs to lock in place? TIA
  2. Apr 11, 2022 at 4:25 AM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Yeah, in Toyota's infinite wisdom, they designed it so you have to remove the grill and quarter pieces and then the headlight housings to change the bulbs.
    https://youtu.be/gSeb4T7WP5M
    PonyMan[QUOTED][OP] likes this.
  3. Apr 11, 2022 at 4:27 AM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    It says 14-18, but yours should be the same besides maybe the TSS stuff.
    PonyMan[OP] likes this.
  4. Apr 11, 2022 at 5:06 AM
    PonyMan
    Central, Louisiana
    Thanks. I can get the headlights off just didn’t want to go through all that to change a bulb. I can reach the bulb I just can’t get the triton bulb to twist and lock in.
  5. Apr 11, 2022 at 5:07 AM
    Taco-Spike
    Two Trucks
    You can reach the driver side to access that one.
    you might have to remove the wash fluid tank to access the passenger side. I did both side without removing the grille and headlights.
    The bulbs have set screws for them, you need to find the right pattern
  6. Apr 11, 2022 at 5:09 AM
    PonyMan
    Central, Louisiana
    Yea I’ve played around with the screw pattern, just can’t get it to lock in
    Taco-Spike[QUOTED] likes this.
  7. Apr 11, 2022 at 5:13 AM
    Depending on which rubber washer that you are using, it's a tight fit so you have to put some descent pressure on it to compress it while you turn the bulb.
    Taco-Spike likes this.
  8. Apr 11, 2022 at 5:30 AM
    PonyMan
    Central, Louisiana
    Yea that too, they only sent one size washer per bulb. So that’s what I’ve been working with.
  9. Apr 11, 2022 at 7:25 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    In the time you've spent typing in this thread, you would have already had the grille off and back on.
    It takes less than 10 minutes to get it off.
    Taco-Spike and RobertD like this.
  10. Apr 11, 2022 at 8:51 AM
    PonyMan
    Central, Louisiana
    I know how it comes off. Done several times. My main concern is not accessing the bulb mount it’s getting the bulbs to fit and turn and lock in place. I’ve changed headlights before, grills, fog lights etc. The bulbs won’t twist and lock in place is my delima.
  11. Apr 11, 2022 at 8:58 AM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
  12. Apr 11, 2022 at 9:58 AM
    PonyMan
    Central, Louisiana
  13. Apr 13, 2022 at 3:47 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Gah I forgot to reply to your other message as well! Did you figure this out? If not, please feel free to give me a call/text at 406-936-0206 and I can walk you through it. As @Tundra234 mentioned you have to apply pretty good pressure to collapse the large washers.
    Tundra234 and Taco-Spike like this.
