UTTundra's '14 DC Build
Discussion in '2.5 Gen Builds (2014-2021)' started by UTTundra, Jan 10, 2018.
  1. May 22, 2018 at 10:43 PM
    #121
    Cuzin Eddie
    Cuzin Eddie New Member
    Shane
    2014 CM Black Platinum 4X4
    TRD Supercharged * BDS 4.5 level with Fox Shocks * AMP running Boards * Bed Rug, Spyder Headlights with HID Conversion * 46 Gal TransferFlow Fuel Tank * Fuel 2 Piece Hostage Wheels * 35" Toyo RT's * Backflip Bed Cover * Pioneer Avic NEX8200 with Amp, Speakers & Subs * Trailer Tow Mirrors * N-Fab Bumper Bar with 30" Vision LED Light Bar *
    You’re killing me UT Tundra! Giving me the want bug! Can’t wait to come and see it.
    UTTundra[OP] likes this.
  2. May 23, 2018 at 4:30 AM
    #122
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    Yea I never tow anything so that's a plus. Only thing will really have in the bed will be a full size spare. And enough stuff for some day trips. But doubtful itll ever be anything over 3 or 400 lbs
    UTTundra[QUOTED][OP] likes this.
  3. May 23, 2018 at 6:55 AM
    #123
    UTTundra
    UTTundra [OP] New Member
    Lou
    Utah
    I think I'm close to done with anything major, haha. Just waiting on parts to finish front suspension and maybe do a proper headlight retrofit since these spyders are giving me some issues. I was at Autotech in Naples the other day, and they were doing a supercharger install on another Tundra.
  4. Apr 5, 2019 at 3:03 PM
    #124
    UTTundra
    Lou
    Utah
    Been awhile since I updated this.
    TRD Pro LED headlights with ihacker harness and vled turn signal bulbs and resistors.
    Northstar Group 31 AGM. Pretty sure this is the biggest battery that will fit in the Tundra. Thought about doing the Genesis dual battery setup, but this route was a lot cheaper and should be more than enough for my needs. It’s also lighter than going the dual route, although the group 31 is still a beast at 75 lbs. I kept the stock battery tray and hold down bracket. I needed longer j-hooks. The 10” hooks were $5 at O’Reilley’s. I extended both positive cables about a foot. The negative cable was fine as is. The machined terminals are from GP Car Audio. I made a cover for the positive terminal using some thermoplastic off Amazon.
    Installed a Pioneer AVH-W4400NEX with the idatalink maestro. I had to chase down a bunch of issues to get this to work properly, but it was well worth. Wireless CarPlay, OBD2 data, TPMS, improved sound even though I already had upgraded speakers, amps, and LC6i. I used the Scosche dash kit, and the fit is near perfect.
