Used Seafoam Now Have A Knocking Sound
Discussion in '2nd Gen Tundras (2007-2013)' started by Apollothetundra, May 26, 2023.
  1. May 26, 2023 at 11:33 AM
    Apollothetundra
    Apollothetundra [OP] New Member
    Trevor
    07 Super White 5.7l V8 295,000
    I drove until my fuel light was on put in 20 oz of seafoam in the tank with 20 gallons of gas . Went through that whole tank now have trouble codes C1201 = Engine Control system malfunction , P0441 Evaporative Emission Control System Incorrect Purge Flow. I have deleted them multiple times with techstream but they come back . Link
  2. May 26, 2023 at 12:02 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    1st question, when did you add the seafoam before the full tank or after?? 2nd question have you modified your intake in anyway?
    C1201 is zero point cal. I get those every now and then, I usually delete them with an obd2 and it's gone for a few months.
  3. May 26, 2023 at 12:17 PM
    Apollothetundra
    Trevor
    . When the tank was empty then filled it with gas to mix it in . The intake yes but was years ago cut a hole behind factory hole and added a pipe or stock air box mod it is called
  4. May 26, 2023 at 12:21 PM
    blackdemon_tt
    As per the seafoam I think you were supposed to add gas, then dump in the seafoam.. hopefully it hasn't damaged any component in there... Check your piping, I was getting the P0441 code on my Celica, but I crossed the purge hoses as I was in a rush to move the car out of my rental and never noticed.... Your case, it may have slipped out.
  5. May 26, 2023 at 12:27 PM
    Apollothetundra
    Trevor
    Where is the purge hose located on the truck ?
  6. May 26, 2023 at 12:37 PM
    blackdemon_tt
    I do believe it's towards the tank. You may also want to check your gas cap as well.
  7. May 26, 2023 at 12:38 PM
    RobertD
    Robert
    DFW, Texas
    Weird, I've been using seafoam the past year or so without issues. I normally add to a half tank of gas but not sure how your method would create an issue.
    Hope it is simple :thumbsup:
  8. May 26, 2023 at 12:40 PM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Wow, never had an issue with Seafoam. Is that the engine knocking or something else?
  9. May 26, 2023 at 12:51 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Hard to isolate the noise from just inside the cabin. Can you have someone give it gas as you film under the hood, and maybe underneath?
  10. May 26, 2023 at 3:38 PM
    Apollothetundra
    Trevor
    I believe it's the inside of my catalytic converter I filmed a video of it .
  11. May 26, 2023 at 3:39 PM
    Apollothetundra
    Trevor
    TILLY[QUOTED] likes this.
  12. May 26, 2023 at 4:37 PM
    TILLY
    Massachusetts
    Glad you found it. Certainly a better outcome than engine noise. :thumbsup:
  13. May 27, 2023 at 10:38 PM
    mtucker
    mtucker New Member
    Escondido CA.
    2008 Double Cab
    Listed in my build thread
    Is that sand coming out of the cat cover occasionally?
  14. May 28, 2023 at 10:46 AM
    Apollothetundra
    Trevor
    Might be mud but I noticed that too
