Use OEM Mic with Aftermarket Headunit
Discussion in 'Audio & Video' started by SchnauzerMan, Aug 2, 2021.
  1. Aug 2, 2021 at 11:09 AM
    SchnauzerMan
    SchnauzerMan [OP] New Member
    Southern New Mexico
    2019 SR5 CM 4x4
    Sumo Struts, Tiger Steps, Bed Rug, Undercover Flex Hard Folding Tonneau Cover
    I ran across a thread on another Toyota forum about how to use the OEM mic with an aftermarket headunit. You don't have to use the 28 pin wiring harness extension that I used. Because I have a Linkedin headunit, which came with matching plugs, I didn't want to compromise the existing wiring of the Linkswell or the truck. If you choose to use one, just search for '28Pin Wire Harness For Toyota Male To Female Extension Full Pins'. As for the USB and Microphone plugs (3.5mm or whatever your HU uses) that plug into the HU, you can use anything you have sitting around the house unused, which is what I did - there is nothing special about these. Just strip them and use the wires indicated below. The OP used a 100k resistor for noise reduction, but I did not (YMMV). Here is the harness which seems to be working well:
    Here is the pinout for 28 plug harness:
    Here are the connections to make:
    Also, if you don't want to tie up a USB, you could use a 12v to 5v step down converter.
    And if anyone does not want to mess with this, there is someone that is making and selling something similar: https://tombit.com/product/3rd-gen-toyota-tacoma-mic-adapter-atc-ato-fuse-type/
    Jman208, Trexman, MedCityMoto and 4 others like this.
  2. Sep 1, 2021 at 5:35 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Bookmarked and probably tackling this someday.
  3. Nov 5, 2021 at 8:31 AM
    Redacted
    Redacted New Member
    MA
    2014 SR5 TRD
    3" level kit
    I thought the issue was the factory mic was amplified and needs a 5v signal. Do you not need voltage to the factory mic and just need the pin 5/19 mic leads tied into a 3.5 plug? If this is true I’m doing this ASAP.
  4. Nov 5, 2021 at 8:33 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That's what the USB supplies, the Mic +5v signal.
  5. Nov 5, 2021 at 8:37 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Bookmarked
  6. Nov 5, 2021 at 8:39 AM
    Redacted
    Redacted New Member
    MA
    2014 SR5 TRD
    3" level kit
    Gotcha. I started looking at my HU and I see an external storage USB plug. Need to confirm if it’s powered or if I need to draw voltage from the HU fuse(add-a-fuse) and then step down voltage. Don’t want to tie into the phone link usb port and mess with the carplay link.
    Thanks a ton.
  7. Nov 5, 2021 at 8:42 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    The USBs on the back of your HU will definitely provide the 5v power, but depending on the port, you might get an error about "incompatible USB" or something along those lines. Probably not a bad idea to use the step down kit like you mentioned.
  8. Nov 5, 2021 at 2:02 PM
    SchnauzerMan
    Southern New Mexico
    2019 SR5 CM 4x4
    The USB power standard is 5v. If all you are using the USB port is for power (ie just using the 2 power wires and not the data ones) then you are not going to get any kind of error - the HU won't even know it's being used.
    Jcmf52 likes this.
  9. Jan 3, 2023 at 4:19 PM
    Gray223
    Gray223 New Member
    2014 Tundra Double Cab Limited
    Has anyone else done this and had it work? Everything else I find people act like it can't be done or you have to do alot more working taking about the factory mic/amplifier. This seems very simple.
  10. Jan 16, 2023 at 7:40 AM
    vilord
    vilord New Member
    Jesse
    2019 TRD
    I'll be hooking this up as soon as I get my truck back from the dealer. I have an idatalink maestro which has a 6v power supply for the reverse camera, so i'm wiring that to feed the mic preamp instead of using usb power.
  11. Feb 6, 2023 at 11:33 AM
    southern_ruckus
    southern_ruckus New Member
    2019 Toyota Tundra TRD Off Road
    This seems like a cool alternative to using an external mic. Has anyone who used this had any issues after long term use?
  12. Feb 6, 2023 at 3:18 PM
    vilord
    vilord New Member
    Jesse
    2019 TRD
    Only feedback (heh) I have so far using the amplified factory mic with a Kenwood carplay radio is that the person at the other end couldn't understand me, too much feedback.
    So I think I need a little more tweaking
    IIonPilgrimg likes this.
  13. Feb 7, 2023 at 7:16 AM
    southern_ruckus
    Ok. Thanks for the response. I wonder if the feedback is related to wire shielding. I think I’m going to give it a try since it doesn’t appear that the wiring harness is available at tombit.com anymore.
  14. Apr 24, 2023 at 10:47 PM
    dabsmcgabs
    dabsmcgabs New Member
    2015 corolla
    Did this for my idoing head unit in my 2015 corolla. Works great! CarPlay had no problems
  15. May 1, 2023 at 1:32 PM
    beerbrewer05
    beerbrewer05 New Member
    2011 White Tundra SR5
    I am getting ready to try this. Just an FYI. That diagram is not correct. It should be a 1K resistor and it goes on the MIC+ side, not the usb side.
    IIonPilgrimg, Jtimon and MedCityMoto like this.
  16. May 23, 2023 at 11:21 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    I need this. Dasaita headunit is great in many aspects but the built-in mic ain't why.
  17. May 23, 2023 at 10:26 PM
    SnowB0und
    SnowB0und New Member
    2013 SR5
    Does anyone have a link to the harness they used? Is this how the 2nd gens are wired?
  18. May 24, 2023 at 4:18 PM
    PDX_Beav
    PDX_Beav New Member
    Portland, OR
    2016 Tundra TRD Pro
    No idea about 2nd gens, but I bought this harness: https://www.ebay.com/itm/203459370351
    IIonPilgrimg and MedCityMoto like this.
  19. May 25, 2023 at 4:05 PM
    MedCityMoto
    Hah! I just bought the same thing for my own 2016, USPS says it arrives tomorrow. Let's compare notes when we're doing this up.
  20. May 25, 2023 at 7:45 PM
    PDX_Beav
    PDX_Beav New Member
    Portland, OR
    2016 Tundra TRD Pro
    I made the cable. I’m going to test it tomorrow with my new head unit. I may end up ditching the usb and just hardwiring to a 12v to 5v step down converter tapped off one of the 12v plugs.
    MedCityMoto likes this.
  21. May 27, 2023 at 4:17 AM
    MedCityMoto
    Get a chance to try it out? I also ordered in a 1k resistor to put mic-side for noise cleanup.
  22. May 27, 2023 at 6:15 AM
    PDX_Beav
    PDX_Beav New Member
    Portland, OR
    2016 Tundra TRD Pro
    UPS lost my package. So Trail Grid Pro and UPS get to work that out while I wait even longer.
  23. May 27, 2023 at 7:54 AM
    MedCityMoto
    Ahhh yes, the standard UPS Manuever © - We Can't Incorrectly Deliver That Which We Lose ®
    ACDC2ZZTop likes this.
  24. May 31, 2023 at 9:29 AM
    MedCityMoto
    I've got mine assembled and the 1K resistor inline on the Mic+ so I'll use an AddAFuse to an accessory with a 5A fuse, and try mine out. My headunit is a Dasaita and I have Mic input gain control so if it's quiet, I'll be able to correct that, long as it's clean and comprehensible.
    Also, you should sell yours along, recoup your costs if it's not going to work out for you!
  25. Jun 1, 2023 at 5:30 PM
    PDX_Beav
    PDX_Beav New Member
    Portland, OR
    2016 Tundra TRD Pro
    Got some 1k resistors and put one in on the Mic+ side. I just tested with my friend and it was clear. They didn’t know which mic was which while testing. I tested it with both mics during the call. They picked the factory mic over the the mic that came with the head unit.
  26. Jun 1, 2023 at 6:41 PM
    PDX_Beav
    PDX_Beav New Member
    Portland, OR
    2016 Tundra TRD Pro
    I ended up tapping the 12v plug closest to the driver using T-taps into a 12v to 5v USB converter to get power. I made a call, the mic still worked well, and I plugged in a 12v usb charger into the outlet I tapped and charged my iPhone from it as a test. Using the tapped outlet did not degrade the mic quality.
  27. Jun 1, 2023 at 8:45 PM
    MedCityMoto
    I tested mine out tonight and it's no different - I think I've missed a setting in the headunit, think it's still using the built-in "mic" on the screen, I'll do some tinkering with settings, see if I can't get it to switch over.
  28. Jun 5, 2023 at 8:51 PM
    Jack_A_Lope
    Jack_A_Lope New Member
    Aaron
    Santa Barbara County, CA.
    2019 Tundra 4X4 SR5 TRD Sport
    Pro Comp Lift, Tires & Wheels, Steel front bumper with LED lighting, Cross bed tool box, bed rails, custom aftermarket sound system
    I have the same head unit (Sony 9500ES) and I used the mic that came with it and it works perfect and there is no problem hearing me on phone calls. There is a setting in the radio that lets you adjust the gain for the mic based on the size of the cab. I have mine set to large.
    That being said I had for a short time a Phoenix Automotive Android radio that plugged right into the factory mic and you had an option to use the factory mic or the one built into the unit. The factory mic worked fine with that radio and didn't need any other harness that didn't come with the radio.
  29. Jun 5, 2023 at 10:01 PM
    PDX_Beav
    PDX_Beav New Member
    Portland, OR
    2016 Tundra TRD Pro
    thanks. I ended up resolving this by putting in the 1K resistor. I now have the factory mic and the interior looks stock, other than the head unit.
  30. Jun 5, 2023 at 10:11 PM
    Jack_A_Lope
    Aaron
    Hardly even notice it.
