USB Power Port Installation
Discussion in '2.5 Gen Tundras (2014-2021)' started by crafty762, Oct 27, 2018.
  1. Oct 27, 2018 at 7:31 PM
    crafty762
    crafty762 [OP] New Member
    Bill
    Minneapolis
    2017 Toyota Tundra SR5 TSS Offroad
    Neon floor lighting, LED bed lighting, Google mini, front LED light bar, custom USB power ports
    nk1794, Hondoman and Pudge like this.
  2. Oct 27, 2018 at 7:35 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Nice job. I kinda wanna put one in my truck, but I have a stupid glass breakage sensor there and zero empty slots.
  3. Oct 27, 2018 at 9:36 PM
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
    I am wanting to install one in that exact spot , but am trying with the idea of installing an accessory fuse box to pull battery power from as I want to have at least that and one of the lighter sockets hot at all times. I hate that all the sockets lose power when the ignition is off. So much for leaving your phone charge while you run in a store or something .
    rodm1, TRD-tv and Hondoman like this.
  4. Oct 27, 2018 at 10:03 PM
    fatalkhaos
    fatalkhaos New Member
    2019 Tundra TRD PRO CM
    Sway Bar 20x10 Fuel Assault 295/55r20 Toyo AT
    Whats the difference in this and the USB plug next to it?
  5. Oct 28, 2018 at 4:34 AM
    timsp8
    NY
    Can you take a pic of the fuse tap? I’m trying to find a source for switched power.
  6. Oct 28, 2018 at 5:05 AM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Nice!
    I did the same except I added a switch above it and tapped an always on power source. I can use the ports with or without the ignition on.
  7. Oct 28, 2018 at 5:14 AM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    The factory plug will allow you to play audio files on your receiver. It will charge a phone, but at a slow rate. The one I added has one qc3.0 port and one 2.4a port which charge much faster than the factory usb port does and gaining more ports for charging multiple devices.
    fatalkhaos[QUOTED] and 14burrito like this.
  8. Oct 28, 2018 at 5:23 AM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Heres what I did, but I did the opposite and used a relay so it's only on when the ignition is.
    Blue sea fuse box inside the console powered by #6awg wire.
    rodm1 and BigdaddyII[QUOTED] like this.
  9. Nov 10, 2018 at 5:18 PM
    rodm1
    rodm1 New Member
    Where about did you hide that?
    Hondoman[QUOTED] likes this.
  10. Nov 10, 2018 at 5:52 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    It's in the console, under the area where the cupholders are.
  11. Nov 10, 2018 at 6:55 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Alternate fuse block is the way to go!
    Hondoman and TRD-tv like this.
  12. Nov 10, 2018 at 6:57 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I put an alternate power port (constant hot) in the glove box.
  13. Nov 10, 2018 at 9:12 PM
    wyone
    wyone New Member
    2018 Tundra DC
    dashcam... more to come
    Ok that is just weird that your glove box has that much room in it.. LOL
    rodm1 and texasrho83[QUOTED] like this.
  14. Nov 10, 2018 at 10:08 PM
    TRD-tv
    TRD-tv New Member
    OHIO
    2012 MGM Tundra TRD
    do it. im gonna take some photos of where i put mine and post it this week but i love it. makes everything neat, easily serviceable and hasslefree
    BigdaddyII[QUOTED] likes this.
  15. Nov 11, 2018 at 4:43 AM
    wyone
    wyone New Member
    2018 Tundra DC
    I plan on using a fuse tap for this.. but am planning on running some wiring to the bed and installing a fuse block there. I use my truck for work and want to install some lights in my tool boxes as well as a small winch. I am having a custom headache rack made with a spot for a 2500 pound winch on it. I use ramps and the winch to pull gang boxes up into the bed of the truck.
    TRD-tv[QUOTED] and rodm1 like this.
  16. Jan 27, 2019 at 9:19 PM
    Donkeypunch
    Donkeypunch New Member
    Has anyone installed one of these for the rear on the center console? I'd like to see some clean installations.
