USB and cig lighter outlets not working
Discussion in '2.5 Gen Builds (2014-2021)' started by Armyretired25, Jan 13, 2016.
  1. Jan 13, 2016 at 12:21 PM
    Armyretired25
    Armyretired25 [OP] New Member
    Northern Alabama
    2016 Plat 4x4 CM
    Dual Exhaust - Black Grill - Back Seat Storage -
    Climbed into my truck this morning and the USB outlet and both cig lighters (under radio and back of center console) are not functioning. Nothing else from what I know of is not working. I quickly opened the fuse box under the hood and although I didn't see any specific fuses named after what's not working I didn't see any bad ones. Any idea?
  2. Jan 13, 2016 at 12:29 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Should be another fuse box in the cab. I'd check there.
  3. Jan 13, 2016 at 12:44 PM
    Def a fuse.
  4. Jan 13, 2016 at 2:02 PM
    Armyretired25
    Northern Alabama
    2016 Plat 4x4 CM
    No fuse box in normal under stearing wheel...only airbag.
  5. Jan 13, 2016 at 2:31 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  6. Jan 13, 2016 at 2:33 PM
    csuviper
    Broomfield, CO
    fuse labeled "PWR OUTLET". It is a 15A fuse.
  7. Jan 13, 2017 at 4:31 PM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    That happened to me - it was a fuse
  8. May 3, 2017 at 6:23 PM
    Bigchat1
    Bigchat1 New Member
    Paul
    2006 Toyota Tundra
    Team, new to the forum and need your help, I have a 2006 Toyota Tundra with the main cigarette adapter that works but the truck comes with two additional plugs on the side labeled 12V 120w and one in the back under the right cup holder area. I have checked them several times but cannot seem to get power to them. I have checked fuses under the hood and checked the 15a fuse talked about above with no luck. Can you guys point me in the right direction? Thanks so much!
