USB Always On
Discussion in '2.5 Gen Tundras (2014-2021)' started by Buck4ua, Aug 22, 2016.
  1. Aug 29, 2016 at 8:58 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
  2. Aug 19, 2019 at 11:05 AM
    Harlan_2nd Gen
    Harlan_2nd Gen New Member
    2007 XSP Double Cab
    Bed cover LED Low Beam, High Beam
    My backseat Cig lighter is “always on” already! Just discovered that :)
    TTund16 likes this.
  3. Aug 20, 2019 at 8:43 PM
    bomber
    bomber New Member
    2017 tundra cm 4x4
    I ran mine off the battery with a fuse. Than added a on/off switch in the dash. This powers the far right cigarette outlet.
    Wallygator likes this.
  4. Mar 23, 2020 at 3:34 PM
    BayouRougarou
    BayouRougarou New Member
    2019 Toyota Tundra Limited 4wd
    I attached a fuse tap to the 1st always hot port in the under dash fuse box to the port labeled 15A P/outlet 2. I added the 15A fuse to the tap and spliced in a male tap to the cold/out side of the p/outlet port. The 12V accessory plugs inside my console and console rear and now always hot. I’m not sure where the fuse is the p/outlet 1. I didn’t look.
    This was on a 2019 Tundra.
    Wallygator and TTund16 like this.
  5. Mar 23, 2020 at 7:53 PM
    TTund16
    TTund16 New Member
    Wonder if newer models are like yours. I should test mine.
  6. Mar 24, 2020 at 6:40 AM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    I made my dash one always on 30A and installed a Quick charge USB, and a USB-C Fast charge for Apple equipment I use for work. I pulled a 10 gauge to the engine fuse box, theres lots of extra places to plug things in there.
  7. Mar 24, 2020 at 6:44 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    My 2014 isn't.
  8. Mar 24, 2020 at 7:08 AM
    coTony
    Tony
    Montrose, CO
    Where did you score that plug with the USB and USB-C? Me likes
  9. Mar 24, 2020 at 7:23 AM
    PeakIT
    PeakIT Old Member
    Utah
    the cool thing about it is that its 36 watt so it can charge a macbook or ipad pretty fast. I did have to Dremel the hole about 1/16 bigger . Also the factory wiring in the tundra is like 22gauge wont support 36 watt so you need a new ground and thicker wire i have 12g and 10g
    MICTUNING 36W Fast PD USB-C Car Charger with USB Quick Charge 3.0 and Type C Charger Socket with LED Digital Voltmeter Compatible with iPhone iPad Pixel Samsung MacBook https://www.amazon.com/dp/B07LCBKZSG/ref=cm_sw_r_cp_tai_KDHEEb18RXAFM
  10. Mar 24, 2020 at 7:42 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Cut a hole into the back of my glove compartment. Felt like my passenger side didnt have it's own USB power but wanted it hidden. It also runs constant power to my CB.
    FB_IMG_1585060696708.jpg FB_IMG_1585060702311.jpg FB_IMG_1585060709069.jpg FB_IMG_1585060715510.jpg
    Shadowfax1 and Wallygator like this.
  11. Mar 31, 2020 at 1:46 PM
    rodm1
    rodm1 New Member
