URGENT HELP with ECU
Discussion in '2.5 Gen Tundras (2014-2021)' started by Pwtaylor2113, Oct 22, 2018.
  1. Oct 22, 2018 at 4:53 PM
    Pwtaylor2113
    Pwtaylor2113 [OP] New Member
    I used a bully dog tuner on my 2015 Tundra. Now truck ECU is all messed up. They need me to remove it to send to them to fix and return. Please I need to remove this in the next few hours. Can someone please tell me where this is located.
    Thanks so much
    SARGE
  2. Oct 25, 2018 at 3:33 PM
    Pwtaylor2113
    Thanks for all
    Your advice.
    The truck is now at a Toyota dealership. And the tuner has been returned to Bully Dogs. Never to be used again. Dealer says that two ECUs and not communicating with each other. Hope to get my boy back soon.
  3. Oct 25, 2018 at 3:34 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Shit, what happened? It crash when it was flashing your ecu?
  4. Oct 25, 2018 at 3:35 PM
    Pwtaylor2113
    Yes and man am I pissed. Hope to get my truck back soon. I won’t be using a tuner anytime soon
    Voyagermike and NewImprovedRon like this.
  5. Oct 25, 2018 at 3:41 PM
    Ntmid8r
    Ntmid8r New Member
    2018 Tundra TRD Sport
    TBA
    Hopefully it’s just a reflash
  6. Oct 25, 2018 at 6:23 PM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    ...and not getting a BD.
    Voyagermike likes this.
  7. Oct 25, 2018 at 6:35 PM
    Did the battery die or ??
  8. Oct 25, 2018 at 11:33 PM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Yeah, in curious too. I run a Bully Dog and have flashed my ECU quite a few times with no issues what so ever.
    14burrito, 15whtrd and GNTundra like this.
  9. Oct 26, 2018 at 2:00 AM
    ZPMAN
    Minnesota
  10. Oct 26, 2018 at 2:11 AM
    15whtrd
    15whtrd Mr. Blonde
    When you first plug in the bully dog it takes a long time to get everything squared away before you can tune the truck. You can update your tuner on the PC or via Wi-Fi while you’re plugged in to the truck. You need to have that battery on a charger while doing so.
    Now if I want to change anything I don’t plug it in to the charger. No problems.
  11. Oct 26, 2018 at 2:48 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    IMO,tuners are just not worth it.In order to gain 30hp (in the higher rpm range) you need to run premium fuel which is .40 cents more per gallon here in VT.
    B737 and MotoTundra like this.
  12. Oct 26, 2018 at 5:31 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I trust Toyota's tuning more than anything else.
    Too much to lose in my opinion with an aftermarket tuner.
    B737, T-Rex266 and NewImprovedRon like this.
  13. Oct 26, 2018 at 6:25 AM
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    I have flashed mine numerous times, mostly when going to the dealership though. It's been installed for 3 years and 60,000 miles later still runs great. I never used a charger the first time and it installed fine, but I have used one ever since then just as precautionary messure.
    Hope all goes well with the truck.
    15whtrd likes this.
  14. Oct 26, 2018 at 9:46 AM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    exactly. "tuning" a pickup truck? gmafb.....
    "i want moar powa, but void my warranty and broke my ecu" makes perfect sense.
    MotoTundra likes this.
  15. Oct 26, 2018 at 10:07 AM
    15whtrd
    15whtrd Mr. Blonde
    I didn’t buy mine so much as to get “moar powa” There are a lot of features that come with it that I like. It has cleaned up the way the truck shifts as well as adjustability of the throttle response. I can clear and read DTC‘s as well as a few other options. My truck is running just fine. Many times it’s user error as to why something went wrong. I have used tuners on many vehicles for years without issues. I gave my mom my old Dodge ram that I had a tuner on it. It’s still running to this day at over 180,xxx miles. It is a Dodge so it had a few other issues but nothing to do with the engine. I use the tuner to clean up the driving experience. Which it does to my liking. Not necessarily to squeeze out every horsepower.
  16. Oct 26, 2018 at 10:26 AM
    B737
    Jersey Shore
    if the truck shifts like garbage maybe it’s broke, or could have bought F150 w ten speed.
    I don’t get putting these add ons to a new vehicle to make them “better”....
  17. Oct 26, 2018 at 10:35 AM
    15whtrd
    15whtrd Mr. Blonde
    OK don’t “get” it then. It must be over your head.
    dandailey likes this.
  18. Oct 26, 2018 at 10:46 AM
    I understand your point(s) but your wording comes off like a complete ass.
  19. Oct 26, 2018 at 10:48 AM
  20. Oct 26, 2018 at 10:54 AM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    How does buying a truck with more gears fix a buyers desire to have different shift points then what Toyota set from the factory?
    Is it ok to put a tuner on a used truck if not a new truck?
    I’m sure everybody has a disposable budget to allow the purchase of 5 or 6 vehicles so that every need is met by at least one.... and the way it came from the factory... cause they are always right.
    Maybe don’t assume that because you don’t want it doesn’t mean that others won’t as well.
    Let’s slow down here and take a look at the facts:
    1 Op is new and has a catastrophic failure and an issue with a highly used piece of gear. Not calling him a liar but maybe some more info or some kind of proof of this happening.
    2. No updates with any information after he got the location he was after.
    I have been the victim of a failed FICM on a diesel a few weeks after purchasing a tuner as well. That was a $1000 repair bill I didn’t want to have. Couldn’t prove the tuner did or didn’t do it. I had that truck another 3 years before getting my Tacoma with not a single problem. Those tuners were way more advanced then the options on this bully dog for our trucks and that was almost a decade ago. It was great I could adjust performance on the fly. Gas mileage tune,stock or full on race mode.... yup I can’t see the practicality in that all.
    Also I do have a bulldog on the Tundra.Its no Nastruck but it’s my opinion everybody should buy one. Just make sure you listen to the warning on the first screen!!
    15whtrd likes this.
  21. Oct 26, 2018 at 11:01 AM
    Taco-Blender
    AZ
    2010 DC 4x4
    You want to turn off your seatbelt chime, Bully Dog will do it. Want to change your shift points, Bully Dog will do it. Want too change throttle pedal sensitivity, Bully Dog will do it. Want to change shift points, Bully Dog will do it. Want to change door lock functions, Bully Dog will do it. Want to monitor trans temp, coolant temp, intake temp, etc, with real numbers, Bully Dog will do it. Want to adjust mph for oversized tires, Bully Dog will do it. Etc, etc, etc...
    Some of us, especially with out of warranty older trucks, would like to have these options.
    Ericsopa and 15whtrd like this.
  22. Oct 26, 2018 at 11:02 AM
    15whtrd
    15whtrd Mr. Blonde
    Juanjoolio007[QUOTED] likes this.
  23. Oct 26, 2018 at 11:07 AM
    netranger6
    Jeremy
    Well. Have anyone measured the throttle position at work? With the BD? member on forum says full pedal is only 86 percent or something.
  24. Oct 26, 2018 at 11:22 AM
    ZPMAN
    Minnesota
  25. Oct 26, 2018 at 11:31 AM
    15whtrd
    15whtrd Mr. Blonde
  26. Oct 26, 2018 at 12:02 PM
    MotoTundra
    MotoTundra The Ocho
    Don
  27. Oct 26, 2018 at 4:40 PM
    ZPMAN
    Minnesota
    I did a test, on the bully dog it says 68% is full open reads 67% when fully depressed. My pedal has been shimed and by the feel of it you should WFO with about 3/8" to spare before pedal fully depressed.
    https://youtu.be/38yYNjkJS_k
    https://youtu.be/SObSj-Ll6k4
    15whtrd[QUOTED] likes this.
  28. Oct 26, 2018 at 7:02 PM
    Trpl7
    Trpl7 My best friend Tate
    Rob
    Washington
    Super White 07
    Partial level kit, Total chaos UCA, coach builder shackles, magnaflow ex. Tuner, SABM, complete poly bushing suspension.
    Toyota sets WOT at 68%, don’t know why but it is truly WOT. These tuners are a like or dislike add on for people that want a little something different with their vehicle. If you don’t like them that’s fine, and your opinion is your opinion. Fact is they do work and they do change the driving experience and add options that you wouldn’t have otherwise. So there is no reason to try and make it sound like those of us that use them are idiots because we purchase items that modify our vehicles to make them different from the next. One other thing, scale of 1 to 10 with 10 being the best Ford rates a 2.
  29. Oct 26, 2018 at 7:57 PM
    ZPMAN
    Minnesota
    A few things I would like bully dog do is to make it possible to mirror the unit to my head unit (very small screen), the other would be there teck phone service was a 2 out of 5. Other than that it's been great.
  30. Oct 26, 2018 at 8:07 PM
    15whtrd
    15whtrd Mr. Blonde
