Uptune the detuned SR
Discussion in '3rd Gen Tundras (2022+)' started by FO LO, Jan 22, 2023.
  1. Jun 8, 2023 at 12:51 PM
    mass-hole
    mass-hole New Member
    Yes, they probably just artificially capped the torque at 406 ft-lbs at 2000 rpm instead of letting it continue climbing to 479.
    GM did this with their original 2.7L. The torque curve literally just hits a ceiling and flat lines.
    But as of this year that same motor now climbs to 390 at 2000 rpm and 430 ft-lbs at 3000 rpm. HP is still 310, they just lifted the artificial torque cap in the tuning.
    superfluous likes this.
  2. Jun 8, 2023 at 1:42 PM
    superfluous
    superfluous 2023 Tundra SR CM 4X4
    metro Detroit, Michigan
    I wrote Burger Motorsports before about the performance of the JB4 on the SR vs other models. They said it works "fine" on the SR... ¯\_(ツ)_/¯ I think they are saying it works the same?
  3. Jun 8, 2023 at 7:07 PM
    BMP
    BMP New Member
    2023 Tundra SR5 SX MGM CM 4X4
    I did as well. Was interested in SR stock boost pressure. I never did get an answer. Was waiting on an SR to mod but totaled my Cruiser so I bought an SR5 that is in route to be delivered soon. I did test drive an SR and it felt prety good for being detuned. The SR5 will be that much better.
    Brad
    Woocawachie likes this.
  4. Jun 9, 2023 at 6:45 AM
    BMP
    BMP New Member
    AFR’s are viewed in real time via a Bluetooth mobile kit or a windows based laptop.
    Brad
  5. Jun 9, 2023 at 7:33 AM
    BMP
    BMP New Member
    Yes, and I would get the wireless phone kit as well.
    Brad
  6. Jun 9, 2023 at 8:55 AM
    blenton
    blenton New Member
    Wait, those guys don’t always tell the truth? Son of a motherless goat!!
    Sounds like you need to set up a dyno session with a local shop :D
    I suppose you could also do some timed 0-60 runs, then work the maths backwards to find out an estimation of gained HP from the time change…
  7. Jun 9, 2023 at 8:58 AM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Do it Euro…. You won’t regret it. Although you’re siting @ 65k. She pulls like a freight train, coal dragger if you will !
  8. Jun 9, 2023 at 6:25 PM
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    @Coal Dragger , you were summoned...
  9. Jun 9, 2023 at 7:53 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    If I will what? Describe the performance of a freight train?
    Generally these days with the obsession with “fuel conservation” pulling like a freight train is not a good thing. It means you’re slow. Real slow, with a chance of stalling out on the next hill you see.
  10. Sep 26, 2023 at 5:14 PM
    PhearCVBz
    PhearCVBz New Member
    2021 Black Tundra DC, 2024 Black Tundra CrewMax
    Have a 2024 SR coming soon. Will the JB4 void warranty? Website says it can be removed "without a trace", so curious? Thanks guys.
  11. Sep 27, 2023 at 2:38 PM
    Woocawachie
    Woocawachie New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
    The smaller tank is definitely one of the biggest let downs on the SR model.
    Mattedfred[QUOTED] likes this.
  12. Sep 28, 2023 at 9:01 AM
    PhearCVBz
    Replying to my own question.
    After doing more research (that I should have done prior), I changed my mind and ended up going with an SR5. There was some questions as to the traceability of the JB4 if there was an engine warranty issue and Toyota looked at diagnostics and etc (basically people are saying they could see the high boost levels and other evidence of it and possibly deny warranty). On top of that, with gas prices they way they are I was not looking forward to having to run 91+ Octane.
    For anyone reading, this is the thread I was referring to.
    https://www.tundras.com/threads/jb4.122299/
    Thanks again guys.
    MadRanx likes this.
  13. Sep 28, 2023 at 11:16 AM
    mass-hole
    They cant see the high boost levels. The JB4 works by spoofing the PCM into running more boost.
  14. Oct 1, 2023 at 2:22 PM
    mudslinger
    mudslinger New Member
    Mudslinger
    23 tundra sr black
    Check out the Scorcher power module they say it doesn’t leave a foot print.ps new member
  15. Oct 1, 2023 at 3:01 PM
    Black widow TRD
    Manuel
    No use in arguing, everyone is entitled to their opinion. Opinions are like assholes… everyone has one.
  16. Oct 4, 2023 at 7:47 AM
    PhearCVBz
    Yeah in the off chance that they are right, and it somehow appears in the logs, it's a pass for me. Sounds fun though.
  17. Oct 4, 2023 at 8:09 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Doesn't work that way, but the other tells would be obvious...assuming they're included in the stored data. Fuel injector duty cycle would be an easy one to tell. They know what % injectors operate at during Xpsi and load %. If they see the "same" psi at that load % but the injectors are working at 80% vs 65 because of the added boost or ethanol content then they can assume some trickery was up. The truck will go into limp mode if it ever "overboosts" and will throw a code but its possible to do even stock.
  18. Oct 4, 2023 at 10:24 AM
    eddiefromcali
    Eddie
    100% Stock
    its a watered down JB4. Uses same inputs but does not have A LOT of the features JB4 offers
  19. Apr 21, 2024 at 11:11 AM
    #49
    cabiczzz
    cabiczzz New Member
    Clyde
    2024 SR
    Stock
    No updates to this? 2 years has elapsed...
    MadRanx likes this.
  20. Apr 21, 2024 at 5:19 PM
    #50
    Woocawachie
    Dickens
    Philadelphia
    Seems like not that many people have this trim. No demand no supply
  21. Apr 21, 2024 at 10:20 PM
    #51
    cabiczzz
    cabiczzz New Member
    Clyde
    2024 SR
    Stock
  22. Apr 22, 2024 at 5:23 AM
    #52
    Woocawachie
    Dickens
    Philadelphia
    I honestly think we don’t need it. There isn’t that much of a difference in real world between the SR and SR5. I have driven both, i do tow 5k trailer and it does it with ease. I did throw in the red filters from TRD model, seemed like it helped the turbos spool up a bit quicker when applying gas. Also cut off the pipe right after it leaves the muffler, got rid of the resonator. That doesn’t make any difference, just cosmetic
  23. Apr 22, 2024 at 7:57 AM
    #53
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
    My 2.5 gen SR has the same power as my 2nd gen SR5. I was not aware the 3rd gen had changed the SR format that drastically. Toyota saved money on these older ones omitting all kinds of conveniences inside the cab basically.
    No intermittent wipers, dual climate controls, vanity mirrors etc.
    cabiczzz likes this.
  24. Apr 22, 2024 at 8:48 AM
    #54
    Woocawachie
    Dickens
    Philadelphia
    Don’t forget 31 less horsepower limited by software
    Lifer likes this.
  25. Apr 22, 2024 at 11:33 PM
    #55
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    And where’d they get that SR rear window port-hole? Reminds me of one from a big 3 brand truck
  26. Apr 23, 2024 at 4:17 AM
    #56
    Woocawachie
    Dickens
    Philadelphia
    My crewmax SR has the entire rear window go down like all other trims
  27. Apr 23, 2024 at 3:25 PM
    #57
    PNW Tundra Mike
    Southern Cal
    Interesting. Was one on here just last week with a little rectangular sliding inset window. Unknown if powered. Wonder if that was a on US model by chance. I had never seen that before and had to ask.
  28. Apr 23, 2024 at 3:32 PM
    #58
    Woocawachie
    Dickens
    Philadelphia
    Probably because it was a a double cab and not a crewmax. I’ve seen them here in US with double cabs and they also have the small sliding window in the back. Electric powered
  29. Apr 23, 2024 at 3:33 PM
    #59
    PNW Tundra Mike
    Southern Cal
    That’s it! Was a double cab. Thx. (Thx too @Mattedfred )
    Mattedfred likes this.
  30. Apr 25, 2024 at 5:48 AM
    #60
    PhearCVBz
    Yup, the power difference had me sway more towards an SR5 but the lack of brake controller (and I guess no tow mode) sealed the deal. Yes, I know an SR would have still been cheaper if I added those things myself, but at the end of the day it would still have 30+ less HP (that I probably wouldn't have noticed other than having it in the back of my mind). I had several other Tundras, and my last one before the Gen 3 was a Gen 2.5 SR....Great bang for the buck with the same power, tow package, and etc....was disappointment that they went a different route for Gen 3, but I can understand it from Toyota's point of view if the previous Gen SR's were stealing a lot of the SR5 sales.
