Upper Control Arms
Discussion in 'Suspension' started by supermotobobby, May 7, 2020.
  1. May 7, 2020 at 8:14 AM
    supermotobobby
    supermotobobby [OP] New Member
    Bobby
    2022 Tundra Platinum 4x4
    Do upper control arms have alignment adjustments or is it just the lower control arms?
  2. May 7, 2020 at 8:16 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    OEM does not have adjustment. There are some aftermarket UCAs that do allow adjustment
  3. May 7, 2020 at 8:18 AM
    supermotobobby
    Bobby
    Awesome thanks! I'm changing bushings.
    831Tun likes this.
  4. May 7, 2020 at 9:45 AM
    831Tun and equin like this.
  5. May 7, 2020 at 12:33 PM
    supermotobobby
    Bobby
  6. May 9, 2020 at 12:12 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Thanks for the link. I may be doing UCA’s as well. I notice the link is to a 12-point wrench. I’ve had bad experiences before rounding off bolts using a 12-point when trying to break them loose. I take it you had no problem with that when using this wrench on your UCA’s?
  7. May 9, 2020 at 6:09 AM
    I didn't have any issues and mine is a 13 with 94K. I used a 2 foot long section of pipe on it as my breaker bar.
    equin[QUOTED] likes this.
  8. May 9, 2020 at 7:32 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Tundra234[QUOTED] and equin like this.
  9. May 9, 2020 at 10:42 AM
    equin
    Ed
    DFW, TX
    Good to know. I can’t seem to find a long, zero offset 6-point in 22mm.
  10. May 9, 2020 at 11:38 AM
    You can break the torque with a regular 22mm and then switch over to the GearWrench.
