Upgrading to Power Fold Mirrors
Discussion in '3rd Gen Tundras (2014-2021)' started by FatBrian, Apr 17, 2017.
  1. Oct 23, 2019 at 11:58 AM
    #241
    D3Tundra
    D3Tundra New Member
    Dennis
    Atlanta, GA
    2018 Midnight Black Tundra Limited 4x4 CM
    Rigid fog lights Interior Led light upgrade Spray in Bedliner CRUX Avity-01 VIM Bypass module 5% tint all the way around 50% on the windshield Wireless charger arm rest mod Amp Research Steps Bak Revolver X4 Tesla Style Headunit Procomp 4" lift Toyo M/T's 35x12.5xR22 Fuel Maverick D538 wheels 22x10 -24 offset
    Where/how did you rewire pin 5? For me, if I leave pin 5 as is, the puddle light stays on. If I run pin 5 to an actual ground it works. However, when I have pin 5 run to an actual ground I get the BSM error. Do both mirrors have to be rewired in order to not get the BSM error? (I haven't done the other side yet)
  2. Oct 23, 2019 at 12:15 PM
    #242
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    So I don't have an answer yet... I left the wires for the puddle disconnected because I had the same problem. The others with a "solution" did not have BSM to contend with as we do.
    My thought was to try and run dedicated wire from the door to the puddle light. I think we are going to have to leave pin 5 alone for the BSM and find a solution for the puddle lights that involve dedicated ground. There are open pin slots so it should not be too hard and I found out how to remove the glass and get into the mirror so the hard part will be passing through the mirror assembly...
  3. Oct 23, 2019 at 12:17 PM
    #243
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    ^ the puddle lights are nice and I plan on getting to them but the power fold was a must for me to get the truck in the garage, and the BSM I like so it was an easy decision to hold off on the puddle until I have time, the wires are ran. I even have auto dim but not connected either...
  4. Oct 23, 2019 at 12:27 PM
    #244
    D3Tundra
    D3Tundra New Member
    Dennis
    Atlanta, GA
    haha ok. I'm the opposite... Never really had BSM so hard to miss it. I had the same garage issue so thats a must for me too. But I put expensive ahh (but nice and worth it now that I have them) VLEDS in the puddle lights. I was hoping to fix this and stop being lazy but it appears I'm back to square 1 (aka lazy) because I'm not about to run dedicated wires for the puddle and everything else thats involved with that. I already have a ground ran but still.
    BlueTundra2019 likes this.
  5. Oct 23, 2019 at 12:29 PM
    #245
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    I will let you know when I get it figured out, it's not a matter of lazy but I have another project I working on and spring will be here sooner than I know..
  6. Oct 23, 2019 at 12:36 PM
    #246
    D3Tundra
    D3Tundra New Member
    Dennis
    Atlanta, GA
    *Sigh* I just did my last track day of the season a Barber. I need to tear my bike down as well and fix some issues smh. Thanks for reminding me of that project too smh
  7. Oct 23, 2019 at 1:03 PM
    #247
    D3Tundra
    D3Tundra New Member
    Dennis
    Atlanta, GA
    So I just did a random test to see if the puddle lights would actually stay on... After 20 minutes to the second, you can hear a click come from the truck and the puddle lights shut off with it. I'm going to connect the other side and see if this solves BSM/Puddle light-gate. If this does work, because I'm running leds in the puddle lights, I may run with this as they shouldn't drain much power. It's almost as if the truck cut all power precisely for cases like this.
  8. Oct 23, 2019 at 1:30 PM
    #248
    D3Tundra
    D3Tundra New Member
    Dennis
    Atlanta, GA
    Scratch that. Puddle light would even stay on when driving. Back to the drawing board.
  9. Oct 23, 2019 at 1:49 PM
    #249
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    you can fix the puddle lights by bringing the wire into the cabin under the dash and tying them into the foot well light, that's what i did. not saying it's the only way, but it's an option to get them working correctly.
  10. Oct 23, 2019 at 1:52 PM
    #250
    JoeJob
    JoeJob Drummer for Booty and the Hoe Fish
    Joe
    New England
    2018 Tundra Limited CM Silver Sky
    TRD rear sway bar, console organizer, stubby antenna, LEDs for cabin, cargo, license plate, and reverse lights, power-fold mirrors, Westin nerf bars, full stereo upgrade. Future - color-match grill surround/bulge, mirror caps, handles, plasti-dip badges.
    I tied my puddle lights into the footwell also. They stay on when you shut the truck down, then dim out after 30 seconds along with th edome lights.
    B737 likes this.
  11. Oct 23, 2019 at 2:15 PM
    #251
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    I'm assuming both of you do not have BSM becuase that doesn't work.... they still stay on when you have bsm on pin 5 shared.
    D3Tundra likes this.
  12. Oct 23, 2019 at 2:27 PM
    #252
    B737
    Jersey Shore
    If you connect a light to the footwell light, it will function with the footwell. run two new wires from the footwell, to the light bulb in the mirror, skipping the factory wires all together.
    matictundra likes this.
  13. Oct 23, 2019 at 2:32 PM
    #253
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Correct but getting it through the mirror housing is no easy task..
  14. Oct 23, 2019 at 4:44 PM
    #254
    B737
    Jersey Shore
    its not that bad, getting it through the door jamb is the hard part. I did it so long ago i cant even recall the details.
  15. Oct 23, 2019 at 6:14 PM
    #255
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    the door jam is a breeze, I think you are missing what I’m saying getting the wires from the inside of the mirror into or past the connector on the mirror itself. If I’m missing something please help :)
  16. Oct 24, 2019 at 4:38 AM
    #256
    1794-BlackTundra
    1794-BlackTundra New Member
    Sergio
    2019 Black Tundra 1794 Edition CM
    Rhino Linings, Smittybilt 11500 Winch (Internal), BAKflip MX4, RotopaX, MaxTrax, ARB Simpson III tent, Old Man Emu suspension, TRD rims, Pioneer Platform with Rhino-Rack Backbone System
    That's some dedication right there! :bowdown:
  17. Oct 24, 2019 at 7:05 AM
    #257
    D3Tundra
    D3Tundra New Member
    Dennis
    Atlanta, GA
    haha I'll try to help clear this up for them. The puddle lights are terminated to the back of the connector INSIDE the mirror. The ground of the puddle light shares pin 5 (which is the problem). Only way to run separate wires is to take apart the mirror and remove the connector and figure out a way to get past it.
    Tchase likes this.
  18. Oct 24, 2019 at 7:14 AM
    #258
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Thank you :) that is what I was trying to explain there is literally a firewall in the mirror it'self to pass a wire through! And I'm not about to try taking the housing apart without knowing how...
  19. Oct 24, 2019 at 7:20 AM
    #259
    B737
    Jersey Shore
    You can run two wires to the spot where the puddle lights go, it is not difficult, I did it, as did many people on this forum. the hardest part is getting the wires through the shaft where the mirror pivots. taking the mirror apart isnt hard. With the glass out there is a ton of room.
    its not a 'firewall' lol
    I have run 4 wires into the mirror, people do it all the time
    you dont have to 'go through' this connector. This was the picture I took before running the 4 wires. Just take the mirror off, take it apart. I think I went next to the connector and I went through plastic inner inside panel of the mirror and just used some butyl to seal up around the loom of wires i added. These are tiny lights, use tiny wires 18-22ga.
  20. Oct 24, 2019 at 7:24 AM
    #260
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    I've had the mirror (the glass that is easy) off I saw no way to pass a wire through and I'm not seeing it in your pics
  21. Oct 24, 2019 at 7:30 AM
    #261
    B737
    Jersey Shore
    Here is the other side, with the puddle light on the outboard part of the mirror and you can see the signal glass (above post), has its own set of wires too. Only removing the 3 screws and pulling the mirror from the truck isnt going to cut it, you have to open up the mirror. I would start with removing the glass since its easy, and work backwards. good luck.
  22. Oct 24, 2019 at 7:34 AM
    #262
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    I've had the mirror assembly on the bench, removed the glass and stared at it for 1/2 an hour and figured I would bust it trying to take it apart even this pic isn't showing me anything new :(
  23. Oct 24, 2019 at 7:42 AM
    #263
    B737
    Jersey Shore
    it's not because i did it 4 years ago and I dont remember the details which means it was a pretty unremarkable task. May need to drill a hole through the plastic inside panel, seal with with butyl and pass the wires through, you are not committed to using the factory connector, there is no "wall", its just plastic. drill it with a step drill if you need to.
    On our trucks the cabin lighting uses a modulated ground from the ECU to dim and turn off the lights, which is why your LEDs are staying on all the time. You need to bring the wire into the cabin and connect it to the dome / footwell circuit.
  24. Oct 24, 2019 at 7:50 AM
    #264
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    yep I know what to do with the wire once it is through, but you are confirming my thoughts, it’s not a disassemble and reassemble. I prefer not to make irreversible mods. Technically I can slap the old mirrors back on lol
    thank you like I said I’ll get back to it and share what I come up with.
  25. Oct 25, 2019 at 7:20 AM
    #265
    Tom_Tundra_TN
    Tom_Tundra_TN New Member
    Tom
    2016 TRD CM
    TRD Exhaust, TRD Front&Rear Sway Bar, TRD Shifter Knob, BFG TAKO2, Toyota GBS, 3/1 Leveling Kit, K&N CAI, Leer 100XQ Topper, Tinted Windows, Tacotunes Upgrade, Bed LED Lights, Mirror Caps & Door Handle Color Match, BedRug, LED Interior Lighting, Tailgate Tundra fill, Toyota Step Rail, Katzkin Leather Seats, Leather Console, FRAC Harness, Stubby Antenna, Power Folding Mirrors, Autoloc One-Touch Window Mod, TRD Pro Wheels w/ Lug Nut Covers, Color Match Bumper Ends
    Tchase
    Finished the install. Thank you for all your advice and photos. I had to move the pins like you said and no BSM issues.
    Tchase likes this.
  26. Oct 25, 2019 at 7:35 AM
    #266
    19TRDPRO_FL
    19TRDPRO_FL New Member
    Paul
    Parkland, FL
    2019 Tundra TRD Pro
    Audio: Pioneer 8200NEX Infinity Kappa complete speaker package 4 Channel Kenwood amp 5 Channel Kenwood amp 10 inch JL Audio W1 shallow mount sub X 2 Readylift Pro Plus 4in lift (6 total) 22x12 Fuel Sledge wheels 35x12.5R22 Nitto Ridge Grapplers LED bar in hood scoop LineX step rails
    These look amazing!!! I love the turn signal in the mirror!!!
  27. Oct 25, 2019 at 8:10 AM
    #267
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Nice!
  28. Oct 25, 2019 at 10:21 AM
    #268
    Hobbesdsm
    Hobbesdsm New Member
    Eddie
    2016 crewmax limited
    TRD exhaust and rear sway bar, 2018 led headlights
    I’m about to do this mods. I have the same situation as some of you, need to park in tight
    Garage. Anyway where you all get the mirror control unit from other than dealer?
  29. Oct 25, 2019 at 11:28 AM
    #269
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    You really only have two options if you want to maintain certain features. You can pay an arm and a leg from the dealer for new mirrors for a specific year that has what you want/ need, or luck out and find a used set like I did ($350 for a set off a platinum 2016). You can go with an after market however you will not have as much of an option to get the features you may want. I was going to go aftermarket but wanted to retain BSM and heated which wasn't offered for a folding mirror. My specifics may be off :)
  30. Oct 25, 2019 at 11:30 AM
    #270
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    BTW when I figure out how I tackle the puddle lights I report back..
