Upgrading to Power Fold Mirrors
Discussion in '2.5 Gen Tundras (2014-2021)' started by FatBrian, Apr 17, 2017.
  1. Aug 21, 2019 at 4:18 AM
    #121
    KTJO 4x4
    KTJO 4x4 New Member
    Katie
    Oregon
  2. Aug 21, 2019 at 4:31 AM
    #122
    KTJO 4x4
    KTJO 4x4 New Member
    Katie
    Oregon
  3. Aug 21, 2019 at 7:48 AM
    #123
    13igtymer
    13igtymer New Member
    2016 toyota tundra crewmax limited
    Will the harness be compatible with tow mirrors with out the power fold feature like the aa1 auto Ridgeline tow mirrors?
  4. Aug 21, 2019 at 11:54 AM
    #124
    showtime240
    showtime240 New Member
    oh man , i cant wait!!
    B737 likes this.
  5. Aug 21, 2019 at 3:53 PM
    #125
    sstoddard
    sstoddard New Member
    Shawn
    2019 Crewmax Sport
    Alarm/start (Compustar Ft7000,Rf2wl1b 2-way remotes and Drone Mobile) Tailgate inserts NSV Lightbar Tailgate actuator Blacked out decals
    IS IT TIME YET?.....IS IT TIME YET?.....
  6. Aug 21, 2019 at 6:35 PM
    #126
    Tom_Tundra_TN
    Tom_Tundra_TN New Member
    Tom
    2016 TRD CM
    TRD Exhaust, TRD Front&Rear Sway Bar, TRD Shifter Knob, BFG TAKO2, Toyota GBS, 3/1 Leveling Kit, K&N CAI, Leer 100XQ Topper, Tinted Windows, Tacotunes Upgrade, Bed LED Lights, Mirror Caps & Door Handle Color Match, BedRug, LED Interior Lighting, Tailgate Tundra fill, Toyota Step Rail, Katzkin Leather Seats, Leather Console, FRAC Harness, Stubby Antenna, Power Folding Mirrors, Autoloc One-Touch Window Mod, TRD Pro Wheels w/ Lug Nut Covers, Color Match Bumper Ends
  7. Aug 21, 2019 at 7:08 PM
    #127
    LifeCycle
    LifeCycle Build..build..build..
    Hugh
    Barcelona Red SR5 XP CM 2017
    TRD Dual exhaust TRD headlights bedmat Elka with adjustment knobs, ARB leafs-ring Fuel Crush +1 offset 20 inch 5 in backspacing TOYO open country 275/65 R20
    ill be in for this!!
    KTJO 4x4 likes this.
  8. Aug 21, 2019 at 8:00 PM
    #128
    TaquitoBandito
    Joel (AKA Bif)
  9. Aug 21, 2019 at 8:22 PM
    #129
    What the!?
    What the!? New Member
    2017 Pro
    KTJO 4x4 and showtime240 like this.
  10. Aug 21, 2019 at 8:26 PM
    #130
    GNTundra
    Gino
    2013 White
    Its a nice upgrade. Well worth the trouble. :thumbsup:
  11. Aug 21, 2019 at 8:52 PM
    #131
    Hobbesdsm
    Hobbesdsm New Member
    Eddie
    2016 crewmax limited
    TRD exhaust and rear sway bar, 2018 led headlights
    Interested!!:spending:
  12. Aug 22, 2019 at 4:55 AM
    #132
    cropduster7
    cropduster7 New Member
    I’m in for the “option 1” like you have for the Tacoma’s which is the actuators and harness. I bought an aftermarket switch already. I’ve got a 2018 SR5 4x4 with heated and power mirrors. I really need the power fold because I’ve only got a few inches each side going in my garage! I think I’d like to keep the factory housings since I’ve seen posts about the aftermarket ones shaking.
  13. Aug 22, 2019 at 8:04 AM
    #133
    Spence30
    Spence30 New Member
    Josh
    ‘19 SR5 TRD cement grey
    That’s what I want also
  14. Aug 22, 2019 at 10:27 AM
    #134
    cd121082
    cd121082 New Member
    chris
    Washington State
    2016 Silver Tundra TRD OffRoad
    none yet
    following
  15. Aug 23, 2019 at 12:57 AM
    #135
    KTJO 4x4
    KTJO 4x4 New Member
    Katie
    Oregon
    danz75 and 1794-BlackTundra like this.
  16. Aug 23, 2019 at 9:32 AM
    #136
    KTJO 4x4
    KTJO 4x4 New Member
    Katie
    Oregon
    So I just updated my post from #78 and I wanted to repost it again...
    I was looking at your 2007-2013 Wiring Diagram that I found on one of the threads that someone was so kind to post and it seems as though the Tundra uses the same style of OEM Connectors. I’m not sure if the are the Pins are the same, but the Connectors at this point seem to look to be the same. I will need to see if I can find the Part No’s as well. This is what I know at know so far regarding the wiring for the 2nd Gens.
    My Plug-N-Play Door Lock and Unlock Harness would connect directly to the N4 OEM Connector inside the Door in order to communicate with the Factory Lock and Unlock Mechanism. This would be Pin #1 & Pin #2.
    My Plug-N-Play Power Window Regulator Motor Harness would connect directly to the N12 OEM Connector inside the Door in order to communicate with the Factory Battery and Ground. This would be Pin #1 & Pin #2. The Power Wire connects directly to the Control Module. The Ground Wire has a OEM Terminal crimped on the other end that will need to be inserted into your OEM O1 Connector.
    As for the last wire, my Plug-N-Play Power Window Regulator Master Window Switch Harness would Connect directly to the OEM N2 Connector inside the Door in order to communicate with the Factory ACC. The ACC Wire connects directly to the the OEM O1 Connector. This would be Pin #13 in the OEM N2 Connector and it would then have an OEM Terminal crimped on the other end that would need to be inserted into your OEM O1 Connector.
    Now for the 3rd Gens, I was looking at your 2015+ Wiring Diagram that was so kindly sent to me and it seems as though the Tundra uses the same style of OEM Connectors. I’m not sure if the are the Pins are the same, but the Connectors at this point seem to look to be the same. I will need to see if I can find the Part No’s as well. This is what I know at know so far regarding the wiring for the 3rd Gens.
    Am I missing something or what happened to the 2014 TOYOTA TUNDRA? If one Wiring Diagram goes from 2007-2013 & the other one says 2015+, what happened during the year 2014?
    wnoble likes this.
  17. Aug 23, 2019 at 9:37 AM
    #137
    JoeJob
    JoeJob Drummer for Booty and the Hoe Fish
    Joe
    New England
    2018 Tundra Limited CM Silver Sky
    TRD rear sway bar, console organizer, stubby antenna, LEDs for cabin, cargo, license plate, and reverse lights, power-fold mirrors, Westin nerf bars, full stereo upgrade. Future - color-match grill surround/bulge, mirror caps, handles, plasti-dip badges.
    The 3rd Gens should be the same - I installed 2nd Gen mirrors from a 2012 Limited on my 2018 Limited so I could get power-fold. The wiring was identical except my OEM mirrors didn't have pins for fold/auto dim/puddle lights.
  18. Aug 23, 2019 at 7:41 PM
    #138
    Tom_Tundra_TN
    Tom
    2016 TRD CM
    house likes this.
  19. Aug 28, 2019 at 7:23 AM
    #139
    showtime240
    @KTJO 4x4
    Any updates? I am ready! and so is my paypal!
  20. Aug 28, 2019 at 7:29 AM
    #140
    coTony
    Tony
    Montrose, CO
    I am anxious to see the results. I also know there was wiring harness changes starting with the 2018's. I bought a 2018 Platinum and there were changes for everything I put on that had to be wired
  21. Aug 30, 2019 at 8:47 PM
    #141
    KTJO 4x4
    KTJO 4x4 New Member
    Katie
    Oregon
    Well if you have the wiring diagram please share it with me
  22. Aug 30, 2019 at 8:47 PM
    #142
    KTJO 4x4
    KTJO 4x4 New Member
    Katie
    Oregon
    Getting closer
    showtime240[QUOTED] and coTony like this.
  23. Sep 2, 2019 at 11:01 PM
    #143
    KTJO 4x4
    KTJO 4x4 New Member
    Katie
    Oregon
    UPDATE:
    Tracking on PNP Harness shows arrival on the 6th. However, I went ahead and made the purchase bc I am 99% sure everything is good to go! They will take the next 4 days making 50 sets. Then they will ship them to me. I should receive them most likely 4 business days after that. Therefore, we are looking at an ETA of 2 weeks!!!
    TACOMA POWER FOLDING MIRRORS ARE AT FULL RELEASE 100% PLUG-N-PLAY COMING SOON!!!!
    On this same shipment I will be receiving the 100% PLUG-N-PLAY TUNDRA POWER FOLDING MIRRORS HARNESS to TEST!!!!! I already know the SR5 Model needs different connectors. I’m working on that :thumbsup: If the 2018+ Model has a different Wire Diagram I need to receive a copy please. Thank You!
    TTund16, Sas, showtime240 and 3 others like this.
  24. Sep 3, 2019 at 12:18 AM
    #144
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    I’m in!
  25. Sep 3, 2019 at 12:25 AM
    #145
    13igtymer
    Do you have a price for it as of now?
  26. Sep 3, 2019 at 12:29 AM
    #146
    TXTundra2722
    2015 Black Tundra
    Samesies
  27. Sep 3, 2019 at 5:18 AM
    #147
    sstoddard
    Shawn
    2019 Crewmax Sport
    I'm in
  28. Sep 3, 2019 at 6:31 AM
    #148
    jdmek998
    jdmek998 New Member
    2021 Tundra Platinum
    Following! This would be awesome feature.
  29. Sep 3, 2019 at 6:32 AM
    #149
    1794-BlackTundra
    1794-BlackTundra New Member
    Sergio
    2019 Black Tundra 1794 Edition CM
    Rhino Linings, Smittybilt 11500 Winch (Internal), BAKflip MX4, RotopaX, MaxTrax, ARB Simpson III tent, Old Man Emu suspension, TRD rims, Pioneer Platform with Rhino-Rack Backbone System
  30. Sep 3, 2019 at 7:13 AM
    #150
    coTony
    Tony
    Montrose, CO
    I am in. I have a 2018 Platinum with all the powers in my mirror
